Author Topic: Using "Forestry Mover" in Urban area  (Read 4404 times)
Offline Climber
  • Quick, Clean & Safe
« on: December 17, 2015, 07:58:21 PM »
Have you ever drove by "Big Boys" logging company and watch them work. Big chippers / grinders, skidder, forwarders ...
I always fantasized about forestry movers. Finally I made decision to go for it. It is costly setup but could be very useful.
And now when I have it I am wonder how could I do some projects with out it.
Here is one of my projects:
Merrimack Valley Montessori School. They had 30 years of neglected property right by driveway. Poison Ivy, vines, construction garbage, prickle bushes, list goes on and on...
Operation: Total distraction.
2 minutes of your time.
Thanks for watching.
http://youtu.be/PkhQUZpl6c0
Online beenthere
Re: Using "Forestry Mover" in Urban area
« Reply #1 on: December 17, 2015, 08:13:18 PM »
Climber
You should join the "shameless" on the Forestry Forum page.
http://www.forestryforum.com/
Might also help your business.
Offline Climber
« Reply #2 on: December 17, 2015, 08:56:43 PM »
Climber
Sorry, I am not sure what do you mean.
Online beenthere
« Reply #3 on: December 17, 2015, 09:12:06 PM »
Click on the link and go to the front page.  Maybe @Jeff can assist and help you out.
Or go to this thread from the past to get more info about it.
http://www.forestryforum.com/board/index.php/topic,15291.msg218673.html#msg218673
Offline Climber
« Reply #4 on: December 18, 2015, 07:44:05 AM »
Offline thecfarm
« Reply #5 on: December 18, 2015, 07:49:54 AM »
A nice machine and a very nice job you did.
Offline Climber
« Reply #6 on: December 18, 2015, 08:16:53 PM »
Machine is nice. Yes. Thanks.
My 6-year old was operated not me, at list most of the time
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #7 on: December 18, 2015, 08:34:03 PM »
  That's a read slick machine. How does it do on old fence rows? I assume you have to remove the wire first. Sure wish I'd had one when I was a teenager working for my dad putting up chain link fences. He never even bought a chain saw till after I left home. Figured all I needed was an ax and brush hook.
Offline NWP
    • Nicholson Wood Products LLC
« Reply #8 on: December 18, 2015, 09:24:30 PM »
Nice. How long did that take from start to finish?
1999 Blockbuster 2222, 1994 Duratech HD8, 1997 Duratech HD10, 2011 Case SV250, 2000 Case 1845C, 1990 Peterbilt 378 w/ Hood 7000 loader, 2001 Chevrolet, 2005 Chevrolet, several trailers, and Stihl saws.
Offline pine
« Reply #9 on: December 18, 2015, 10:37:40 PM »
Looks like you were running a DCR rotor on that Fecon.  How do you like it.  Do you have a variable speed/2 speed motor on it and if so what is your opinion.  They sure do work nice.
Offline timberlinetree
« Reply #10 on: December 19, 2015, 06:49:51 AM »
That does a real nice job! Best thing about those( besides the job they do) is in the summer when you hit bees the little suckers can't get you! Great job!
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Offline chet
« Reply #11 on: December 19, 2015, 11:15:19 PM »
They can if ya got da window cracked.  smiley_furious3  Don't ask. :D
Offline Climber
« Reply #12 on: December 20, 2015, 03:06:17 PM »
Looks like you were running a DCR rotor on that Fecon.   ...
A: I am not sure what is DCR rotor is. It's what came from Fecon. Model BH74CC I think.
... How do you like it.  ...
A: Love it! 8)
...  Do you have a variable speed ...
A: No. I tried variable. Did not like it. Stayed with more simpler version. I think you need variable if you have lower GPM.
Offline Climber
« Reply #13 on: December 20, 2015, 03:28:28 PM »
Bzzzzzzzzz
http://youtu.be/EPFn29hBetk
Offline Climber
« Reply #14 on: December 20, 2015, 03:30:29 PM »
Not asking... But since you started ...  ???
Offline pine
« Reply #15 on: December 20, 2015, 08:10:00 PM »
A: Love it! 8)
Here is a picture of the three different rotors that they offer.
I thought from your video you had a DCR.  I stayed away from it as I have a few rocks that reportedly are not good on the DCR and I was strongly recommended in my use/forestry application not to get it. I have the HDT rotor.  Was curious as to the wear on your tools if it was a DCR. Are you running the Samurai knife or the double carbide tool?
I have 45 gpm flow on my unit and I went with the variable after talking with Mark at Fecon.  I will tell you that the variable flow motor is amazing compared to the single stage that I used previously.  It took a bit to get used to it because as you take a bigger bite it starts to slow down just like the regular hydraulic motors do and the tendency is to back off to let the rotor come back up to speed.  Instead if you just stay engaged the torque of the variable flow kicks in and it is amazing at the diameter that it can chew up.
What gpm does your unit have?  What is your recovery time from a full stall on the rotor?
Offline Climber
« Reply #16 on: December 21, 2015, 12:21:08 AM »
Wow, it's alot of info. Thanks Pine.
on the video you can see rotor and teeth on 33rd cecond, when machine still on trailer. I guess it's HDT with double carbide tool.
... What gpm does your unit have?  What is your recovery time from a full stall on the rotor?
~48 GPM.  I bump a bit so maybe 49-50.
Recovery time is very fast. 2-3 seconds.
Offline pine
« Reply #17 on: December 21, 2015, 08:52:40 AM »
 It would have helped if I had gone back and watched the video a second time before I asked.  :-[ I would not have asked a stupid question.  :-[
At 13 sec it is real obvious.  I never saw that the first time and was trying to see it from the "at work" part when the camera caught the rotor movement while at speed.  The RC 100 is a nice unit.
Offline Climber
« Reply #18 on: December 21, 2015, 10:38:52 PM »
... a stupid question ...
There are no stupid questions, only stupid anwsers. However, because you asked your questions I learned alot. Thank you.
... The RC 100 is a nice unit ...
Hell ye  8)
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #19 on: December 21, 2015, 10:50:54 PM »
those things are awesome
Boy, back in my day..
Fruits of "Urban Logging", pictures of yard tree furniture.
Started by Daren on General Board
Last post April 15, 2006, 03:35:38 PM
by iain
here is a picture of my white oak "urban waste" tree i salvaged
Started by Kelvin on Urban and Community Forestry
Last post December 08, 2008, 03:40:21 PM
by LeeB
"Harvesting Urban Timber"
Started by tyb525 on Urban and Community Forestry
Last post November 04, 2008, 09:01:02 PM
by tyb525
Need rental or services in Los Angeles area for Oak logs 10"-24" x10'
Started by dtmpadilla on Sawmills and Milling
Last post May 21, 2015, 08:12:17 PM
by WV Sawmiller
