Author Topic: Homemade whole log debarker  (Read 4757 times)
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« on: December 28, 2015, 10:42:45 PM »
Any of you made a whole log debarker?  Pics be great
Boy, back in my day..
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: Homemade whole log debarker
« Reply #1 on: December 28, 2015, 11:07:40 PM »
 Here I thought I was going to see one !!  :D
   Marcel
Offline barbender
« Reply #2 on: December 28, 2015, 11:57:49 PM »
Me too, Marcel!
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #3 on: December 29, 2015, 12:02:56 AM »
Me too, Marcel!
I saw a Goat debark a whole log and that is the truth!  piston-smiley
I know paper mills have peelers. Can make a log slicker than a whistle. But I've never seen a homemade one.
Offline scully
  • Orange Mills Matter
« Reply #4 on: December 29, 2015, 06:25:18 AM »
That's a prety tall order but I think if I had the front half of an 8-N some old plow edges off them state snow plow trucks and a revolving door from one of them city stores I cuwd build one .......
I bleed orange  .
Offline 4x4American
    • Website Link
« Reply #5 on: December 29, 2015, 06:27:07 AM »
My friend is thinking about building one.  Using spinning chains.
Offline beenthere
« Reply #6 on: December 29, 2015, 07:01:20 AM »
Spinning chains ??  Maybe like a flail mower?
Which just might work, if one can control the roll and flow of the log along with the rpm of the flail.
Offline 4x4American
    • Website Link
« Reply #7 on: December 29, 2015, 07:06:20 AM »
Yea I might help I was thinking to have a troth with a a dual chain turner for the log, and have one of those plow truck chains that whip the ground in front of tire to break up ice, powered by a hydraulic motor, mounted on a rail that goes back and forth via a chain system, and a diesel engine powering the whole setup.
Offline sandsawmill14
  • love my job (most days)
« Reply #8 on: December 29, 2015, 07:17:04 AM »
i would think a rosser head setup would work better than  chains. you could probably use the same drum or what ever the chains are on and just replace the chains with homemade teeth or short spikes. we used to run one that was so old and patched up it could almost count as home made :o :D :D :D
Offline tmbrcruiser
« Reply #9 on: December 29, 2015, 07:45:55 AM »
I don't think chain flail would be simplest answer to debark a log. I am familiar with chain flails on chippers to remove bark and limbs during whole tree chipping. As you would expect during the winter the flail will remove a lot of small limbs and not so much bark. That being said, I am sure the design would be different so the results would be different.
Once you get sap in your veins, you will always have sawdust in your pockets.
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #10 on: December 29, 2015, 08:39:14 AM »
I suspect you could pick up a Morbark Debarker at a sawmill auction far cheaper than you could ever build one. I know from years of experience, that a log debarker is the most abused piece of equipment in a mill operation. They take a terrible beating. Its not something you can just throw together.  Remember, every single log is different from the next. large, small, crooked, hard, soft, bark comes off like chips or it comes off like binder twine.  I know far more people that have been hurt by a debarker than a sawmill. That is another consideration.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #11 on: December 29, 2015, 09:26:30 AM »
Years ago the manure spreader of choice around here was the chain type flail barrel spreader.  Just a round trailer body with a large opening on the right side and a large pipe in the top middle with many large chains.  Spin it up and the brown gold had nowhere to go but out the side.  They worked great but when you started losing chains they ended up in the field for the next machine to pick up (bad news) and it would start to self destruct from being off balance.  Now you see many of them converted to wood trailers with the classic round barrel bottom.  Find one used and complete and it'll be a heck of a start toward a chain type debarker.
It's gotta be easier to have a long floating arm that follows the log contours as the log is being turned like you see in some of the commercial mills.  Building the live table I think would be harder, for the feed and turning of the logs.
Offline york
« Reply #12 on: December 29, 2015, 09:36:49 AM »
Spinning chain,will not work too well,it will just drive the dirt deeper,ya want an rosser head set up and if you do find a used debarker,get ready to rebuild it.....
Albert
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #13 on: December 29, 2015, 09:38:51 AM »
You can buy mill hogs off ebay cheap That should last for a while.
That should be great for a home made unit.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #14 on: December 29, 2015, 10:01:24 AM »
I agree with Jeff. Unless you have a lot of high grade junk and a machine shop, it's almost certainly going to be cheaper to buy a used debarker. I've been thinking about debarkers a bit lately. Phase four or five of my sawmill operation will require one. Fortunately, I'm still on phase two. :D
Offline Percy
  • Resident trouble maker
« Reply #15 on: December 29, 2015, 12:08:01 PM »
« Reply #16 on: December 29, 2015, 12:27:42 PM »
something else to consider is speed a debarker has to be fast and do a good job or it will cost more than just sawing without it :)
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #17 on: December 29, 2015, 07:08:13 PM »
I saw a hydraulic debarker working in a pulp mill many years ago. It was a ring of high pressure water jets and the log passed through (at about the same speed as a bandsaw carriage). They ran the water and bark through a screen, fed the water to a settling tank, and then filtered it for re-use.
A few years ago a contractor wanted a funky handrail for a deck and stair combination. He found a small diameter Douglas-Fir that had a lot of sweep in two planes and he was going to build the deck and stairs to match :o. He came to me for advice on how to debark it.
I told him a drawknife would do it. He told me it was way to slow, so I suggested a pressure washer. He tried an 1800 PSI electric and all it did was clean the bark. Then he tried a 2400 PSI gas unit that his neighbour owned. That just cleaned the stuff that he missed the first time. I suggested he needed way more pressure than that (notice I let him tell me what wasn't working before I made the suggestion)
Finally he rented a 3200 PSI gas powered pressure washer and that did the job nicely. In fact, he said he had to work quickly or it would start to tear off the sapwood.
So ... could you make a log handler that would feed a log past a pressure washer?
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Gearbox
« Reply #18 on: December 29, 2015, 08:00:53 PM »
The one mill I have hauled to has a wheel that looks like a feed roll on a processer head . It is electric driven and set at some angle . The log turns and advances past the cutter wheel . seems to work well on 16 ft red & white pine .
Offline 4x4American
    • Website Link
« Reply #19 on: December 29, 2015, 08:55:32 PM »
Interesting....was that a steam unit?  It's definitely possible...but during the winter time I wouldn't be able to use it, and the ground where I am setting up is clay and doesn't need any more water!
Building a DIY Homemade debarker for my Woodmizer LT35HD
Started by MikeySP on Sawmills and Milling
Last post April 22, 2019, 04:01:06 PM
by MikeySP
anyone using a debarker?
Started by woodmills1 on Sawmills and Milling
Last post February 24, 2009, 08:15:57 AM
by MaddiesDad
LT 15 debarker
Started by Slab Slicer on Sawmills and Milling
Last post January 02, 2013, 08:51:32 PM
by Magicman
Debarker
Started by b.palmer on Sawmills and Milling
Last post April 20, 2019, 07:23:08 PM
by Magicman
