Author Topic: Alternative to anchorseal?  (Read 18674 times)
Offline WLC
« on: February 22, 2016, 05:07:01 PM »
I need to come up with an alternative to anchorseal.  Commercially available or home made.  No one here in AK carries it.  Closest dealer is in BC Canada or Washington state.  I called the company today to see if I could order mfg direct and they said yes.  Sent me to someone else to do the order and the nice young lady said hold up a minute and let me check shipping before we proceed.  Yep, you guessed it.  Shipping costs as much as the product.  I can't pay almost $200 for a five gallon pail.  Shipping would be similar if ordered from WA state as well.  Not too sure I could get it from BC and I imagine shipping etc to be as much.
What are some alternatives?  If commercial it needs to be able to be sourced at Home Depot or Lowes.
Anyone have a suitable home made concoction?
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline beenthere
Re: Alternative to anchorseal?
« Reply #1 on: February 22, 2016, 05:31:28 PM »
What is it that you will be end coating?
Anchorseal isn't something that must be used... it will stop some end-checking on logs and lumber, but that loss to end checks must be weighed against the cost of end sealing. IMO
Offline landscraper
  • LT4H0DD47. Dyna SC14. Hudson Stake Sharpener.
« Reply #2 on: February 22, 2016, 06:55:34 PM »
I use W.R. Meadows 1300 Clear as an alternative to Anchorseal.  It is a wax emulsion that looks and acts the same as Anchorseal IMO.   Anchorseal costs $87 a bucket I think, Meadows 1300 is $32 to $35 (in the lower 48), and it is usually in stock at my local construction supply house, so no shipping.  It is a concrete sealer or curing compound.  Valley Block and Concrete in Wasilla mentions on their website that they sell concrete sealer.  If it is a stock item with them you could try using that.  If they don't have 1300 clear you could use 1600 series too, it is just 1300 with titanium dioxide tinting added, so it dries white instead of clear, it is $40 a bucket I think.  Same wax emulsion otherwise.  Neither 1300 or 1600 should be allowed to freeze according to the labeling.  Don't use any of the other Meadows sealers, they are acrylics or resins, not waxes and will not act the same.  Other manufactures make wax emulsion sealers too.
Firewood is energy independence on a personal scale.
Offline bkaimwood
  • Life's too short to sweat the small stuff
« Reply #3 on: February 22, 2016, 07:11:20 PM »
May sound silly, but did u price a drum, shipped? I don't know how much you could use, but think I might go for the drum next order...I could be wrong, and maybe the next size up is the big ag. sized cube...
bk
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #4 on: February 22, 2016, 07:23:12 PM »
In my milling career I sawed millions and millions of feet of lumber. Not one single board or one single log was end coated.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #5 on: February 22, 2016, 07:27:11 PM »
Lumber for farm use never gets sealed.
The only ends I seal are my table and bench slabs that will be air drying for a couple of years.
Offline bkaimwood
« Reply #6 on: February 22, 2016, 07:40:37 PM »
Interesting... I never used to end coat anything, half because of disorganization, the other half because of lack of knowledge... Since I tightened the reigns, and started applying anchorseal to everything, I can notice a significant difference in the minimalisation of end checks and even drying...
bk
Offline landscraper
« Reply #7 on: February 22, 2016, 07:43:13 PM »
My logs and lumber sit around a little longer then a production mill  :D, so if I have some decent hardwood that I have plans for I will end seal it so I don't lose the investment of my time.  All my turning blanks get sealed too, no fun turning cracked wood.  And at $32 for 5 gallons, it's not exactly a deal breaker.  5 gallons last me a year.  I don't worry about pine or fence boards or lowboy decking etc., just the better stuff that I am drying.
I bet the wood from the big mills gets on a tractor trailer and off to the furniture plant or whatever before the wood can even start drying.
I used to grind bark for a hardwood mill and I would watch them spray Anchorseal out of 55 gallon drums on all the lumber that came off the line close to the bark pile where I worked.  They also had water sprayers set up on all their log piles in the summertime.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #8 on: February 22, 2016, 07:49:40 PM »
A cheap and easy alternative to Anchorseal is any kind of roof coating thinned down enough with kerosene or diesel so you can more easily brush it on.  Asphalt based anything will work fine.  Whether it's the aluminized stuff or blackjack, it'll all work fine.  Actually, the aluminum mobile home roof coating is thin enough to paint on as-is in the bucket after some rugged stirring.  Any kind of old, unwanted paint will work.  Melted wax will work.  The idea is to slow down the evaporation out from the ends of the wood.  Heck, I bet you could even slather on some lard and it'll work!
I rarely endcoat my boards or logs.  Only thing I've coated recently was some large black cherry slabs I'll be using for counter tops eventually.  I used some over 10 year old Walmart spray paint.  No checks in 9 months or so and cherry likes to crack.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: February 22, 2016, 08:00:29 PM »
The ERC logs that I sawed Saturday had been painted with what looked to be latex house paint.  Completely unnecessary, especially with ERC.
Offline fishfighter
« Reply #10 on: February 22, 2016, 08:11:48 PM »
I had painted some of the first oak boards I sawed with some old varnish. Last time I checked the pile of lumber, there was no end checking at all on the ends.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #11 on: February 22, 2016, 08:46:33 PM »
Goto Lowes, Home depot, Sears, Walmart or what ever and buy the latex paint returns. (wrong colors or whatever)
They are very glad to get rid of it. Most of the time they will give it to you.
Most of the time they need to pay for disposel.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Larry
« Reply #12 on: February 22, 2016, 08:53:58 PM »
We had a large flooring mill.  They probably had 5 acres covered with stacks of stickered oak 10 foot tall.  Not a single board had end sealer on it.
I sometimes use Anchorseal on special logs but most get no attention.  An alternative is to cut your logs a little extra long.  When your ready to saw cut off the extra.  Put the lumber on sticks with a small overhang on the ends.  That end stick will stop most checks.  When later processing I usually waste a bit off the end of each board just to insure I don't have a snipe from the jointer/planer.
I have used a coating called Silver Dollar.  Its a fibered aluminum roof coating paint for mobile homes.    Something similar should be available in your location.  Don't use Black Jack or roofing tar....the blade drags the tar through the cut.  What a mess.  Try the Silver Dollar on a test log first, as it has been years since I used it.
I don't think paint does much good.  Just not thick enough.  In fact when I do use Anchorseal I'll put on two coats.
A neighbor walnut mill heats a 55 gallon drum with paraffin in the bottom quarter.  All there gunstock blanks are dipped immediately after sawing.  I use something similar for lathe turning blocks.
Offline sawwood
« Reply #13 on: February 22, 2016, 08:59:52 PM »
We have used drive way sealer we get at Lowes. It was $15.00 for a 5 gal bucket and you need to mix it
up each time. Also keep it from freezing.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline Ox
« Reply #14 on: February 22, 2016, 09:51:26 PM »
I'm lovin' all these cheap ideas from real world experience.  "Country boys can survive" and all that.  It's a beautiful thing.
Offline ljohnsaw
« Reply #15 on: February 22, 2016, 10:26:03 PM »
Not out here!  I used to buy mis-mix light colors to paint my workshop to brighten it up.  I could get gallons for $1.00 and 5 gallon tubs for $4.00.  Now that paint is $20+ per gallon new, they charge $5.00/gal mis-mixed! :o
John Sawicky
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #16 on: February 22, 2016, 10:49:09 PM »
It's also $5.00 here.
I use the mis-matched red for property lines.
Offline Kbeitz
    • My Hobbies
« Reply #17 on: February 23, 2016, 04:07:32 AM »
Ny last batch cost me $20.00 for 15 gal and a bunch of little cans extra for free.
I also get free paint from the auto paint shops. But I dont think that would work good for sealing wood.
Offline dutchman
  • Sawyer SW PA TimberHarvester 30HT
« Reply #18 on: February 23, 2016, 08:42:06 AM »
When I worked at a circle mill they would use boiled linseed oil with
parafin melted into it.
Used a paint can 3/4 full (linseed)  add 1 piece of wax heat till melted.
Once mixed it will stay for weeks.
Only used on high grade logs.
Offline WLC
« Reply #19 on: February 23, 2016, 08:38:56 PM »
Thanks for the replies and suggestions.  Guess I'll go to Home depot and raid the mistint section for a gallon or two.  Our birch are real bad about end checking and thought I'd try anchorseal to slow that down along with sealing a few of my bowl blanks destined for the lathe.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Search for Anchorseal Alternative
Started by YellowHammer on Drying and Processing
Last post May 11, 2019, 07:00:17 AM
by YellowHammer
anchorseal
Started by xlogger on Drying and Processing
Last post February 13, 2019, 08:49:00 AM
by wisconsitom
Anchorseal or Anchorseal 2?
Started by Brad_bb on Sawmills and Milling
Last post April 08, 2017, 09:14:42 PM
by flatrock58
Anchorseal on Red Elm
Started by ironman123 on Drying and Processing
Last post December 18, 2015, 06:56:43 PM
by ironman123
