Author Topic: Stacking wedges in felling tree  (Read 5918 times)
Offline Kenzen
« on: November 11, 2015, 06:33:25 PM »
I was wanting to use stacking wedges in helping fell a tree.  Have heard that one can either plunge cut above or below your felling cut and put wedges in the plunge cut such in as the pic.  So any advise in best way of doing this
Offline beenthere
Re: Stacking wedges in felling tree
« Reply #1 on: November 11, 2015, 06:54:12 PM »
Looks like it might work, but they would be hard to hit individually to drive them in.
Offline Autocar
« Reply #2 on: November 11, 2015, 07:11:29 PM »
I just stack two wedges on top of each other and drive them into the cut if one dosen't lift it enough. Iam not sure how your way will help but not a expert on that type of lifting.
Bill
Offline CCC4
« Reply #3 on: November 11, 2015, 07:28:38 PM »
Thats a new one on me for sure. I don't see the advantage. I will stack them like Autocar suggested but I can't get my head around the 4 wedges. Looks to me like if you had a bad back lean you were wedgeing against that those 4 essentially kerfs would work against themselves on lifting. I am curious to hear what other people have to say, it's interesting for sure.
It looks from the pic that your back cut is minimal and you will run out of lift. What kind of face is in that cut?
Offline Maine372
« Reply #4 on: November 11, 2015, 07:32:51 PM »
been there, done that. its a pain but it does work.
the easier method is this - drive one wedge all the way. cut a slice about the thickness of the butt end of the wedge from something small, like 3-4in. use that as a spacer and drive the second wedge. rinse and repeat as needed.
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #5 on: November 11, 2015, 07:40:45 PM »
Kenzen, is that your photo or did you lift it from another website?
Offline june
« Reply #6 on: November 11, 2015, 08:18:20 PM »
sorry i never saw that . i use for big threes two wedges on the sides  and a thicker iron wedge on the back and it always work for me.
or push it with the skidder :D
Offline SFires
« Reply #7 on: November 11, 2015, 09:04:41 PM »
Looks to me that the amount of "lift" each wedge could make would be limited by a plunge cut off me if that makes any sense to anyone. Seems a shallow cross cut would be better to allow more lift  but I guess that could also possible cause a chunk to break out the back side.  Curious to see how it works. Let u know how it goes if you try it
A man can always use more tools, more space,more wood, and a whole lot more time.
Offline redprospector
« Reply #8 on: November 11, 2015, 09:31:30 PM »
I don't see the practicality of it. Why not just drive in 1 wedge to get a little lift, and then stack up a couple more in the same cut if needed. That should give about 2 1/2" of lift. If that isn't enough there are lots of other things that can be done without boring 3 slots in a stump.
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
Offline John Mc
« Reply #9 on: November 11, 2015, 09:37:44 PM »
That's how I do it. Driving the second wedge on top of the cookie frees up the first wedge. If the second wedge doesn't tip it over, cut another thicker cookie to slip into the gap, and pound the first wedge in on top of that.
Another benefit: a wedge on top of a cookie is far less likely to spit back out of the back cut than two wedges stacked on top of each other.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #10 on: November 11, 2015, 10:18:30 PM »
Never seen a thing like that.
And by the time you had all the wedges in I would have the tree on the ground.
Offline Spartan
« Reply #11 on: November 11, 2015, 11:49:15 PM »
And the next one too!
Offline SineWave
« Reply #12 on: November 13, 2015, 01:06:50 PM »
Bailey's "rifled" falling wedges are nice for stacking. The "rifling" keeps them stacked by keeping them from squirming out...
Offline loggerman1959
« Reply #13 on: November 13, 2015, 01:44:25 PM »
I think that's over complicating things . Put two wedges together , sandwich  a little sawdust in between for stickiness , and drive them into the back of the tree . If that don't work use that big john deere wedge and push it over .
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #14 on: November 13, 2015, 02:17:31 PM »
East and West agree!  Loggerman's solution of sawdust for stacking wedges works, without bringing into play the hardness of the wedge. But, use two of the same type.
Offline treeslayer2003
« Reply #15 on: November 13, 2015, 04:02:28 PM »
good tip on the saw chips, i'll try that. normally what i do is start three side by side but only drive the two outer ones, then when i stack the middle they can't slip side ways.
how can ya push a tree heavier than the skidder?
Offline SineWave
« Reply #16 on: November 13, 2015, 06:27:58 PM »
Gears / leverage / mechanical advantage?
How can a 16# sledge with a 2 ounce wedge push over a 2-ton tree?
You're not trying to lift the tree, just tilt it. Half the tree is being "lifted" but the other half is being lowered.
Offline OH logger
  • livin the dream
« Reply #17 on: November 13, 2015, 07:01:56 PM »
if you stack the two wedges at a 90 degree angle they don't pop out very often at all. pound one then the other and repeat
john
Offline thecfarm
« Reply #18 on: November 13, 2015, 07:34:14 PM »
I have used 6 inch wooden wedges made from a dead white maple. My Father and me did not want to flatten out a bunch of small trees so I pounded about 8-10 wedges for a good half hour. I can still hear my Father swearing at that tree and wondering why the DanG thing did not just tip over.  ;D
Offline GAB
« Reply #19 on: November 13, 2015, 07:37:56 PM »
I think you should add hydraulics to your list.
Gerald
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Felling wedges. Which brand is best
Started by Bthomasb3 on Forestry and Logging
Last post March 26, 2020, 03:11:35 PM
by Skeans1
Felling Wedges, what ones do you guys like.
Started by JOE.G on Forestry and Logging
Last post September 02, 2012, 02:05:05 PM
by lumberjack48
Cold weather felling wedges
Started by Firewoodjoe on Forestry and Logging
Last post February 22, 2020, 08:02:35 PM
by Firewoodjoe
cold weather felling wedges
Started by stumper on Firewood and Wood Heating
Last post March 13, 2012, 07:32:13 AM
by westyswoods
