Author Topic: Key switch  (Read 920 times)
Offline Peter Drouin
    • A&P Saw mill LLC
Key switch
« on: January 14, 2016, 04:59:34 PM »
My key switch on the mill did work ok. One day the mill would not turn over. Had power to the starter. So I took off the starter off and the thing was toast. Called cat and for $400 got a new one. Had it on for 2 days and It cooked.
I did check to make sure the power would go off when I let go of the key when starting.
Went to my starter guy and got a new Bosch starter for $125. And he told me sometimes a key switch with the vibration might engage the starter when I'm cutting. :o
Put in a new switch and I hope I'm good. ::)
A&P saw Mill LLC.
License NH softwood grader.
Offline Ocklawahaboy
  • Learning as I go
Re: Key switch
« Reply #1 on: January 14, 2016, 06:23:33 PM »
I has a switch fuse in the crank position and could barely hear the starter turning while the engine was running.  Just a little different sound made me try to turn the engine off and, when I couldn't, yank the battery terminal off.  Thankfully, no apparent damage to the starter.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Key switch
« Reply #2 on: January 14, 2016, 06:49:11 PM »
Hopefully it was the switch, and it lasts you another 8 years.  $400 for a starter that is astronomical, that's why they call it the stealership!  :o
Boy, back in my day..
    • A&P Saw mill LLC
Re: Key switch
« Reply #3 on: January 14, 2016, 07:36:20 PM »
stealership :D :D :D :D :D :D :D :D :D But the Bosch is not as heavy as the Cat starter.
A&P saw Mill LLC.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Key switch
« Reply #4 on: January 14, 2016, 09:02:26 PM »
Never heard of that Peter, but I've made a note of it now.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Key switch
« Reply #5 on: January 14, 2016, 09:10:31 PM »
Ouch,  hopefully that will be the end of your woes.
Lt 40 hyd switch
Started by CMI80 on Sawmills and Milling
Last post December 24, 2017, 07:15:26 PM
by CMI80
lt-40 key switch
Started by jmouton on Sawmills and Milling
Last post September 17, 2019, 08:55:28 AM
by Magicman
Going to switch i think
Started by furltech on Chainsaws
Last post July 16, 2014, 02:48:43 PM
by goose63
Reversible switch
Started by jdtuttle on General Board
Last post February 02, 2010, 04:51:11 PM
by woodmills1
