Sawmill Calculator
Started by Darrel, November 29, 2015, 02:03:31 PM
Darrel
I've been looking for an app for my iPad to that will calculate board footage, both log scale and finished product. The only thing that I found in the App Store is "Sawmill Calculator" by Grant Erickson.  I downloaded the free version to check it out and I'm not smart enough to figure it out and there's no documentation to help me.  While for $4.00 the pro version does offer a bit more, without documentation, I'd still come up empty handed.
Does anyone have any suggestions?
Darrel
1992 LT40HD
@PostonLT40HD uses some sort of phone app.  (looks like the notify thingy is not working)
flatrock58
I have Board Feet easy calculator on my phone.  It is free and does an Ok job.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
Theo
Norwood have one and Micapeak
Theo
HUD-SON and Range-Road & KASCO Canada Dealer
Darrel
The one I'm trying to use is from micapeak but there is no documentation. To me it is useless unless I can figure out how to use it.
1992 LT40HD
The forum toolbox mobile view has several calcs.
Tom the Sawyer
Darrell,
I have used both of MicaPeak's products.  Other than the "About" section, there isn't much but I would be glad to try to answer any questions.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
POSTON WIDEHEAD
Quote from: Magicman on November 29, 2015, 02:18:15 PM
I just got your notification Magic.
I use Sawmill Calculator App. Its fast.
I also use the FF Calculator when fractions are needed.
I like to use the FF Cal. when giving quotes. I can enter my info at the mill and print it at home at the same time from my iPhone.
I've been trying to get Magicman to throw away that obsolete flip phone he has and get a smart phone.  :D :D
One day the Solenoid is gonna go bad in it and they don't make them anymore.  ;D
POSTON WIDEHEAD
Here is a screen shot of the Sawmill Calculator App I use at the mill.
I just put my finger on the dot and slide it to the desired number. Thickness x width x length and then the quantity.
It also lets you figure top to bottom cant sawing and what your last board will be depending on kerf.
I don't use it as I had already learned my kerf and starting positions before I found this app.
I also use an app.....if a customer has a standing tree, he can give me the circumference and then I give him the diameter and the board footage based on length. A lot of potential customers will call and give you what they think is the diameter but in reality, they are giving you the circumference.
The Forestry Forum Calculator has about everything you can think of on it pertaining to logs and trees.
Darrel
Thanks for the replies. I played with it a bit more and figuured out that the cut list is from middle to outside without turning the log. The board foot calculator is good but the cut list is not worth much because if I cut 1" slabs starting top to bottom, I'd get everything on the list without taking the time to punch in the numbers.
I'll check out the calculators on the forum.
1992 LT40HD
QuoteI've been trying to get Magicman to throw away that obsolete flip phone he has and get a smart phone.
Soon because I need something to check the weather.   ;D
redprospector
Quote from: Magicman on November 29, 2015, 09:17:03 PM
Don't do it!
It's a trap!  :o :o :o
That has indeed been my suspicion.   :o
Tom the Sawyer
Darrell,
MicaPeak has versions for Android and iPhones, which work the same way (see PostonLT40HD's screen grabs).   I didn't understand a couple of your comments:
1.    "the cut list is from the middle to the outside without turning the log."
The cut list generates the calculated starting height above the deck in order to minimize waste, whether all boards are of the same thickness (Flitch Remaining = None) or if you wish to end up with a different thickness on the deck (Flitch Remaining = whatever thickness you want, say 6" for a beam).  The starting height would be the same, whether you saw all of the way down, or if you flip the cant 180 degrees (stress, or to center the pith).
2.    "the cut list is not worth much because if I cut 1" slabs starting top to bottom, I'd get everything on the list without taking the time to punch in the numbers."
Are you including your saw kerf?  If you have a cant 16" tall, and a 1/8" kerf, it calculates that your first cut should be at 15 5/8" and that you would get 14 - 1" thick boards.  The real benefit is when you cut your 4/4 at 1 1/16" or 1 1/8", it makes those calculations for you, reducing errors.  If you are using a visual 1/4 scale which has the kerf figured in then you should "get everything on the list", unless you need to get different thicknesses from the cant.
I don't use it for my first two opening cuts.  I primarily am seeking a face clean enough to make a good board (and often orienting the most desirable "live" face).  I use the program to calculate where to make the opening cut on the face opposite the face on the deck.  If I am taking 5/4 boards (1 3/8") down to a 4" mantle from a cant 20" tall, I start at 19" - makes it pretty simple.
Like most software, the quality of the information you enter will determine the quality of the information you get from the program (GI-GO).
drobertson
The apps are pretty neat, but what about a scale stick and sawing logs?  just asking, it has seemed to me that even the best app is at best a good average at the end of the day.. unless the logs are primo,   lots of button pushing, I don't know, just ranting,  please don't tell customsawyer I was ranting after a Broncos win over the Pats! 8)
terrifictimbersllc
Quote from: redprospector on November 29, 2015, 10:11:59 PM
Don't do it!
A communist plot
slider
I guess my old flip phone makes me a relic as well.
al glenn
Outer Rondacker
Quote from: slider on November 30, 2015, 07:43:53 AM
Wondering what that makes me since the only phone I own has a cord on it. ???
Tom the Sawyer
drobertson,
I bought a International 1/4" scale stick to try out (Logrite, of course).  Unfortunately, the logs I mill don't come in two foot increments.  I also buy logs and would need to buy a stick with the Doyle scale.  The app, on the other hand, takes any length I enter, calculates in several common scales at a touch, keeps a record of what I have scaled, and will email a copy to me and anyone else I choose.  It even gives me log weight estimates based upon the species at the same time.  All for $2.99 - SawlogCalc Pro (they do have a trial version with a few limitations but free).
mobile sawmill services
whats wrong with the good old fashioned tape measure, pencil and paper, and a cheap calculator, this will give you the most accurate figures, and with practice, you will soon be able to look at a log, and with a quick length measurement, a couple of dia's, you will be able to do a pretty accurate guestimate based on your own sawing style, all the fancy apps are doing is taking the "learning curve" out of the equation, and it isnt that difficult.........just go for it, brain work keeps you on your toes  :P
POSTON WIDEHEAD
Nothing is wrong with the sticks or tape measures.
I have the Doyle and the International stick and 9 tape measures.  :D
I just like apps.  :o
drobertson
Quote from: Tom the Sawyer on November 30, 2015, 12:05:48 PM
drobertson,
Tom, I'll tell you that's a lot cheaper than the price of a scale stick! with all the added functions and memory as well,, You bet they are handy, fact is, I'm a flip phone user too, I reckon I got jealous,, the only point I was trying to make is the logs still have to be measured, also I read into it that the op was wanting an app to show what lumber would come from the log, my misunderstanding,, I know one thing for sure, tallying by hand in the wind and sometimes rain is a pain..
Tom the Sawyer
There is an alternative for those who don't have smart phones.  You can get an Android tablet for as little as $25.  They don't have high resolution screens or a bunch of advanced features but they communicate over WiFi, run apps like SawlogCalc or Sawmill Calculator, receive/send email, and you can even read the Forum or surf the web. No monthly access fees and, if you don't have WiFi, there are free hotspots at many businesses and restaurants including most McDonalds.  The one I use at the mill is an Azpen 10" that cost $50.
POSTON WIDEHEAD
Quote from: Tom the Sawyer on December 01, 2015, 09:11:54 AM
..........including most McDonalds.
Spend a lot of time at Mickey D's do ya Tom?  :D :D :D :D
drobertson
Thanks Tom, never gave this a thought, worth looking into for sure, we have wifi, and did have a pretty good egg mc muffin just today, they made a mistake, or as Christy said, I mumbled,, probably more the case, but, it was the best ham and egg mc muffin I ever had ;D  worse part of this morning was sending Bret back to California,, and when I got back the temps had dropped below freezing and yes, my strainer cracked, I forgot my windshield fluid,
