Steady hand, good eyes and he did it.
Started by POSTON WIDEHEAD, October 22, 2015, 09:46:25 PM
Ga Mtn Man
So are you less likely to hit them as they get shorter?  I'd like to think there is some hope out there.
MartyParsons
Hello,
You can solve the pin falling out by replaceing the old gear with the new and improved style. They removed the spring roll pin and put two set screws on each side. Note that there is a pin mounted to the screw. Lock Tite works on the screws.  ;) blue
Before this change I would wire the pin. Thread the wire through the pin and wrap it around the gear. At this point the gear and the motor shaft is worn and should be replaced. But you can keep it in operation until the part arrives.
If the pin brakes more than once the rollers are tight on the arm on another binding issue.
Marty
Part # P09970  $ 6.95 each.
terrifictimbersllc
Quote from: Ga Mtn Man on October 26, 2015, 09:08:13 AM
No. A couple of weeks ago mine were only 3 inches up and one of them still managed to jump up and grab the blade.  smiley_hellow_im_here  Hint you don't have to saw them down you can just lower them, this will save some blades at least.
Bandmill Bandit
Hey Marty
Thanks a bunch for posting the upgrade Kit part number. I just haven't had a chance to look for it.
4x4American
I'm willing to bet it's from jamming it open or closed.  In the picture, its that roll pin is sheared off?
Boy, back in my day..
POSTON WIDEHEAD
Quote from: 4x4American on October 26, 2015, 09:02:27 PM
It happened when I was attempting to pass a knot that I should have chain sawed off ahead of time.
You're actually looking at the new pin already installed.
Kbeitz
Quote from: terrifictimbersllc on October 26, 2015, 08:28:40 PM
It's real easy to make a pusher in front of your blade that will hit the side supports before the blade.
It will eather stop the mill or push down the side supports.
Love machine shop work
and Wood work shop work
And now a saw mill work
Dave Shepard
You will loose some of your throat capacity that way on a WM, and you won't push down a hydraulic support.
MartyParsons
Hello,
This thread is jumping around. The picture of the gear and the screw on only one side of the pin is on the allen wrench. The new design has two set screws on each side. No more roll pin.
Understand?
Marty
drobertson
 new is good, but have to say, I've never seen much of an issue with the existing roll pin design,  other than at times through the winter when frozen conditions are present.
highleadtimber16
I finally welded mine onto the shaft. It's never coming loose again. ;D
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
Ga Mtn Man
My blade guide stopped moving yesterday so I thought I was gonna get a chance to see if my hands were goat-steady.  Well, when the sprocket fell off with the first tap on the pin punch I realized there was more going on than just a sheared pin... the shaft was broken at the pin hole  :(.  With the motor off of the drive chain, I tugged on the blade guide arm and found it was pretty hard to move.  I must have over-tightened the rollers when I did an alignment a few months ago .  I think this may have caused the shaft failure.  I find it difficult to tell when the rollers are tight enough but not too tight  ???.
So... I'll be ordering a shaft and new-design sprocket tomorrow.   Did the shaft get re-designed too?  I recall seeing a post here on the forum that it did, but I can't find the post.
terrifictimbersllc
Quote from: POSTONLT40HD on October 26, 2015, 09:38:00 PM
Be prepared for adventure on the goat path, roll pins being just one possibility. 🐐
