Dynamic Green Products Inc.
Author Topic: How to remove clutch drum on 55 Rancher?  (Read 2155 times)
Offline Timberwerks
  • Timberwerks Studio
« on: October 01, 2004, 07:17:05 PM »
Can anyone give me some tips on removing the clutch drums on a 55 rancher and 3120? I would like to grease the bearings and replace rim sprokets. I know I need a piston stop but I cant seem to find one. Any tips?
Dale
Offline jokers
  • Chainsaw Freak
Re: How to remove clutch drum?
« Reply #1 on: October 01, 2004, 08:31:19 PM »
You can buy piston stops from your Husky or Stihl dealer for about $10. You want a metal one if you choose the screw in type and you can buy the long version and use it on all of your saws. The plastic screw in stops may break if loaded at an angle, they were originally made for the horizontal cylinder saws where the plug entered perpendicular to the crown of the piston.
A cheap and workable substitute is enough clean starter(or lint free, minimally compressible) rope fed through the plug hole to lock the piston, then it`s a left hand thread to remove the clutch. Be careful that you don`t allow the rope to go into your exhaust port as you feed it into the cylinder.
Russ
Offline Timberwerks
« Reply #2 on: October 02, 2004, 11:24:10 AM »
I got the job done. It was very easy and took about 10 minutes. I got the non screw in type piston stop and it worked like a charm. Now I can always be sure my needle bearings are greased. My other Husky's have the in board clutch and those are really easy to do.
Dale
Offline oldsaw
  • It's a tree, it's a board, it's a....
I've always used rope for that stuff
« Reply #3 on: October 02, 2004, 08:07:25 PM »
Figured it out when I rebuilt my father-in-laws mower on Memorial day a few years ago.  Briggs with overhead valves.  Had to pull the valve springs, but didn't want to pull the head.  He thought I was smart then, but it completely flipped him out when I rebuilt his carb with a couple of salvaged screws from a junked computer, some epoxy, a piece of wire, and a beer can.
So many trees, so little money, even less time.
Stihl 066, Husky 262, Husky 350 (warmed over), Homelite Super XL, Homelite 150A
Offline sawguy21
« Reply #4 on: October 03, 2004, 03:14:56 AM »
Up here, we call that McGyvering after a TV character who could make a bomb or just about anything else from a paper clip and a wad of chewing gum. ;D
Offline GAV64
  • I hate the daily routine!
« Reply #5 on: October 06, 2004, 04:58:49 AM »
I use and impact wrench, no need to use a piston stop. Same as getting pulley of an alternator.
clutch drum bearing
Started by jwilly3879 on Chainsaws
Last post April 05, 2015, 09:50:29 AM
by celliott
What is picco clutch drum used for.
Started by alsayyed on Chainsaws
Last post February 01, 2007, 07:17:30 PM
by SawTroll
replace clutch spring on 55 Rancher
Started by propster on Chainsaws
Last post February 11, 2012, 10:49:42 PM
by kenskip1
Old Homelite Clutch Spider/Drum Question for C-Series & XP series
Started by weimedog on Chainsaws
Last post December 11, 2005, 02:45:12 AM
by Bill
