Author Topic: Green timber outside treatments  (Read 1798 times)
Offline fishfighter
« on: January 21, 2016, 06:56:37 AM »
Looking for the best thing to treat outside timber frame posts and beams that will be exposed to the weather. All are green at this point, so what is the best way and treatments.
Thanks.
Online beenthere
Re: Green timber outside treatments
« Reply #1 on: January 21, 2016, 10:31:52 AM »
What is the species, and what is the exposure time?
Beams should not be exposed, whereas posts need limited exposure before drying off.
For limited short term exposure, there are deck treatments that will (to a limited extent) keep water from  soaking into the wood. A mix of mineral spirits with melted wax helps, but needs a fungicide to slow down mildew. Days gone by, Penta was a good addition to that mixture. As well, boiled linseed oil was added too.
Not sure what is "best".
Offline fishfighter
« Reply #2 on: January 21, 2016, 07:55:31 PM »
All oak. Exposer will be all the time. I was thinking heated linseed or cotton oil might help some.
Offline venice
« Reply #3 on: February 09, 2016, 02:00:29 PM »
If they where dry i'd say linseed oil would work ok. 2 to 3 applications and regular maintenance depending on exposure to the elements would do.
But i dont recommend treating green wood with anything that traps moisture. Any kind of oil or paint does...
Most likely your oak is developing cracks during the drying and seasonal changes anyways.
I would let them sit till they are dry enough to paint or oil. Sand off the grey that is going to develop over the years and oil them. It's oak afterall. Maybe some treatment against insects now if this could be a problem in your area.
venice
Offline fishfighter
« Reply #4 on: February 09, 2016, 05:28:42 PM »
Thanks. I glad I didn't oil them. Sure about the gray. It's happening inside my cabin build. Just knowing it's going to take a few years for those beams to dry, I'm going to leave them be.
Offline dhp3228
« Reply #5 on: February 13, 2016, 11:12:21 PM »
Is there a way to treat the bottoms of your post to keep them from attracting termites? I'm in East Texas using Pine. Just curious if there is a solution or some product that a person could concoct to soak the ends in?  Thanks for the help and I'm sorry if this take the original post in a different direction.
Online beenthere
« Reply #6 on: February 13, 2016, 11:45:28 PM »
I believe there are ground treatments, but we don't have temites up here so not familiar with present day treatments.
Suggest contacting your extension service or local yellow pages.. Or the local lumber yard should have that info on the tip of their tongue. ;)
Offline boldrum
« Reply #7 on: February 14, 2016, 04:24:00 AM »
Antifreeze 1gal, borax 4 cups, h20 2 gal. Note grind borax or it will tend to clog sprayer. Had a major insect and mold problem here in coastal SC. I spray everything going on stick in my woodshed including the sticks. I have not had any problems since starting this process. This solution is very toxic to animals but none of the roving cats or dogs seem to find it palatable. Nevertheless use caution.
Homemade bandmill.
Tractor fel David Brown 885, Kubota BX 2230, Stihl chainsaws. Truck, trailers, bunch of shop stuff.
Offline fishfighter
« Reply #8 on: February 14, 2016, 07:53:13 AM »
Would paint them with roofing tar all the way above ground contact. Also and some gravel at the bottom of each hole. Couple inches will do. That is so water will drain off the bottom.
timber treatments
Started by JD_Kid on Sawmills and Milling
Last post April 02, 2002, 09:10:43 PM
by JD_Kid
Does post and beam change the use of Green Oak timber, v true timber framing?
Started by MbfVA on Timber Framing/Log construction
Last post September 04, 2017, 09:36:55 PM
by Don P
Gas Treatments
Started by Raider Bill on General Board
Last post September 14, 2011, 04:35:00 PM
by Raider Bill
Ethanol treatments
Started by islandlogger on Chainsaws
Last post November 04, 2011, 10:55:30 PM
by John Mc
