Author Topic: New Building Plans?  (Read 940 times)
Offline tacks Y
New Building Plans?
« on: March 06, 2016, 06:46:41 PM »
I am thinking of putting up a new building this summer, 24' wide 36' long. Thinking 8' overhangs on each side clear span no posts. 12 to 13' tall so I have room to put mill under one side. Is this a bad plan with a solid wall behind mill ( I know blowing saw dust again). Is a 8' overhang enough to mill under? Or is the wall behind the mill  going to make to much work moving wood? I see some of you with free standing roofs, so access to both sides. Ideas? Thanks Tom
Offline bkaimwood
  • Life's too short to sweat the small stuff
Re: New Building Plans?
« Reply #1 on: March 06, 2016, 07:02:42 PM »
Sounds like a great project... But, if you want to protect the mill in most weather, 8 foot isn't enough, even with 8 foot walls... Taller wallsmean more room for precipitation to angle itself in there... I think anything under 12' wide is not worth considering... My barn wall height is 12', open on the front end, and it commonly precipitates in 8 foot or more...in bad storms, 15-20 foot...the height is the killer...what other options or ideas do u have?...
bk
Offline tacks Y
« Reply #2 on: March 06, 2016, 10:14:41 PM »
The height under mill would be 8-9 feet tall just enough to clear mill. Just thinking I would need a least 3' on the wall side or will this still be to tight? Thinking 12-13' walls 4-12 pitch so I can not go to wide with out running out of height and strength to make it with out posts. I need another tractor shed any ways so this would cover the mill also. Maybe kiln on other 36' wall. The weather comes from the other direction so that would help.
Offline bkaimwood
« Reply #3 on: March 07, 2016, 05:57:42 AM »
Good deal with the "weather" direction, that will help ALOT. I have about 3-4 feet between my mill and the inner wall...its plenty of room as long as you keep your area clean...I do struggle with that a bit, especially when production sawing. You plan sounds much like mine. I think I'll be going out 16 feet or so, but committing to going in the ground with posts on the outside of the "lean to". I wish it was simpler, with less work and $$$, but never seems to be...
bk
Offline tacks Y
« Reply #4 on: March 07, 2016, 07:16:29 AM »
That is the problem trying to keep the same roof line and still have the height I need.
Building Plans
Started by craigc on Timber Framing/Log construction
Last post December 02, 2012, 10:03:32 AM
by Jim_Rogers
Online Building Plans
Started by Mark M on Timber Framing/Log construction
Last post July 04, 2003, 04:29:00 AM
by Norm
Plans for putting my Woodmizer in a building.
Started by Northmizer-10 on Sawmills and Milling
Last post June 29, 2010, 09:49:09 AM
by Meadows Miller
What style is this? Where to look for stock building plans?
Started by Brad_bb on General Board
Last post May 10, 2019, 08:12:00 PM
by WLC
