Author Topic: Swing saw.... I think thats what they are called...  (Read 4553 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« on: December 20, 2015, 06:29:56 PM »
I needed a faster way to cut up my slabs. It's working great.
I welded on my handle to low but I can fix that.
I'm also going to put on a larger blade. It now has a 10"
Any one else use or have one?
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline dustyhat
Re: Swing saw.... I think thats what they are called...
« Reply #1 on: December 20, 2015, 08:10:32 PM »
Used to use a humongous one at my dads mill. think it had a 15 or 16 inch blade , used to scare the crap out of me when it would jump forward and catch. i was always scared it was going to break the safety chain . but they really worked good.
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Offline Kbeitz
    • My Hobbies
« Reply #2 on: December 20, 2015, 08:12:35 PM »
For that reason I'm looking for a Dash-pot.
Offline DMcCoy
« Reply #3 on: December 20, 2015, 08:31:52 PM »
Perfect timing, I plan on a re-do of my fire wood chop saw.
Dash pot-  (I had to look it up)
If you wanted to use an air cylinder there are special fittings for use on air cylinders that allow free air flow in one direction and adjustable restricted air flow in the other direction.  I have used them often, would be perfect in this application.
Offline beenthere
« Reply #4 on: December 20, 2015, 09:35:07 PM »
Unless what you are going to chop is below that 2" fence, then you may be in for some big bangs and wood getting thrown about. Maybe good for 2-by boards or 1-by.
Have worked around such swing saws, and when sharp.. they work pretty good. But not so good for slabs and mill junk.
The buzz saw types where the cutting force is down through a slot in the table is much safer, IMO.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #5 on: December 20, 2015, 10:12:37 PM »
Cutting front to back would be safer.
Make sure you keep your fingers clear when in use.
lots of dull bands and chains
Offline longtime lurker
« Reply #6 on: December 21, 2015, 03:58:55 AM »
The same thing but bigger used to be pretty common in mills here. Mostly gone now.. OH&S killed them off.
Offline Kbeitz
    • My Hobbies
« Reply #7 on: December 21, 2015, 06:10:01 AM »
I know how dangerous they are.  I never get in front of the blade when running.
For my dash-pot I'm thinking of using a hydraulic cylinder that gets fed back into
its self with a flow control valve in the line.
Offline Kbeitz
    • My Hobbies
« Reply #8 on: December 21, 2015, 06:11:52 AM »
A dashpot is a mechanical device, a damper which resists motion via viscous friction.
The resulting force is proportional to the velocity, but acts in the opposite direction,
slowing the motion and absorbing energy. It is commonly used in conjunction with a
spring (which acts to resist displacement).
Offline Ron Wenrich
« Reply #9 on: December 21, 2015, 06:25:04 AM »
I worked with one of those back in the early '70s.  Ours had a counter weight to keep the saw balanced, and to keep it back while running.  Our blade was bigger.  It was the same as you would see on a buck saw.  It made quick work out of cutting.  I'm not sure the smaller toothed saw will be as efficient.  We went to a smaller tooth and more modern setup, and we quickly took it out, if I recall.  We used it to cut up heavy slabs for firewood and to trim boards.
Are you planning to carry every board or slab over to be trimmed?  We put ours in the line flow of the mill.  Slabs were pushed to it and trimmed.  Same went for boards.  We used a wider set of dead rolls.  Our backstop was 6".  And we had a conveyor to take the cut up slabs away and pile them.  Neighbors burnt wood, so there wasn't much of a problem keeping it away.
Offline Kbeitz
    • My Hobbies
« Reply #10 on: December 21, 2015, 06:30:49 AM »
Yea... I will carry them over.. It's my down time and I don't mind it....
I'm not in much of a hurry. I wait until I get a saw horse full
before I start cutting. I spent about 1/2 a day using it so far.
It better that the way I was doing it before. Seems to work good.
But I do need a larger blade. About 3" thick is my limit right now.
Offline 21incher
« Reply #11 on: December 21, 2015, 08:22:05 AM »
Looks like that will get the job done. If you go with a bigger blade watch the tooth angle so It doesn't dig in. How about a clamp on top of the slab operated with a foot pedal to keep the slab from jumping without having a hand on it. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline drobertson
« Reply #12 on: December 21, 2015, 08:50:00 AM »
The one I have had an air cylinder to hold the cant down and back against the fence.  Not hooked up when I bought it and I never did, but I do think a clamp would help, as would a fence on both sides of the blade.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #13 on: December 21, 2015, 09:06:25 AM »
Classic story of a similar device here:  http://poestories.com/read/pit
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #14 on: December 21, 2015, 09:19:46 AM »
I like your idea of a closed loop hydraulic cylinder with a flow valve.  I believe they make flow valves that only work one way then is unrestricted the other.  Sounds perfect for your application.  Good thinking!  Nice idea for the saw too.  I work the same way - proof of concept first, then lots of tweaking to fine tune to make it nice and easy to use.
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
« Reply #15 on: December 21, 2015, 10:35:50 AM »
I have one that is 26". Had too much angle when I bought it. Changed blades and it works good. As mentioned above it is scary when the blade catches. That is what happens with too much hook angle. Always stand out of line with the blade. The way yours is set use the right hand to swing the saw. That way your body is out of line with the blade. I can get 30-40 pickup loads of wood per sharpenings. Lot faster than a chain saw.
Bill
Offline Kbeitz
    • My Hobbies
« Reply #16 on: December 21, 2015, 11:08:38 AM »
Well I just spent 3 hours running my mill with my wood vise edger setup.
I could make a cut and take the cut off piece to the swing saw and cut it up
before the carriage returned home. The swing saw is so fast. I'm all smiles.
Offline Ox
« Reply #17 on: December 22, 2015, 07:43:30 AM »
I'm happy for you!  Don't you just love when something works out as good or better than you imagined it?  Nice job.  8)
Offline Kbeitz
    • My Hobbies
« Reply #18 on: December 22, 2015, 07:46:13 AM »
Yep... I hated cutting up the slabs and I did not like edging.
Now it's not so bad. Cant wait for summer.
I'm ready to go. I also made a little wagon to slide under the
swing saw. I did not like picking up the cut wood off the ground.
Offline Ox
« Reply #19 on: December 23, 2015, 08:16:04 AM »
Were you a farmer in a past life?  The things you're doing are the things we used to do - come up with "extra time" to make things to help your days go smoother and faster.  You're spot on thinking this way.  A day or two fabbing equals many years of reduced labor when working.  It's a no brainer.  I like the way you think... I wish I was a bit smarter and able to think outside the box more.  I also need to utilize this wonderful forum more when I need help thinking on something.  The guys, you included, around here are phenomenally smart.  I often feel very fortunate for coming across this place a while back.  I think Jeff's idea about starting this forum and doing all that he does has changed more lives for the better than he will ever know.  I know I was a lurker and reader for a good year before I joined!  Keep on keeping on!
Reduced Tail Swing/Zero Tail Swing Excavators in the Woods
Started by wfcjr on Forestry and Logging
Last post December 29, 2014, 11:16:12 PM
by Corley5
I called 911
Started by Sixacresand on General Board
Last post October 30, 2019, 12:34:44 AM
by ljohnsaw
What's it called????
Started by POSTON WIDEHEAD on General Woodworking
Last post December 10, 2013, 07:25:41 AM
by VT_Forestry
What are these called?
Started by Brian_Weekley on Timber Framing/Log construction
Last post March 30, 2015, 08:58:25 PM
by S.Hyland
