Author Topic: Alternative to anchorseal?  (Read 18121 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Alternative to anchorseal?
« Reply #20 on: February 23, 2016, 09:03:59 PM »
Thanks for the replies and suggestions.  Guess I'll go to Home depot and raid the mistint section for a gallon or two.  Our birch are real bad about end checking and thought I'd try anchorseal to slow that down along with sealing a few of my bowl blanks destined for the lathe.
Try to look for one coat paint. It's thicker and works better. Other stuff might need two coats.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #21 on: February 23, 2016, 09:46:14 PM »
I wish I could afford to buy more boiled linseed oil than I have on hand.  It's so expensive nowadays.  It's so useful for so many different things.  My last project was making old fashioned oil cloth tarps from canvas drop cloths.  Thin the oil with paint thinner and spray on, then let dry.  It sheds water nicely.  But anything it touches gets wet underneath.
Offline lewis
  • the best tree is a stump
« Reply #22 on: February 24, 2016, 01:34:11 PM »
a guy had 2 drums of end wax and one was leaking,he told me he would give 20 gal if I would move it to another drum I cut the top off and used a can to xfer the wax, it was mixed with ammonia,there were no labels on  the drums so I don't know what kind it is,but it sure works good,dose anchor seal have ammonia in it?
Offline Ox
« Reply #23 on: February 24, 2016, 04:03:09 PM »
lewis - what's the purpose of the ammonia?  Is it used as a carrier which acts like a thinner and then evaporates away leaving behind the wax?
Offline lewis
« Reply #24 on: February 24, 2016, 05:10:06 PM »
that's what I assumed, it was almost as if the wax was dissolved in ammonia,I had to stir it as it had separated
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #25 on: February 24, 2016, 05:49:52 PM »
Most of my clients don't end coat their logs but a few do.  AnchorSeal, or similar products, are much preferred for a couple of reasons.  Primarily it is because of its ability to do the job, some paint doesn't seal very well, sealer's like Thompsons soak in but don't really seal the pores.
The tar-based products, driveway sealer or roof coating, make a mess, gum up the blade and leave stains on the milled surface.  :(
A big concern with opaque products like roof sealer or the paints, is that you can't read the grain of the log accurately, and you obscure things like blue stain in oaks or black stain in walnut.  :(
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline 21incher
« Reply #26 on: February 24, 2016, 07:04:59 PM »
I dont know if it was something that I did wrong while drying, but some of the first walnut I milled I put several coats of latex paint on to seal the ends and the wood dried without splitting open. But when I machined it there were fine cracks that developed that look like the fibers seperated, but didn't split apart and the wood would break real easy in first foot of a board. After that I stoped painting it and just let it split where it wants to and have no more surprises.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Delawhere Jack
  • I ought to know better.....
« Reply #27 on: February 24, 2016, 09:04:34 PM »
When I worked at a circle mill they would use boiled linseed oil with
parafin melted into it.
Used a paint can 3/4 full (linseed)  add 1 piece of wax heat till melted.
Once mixed it will stay for weeks.
Only used on high grade logs.
Had a client that sealed his logs in a similar fashion. He used paraffin wax melted down and thinned with mineral spirits. Very similar results to Anchorseal, and I could still see the growth rings when the log was on the mill.
Offline Ox
« Reply #28 on: February 25, 2016, 08:57:37 AM »
This is the classic recipe for Waxoil - a protectant for metal surfaces against corrosion.  I've never used it, but many people swear by it much like others swear by Fluid Film.  I'm in the latter group.
Offline Cazzhrdwd
« Reply #29 on: April 03, 2016, 06:34:03 PM »
I've had my first bout with Anchor Seal  and the stuff is great. I didn't like using paint as I ended up with slab wood that I sell with paint on the ends. Its much easier to paint the logs than boards.
For those who do end coat, I get a lot of waste while applying it with a 4" brush. Seems a sprayer would be better, do you guys have any ideas on a simple hand pump sprayer or is there a better way to apply it without all the waste dripping?
96 Woodmizer LT40Super  Woodmizer 5 head moulder
Offline OffGrid973
  • Off Grid
« Reply #30 on: April 03, 2016, 08:53:07 PM »
If you do not have an abundance of lumber such as walnut and cherry I would say Anchorseal is the perfect option.  I have focused on Slabs and thick pieces for making furniture and I like the moisture readings in the wood near the anchor sealed ends is similar to a puncture in the middle of the wood with my moisture meter.
I guess it depends how much material you have and sizes you are cutting, stocking, etc.  Also there is no chance I would let some of the options above hit my tools, Anchorseal I never had an issue with.
FYI - those small checks mean most likely the material was not dry enough, don't think it was the sealer that caused that.
Your Fellow Woodworker,
- Off Grid
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #31 on: April 04, 2016, 01:22:26 AM »
Latex paint doesn't work very well -- it tends to breathe, which is exactly what you don't want. I've seen some very nice birch logs ruined because the owner ignored everyone's advice and used latex paint on the ends.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline alanh
« Reply #32 on: April 04, 2016, 09:00:39 AM »
I read wax will work? my wife is in the soy candle business, always 10 gallons of soy wax hot and ready... I would only do the slabs that are drying for extended time...
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #33 on: April 04, 2016, 04:29:17 PM »
I have been melting bees' wax and applying with a chip brush.  It seals the ends well and before I get the ends coated several honey bees stop by to visit.  It also smells really good.
Caveman
Offline GeneWengert-WoodDoc
« Reply #34 on: April 05, 2016, 05:54:20 PM »
End coating is suppose to slow or stop the end of logs or lumber from drying.  If the ends dry faster than the rest of the lumber, they shrink and create stress that can result in end checks.  Some species shrink less than others, so low shrinkage means low stress.  Low stress means low benefit from end coating.
So, not all species need end coating.  However, for many species, like birch, oak, walnut, and maple, end coating means no end checks due to drying if the coating is put on thick enough, if the coating stops or greatly retards drying (latex paint often does not), and if the coating is applied before any checks occur.
The coating makes the lumber more useful to the ultimate user and means a log can be a few inches shorter, which means the next log up the tree is a bit larger is diameter, etc.
Maybe Anchorseal will let the OP be a sales outlet for AK.  That might save money.  I could always throw a 5 gal. Bucket in my RV when I come to AK.
Anchorseal works and so do some of the alternatives mentioned.  Anchorseal is easy to apply...spray or brush.  It is not flammable, compared to paraffin.  It can have antifreeze...many other products get very stiff when cold in AK compared to cold weather here in the South.  It is in water so has no harmful emissions as it cures.  Finally, it can be colored red to remind everyone about the great Univ of WI Badgers, and the Bulldogs of U of GA.  That should really help lumber sales.
Offline taw6243
    • Silverwood Sawmill
« Reply #35 on: April 06, 2016, 09:48:07 PM »
elastomeric roof coating $16/gal at menards it is white and thick will not let logs or boards crack
Tim
4500 hours on my 2004 LT40HDG28, CBN sharpener and auto setter, 25" woodmaster planer with 9'auto leveling bed and trac vac chip handling system, 1998 L3010 kubota, 2010 L3200 kubota Festool TS75 rail saw with 42", 75" and 106" rails.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #36 on: April 07, 2016, 08:37:28 AM »
This stuff is about $17 a gallon delivered (admittedly not everywhere)  and I heard it works great.
http://uccoatings.com/product/anchorseal-2-5gallon/
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline WLC
« Reply #37 on: April 08, 2016, 12:23:56 AM »
When and where are you coming to here in our great state? If it works out I might just take you up on your offer.
I like the idea of UGA red colored anything.  Went to school there many moons ago and worked at the Forestry Sciences Lab there on campus for about 10 years.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #38 on: April 08, 2016, 07:39:26 AM »
 :D :D
Offline jwlogdog
« Reply #39 on: September 15, 2019, 01:40:17 AM »
I have had heard that one gal. of wood glue mixed with one qt. of water is excellent alternative
Search for Anchorseal Alternative
Started by YellowHammer on Drying and Processing
Last post May 11, 2019, 07:00:17 AM
by YellowHammer
Anchorseal
Started by duaneb on Sawmills and Milling
Last post March 31, 2012, 01:28:14 PM
by Wallys World
Anchorseal on Red Elm
Started by ironman123 on Drying and Processing
Last post December 18, 2015, 06:56:43 PM
by ironman123
Anchorseal or Anchorseal 2?
Started by Brad_bb on Sawmills and Milling
Last post April 08, 2017, 09:14:42 PM
by flatrock58
