I bought a shaper now what
Started by yukon cornelius, March 22, 2016, 02:14:18 AM
yukon cornelius
I found a craftsman 2 HP shaper at an auction for under $25. I want to tongue and groove or glue joint 2 inch material. My plan is 2 rabet bits 1\2" and 2 spacers 1\2". I plan to alternate spacer rabet spacer rabet. That setup will run me about $50. Then after a while invest in more sets for other things. You think it will work?
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Ljohnsaw
I have the same dilemma.  I bought an old Delta/Rockwell shaper and plan to use it for 2" stock T&G.  There just are no sets for T&G that big and I'm thinking I need to to the same thing.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
yukon cornelius
I found a few things from my shopsmith that will work on this shaper. The jointer head makes me think I could get molder knives for it. I fired it up today and it works great.I think it was good score. Now i need to get those other cutters ordered.
hackberry jake
Look into "Euro block" cutter heads. I have three of them I like them so much. The head itself will be a little over $100, but the knives are only $13 or $14 a set with $1 shipping from routerbitworld. You can't beat that as far as cost per profile. And they actually do have a 2" tongue and groove set. The 40mm knives are the standard, but most heads take 50mm knives as well (almost 2"). Being a smaller shaper, you'll probably want the small aluminum head. Around 88mm I think. Amana profile pro, and cmt universal shaper cutterhead. I think others sell them as well. Just stay away from the woodline set. I sent mine back, as it was poorly machined garbage.
Jim_Rogers
Well you could "read the book"... if you never have you could find and read the Shaper Handbook.
I read it and I learned a lot about how to use a shaper from it.
Jim Rogers
Ljohnsaw
Wow, I really like the design of the Euro block cutters.  The only problem is the size - they have a 30mm spindle hole!  My lowly Rockwell is only 1/2".  Right now has a 1/2 hp but was planning on putting 1hp on it.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
yukon cornelius
I will check out the euroblock. I also have the 1/2" shaft. This brings another question. Grizzly has, I think they called them T block spacers. They looked like adapters for cutters with larger shaft sizes. Is that what they are for?  Jim, I think that book is what I need.
Just Me
 That is what they are for but...... Be advised, that is a small light shaper, and just because you can find bushings to make a cutter fit does not mean it should run on that machine. Shaper accidents are ugly. The book suggested could be aquired from the local library, but read it either way if you don't have an old hand to show you the ropes.
tule peak timber
Yukon, If you send me your address-I'll send you my copy of the Shaper Handbook. Rob
yukon cornelius
The only thing I can actually think of using it for is the big tongue and groove and possibly finger joints. Rob,  I may take you up and borrow that book. I will check the library first so you are not without it.
I am very surprised the cutters are not keyed or locked on other than compression from the nut. If I get time I will get a picof it tomorrow. It is in the shop in the middle of the floor awaiting a spot. It has a cove cutter on it. A slight tightening of the drive pulley and it runs smooth. $27 well spent for this machine.
hackberry jake
Quote from: ljohnsaw on March 23, 2016, 08:29:37 PM
They have 3/4" cutterhead, 1" heads, and 1.25" heads. I have two 1.25" heads and one small 3/4" head. T-bushings are what the adapters are called. I use them all the time to bush 1.25" cutters on my 1" spindle shapers. Bushing up a 1/2" spindle to use 3/4" cutters is pretty common. Most companies throw in a set of 1/2" bushings with 3/4" cutters. The 1/2" spindle would probably be too small for a Euro block though. 1/2" shaper cutters are usually pretty inexpensive though.
Here is an example
http://www.amazon.com/Amana-61068-ALUMINUM-SHAPER-68MM/dp/B000P4QJXS
Ljohnsaw
Hackberry,
Yes, but what I was hoping, maybe unrealistically, is to be able to do a 2" T&G (in one pass) on my little shaper.  I suppose I could cut the "tongue" in 2 passes, the groove in one.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
hackberry jake
That would be a lot of material to remove in one pass. It also depends on how deep you want the tongue and groove I suppose.
Ljohnsaw
I was thinking about those Euro blocks - with that guard profile, they would only remove about 1/8" per pass?  So it would take multiple passes no matter what you were cutting, no matter how much power you had.
Cutting full 2" stock, I'm thinking I need about 3/8" deep minimum groove/tongue for my planking that will be up to 8" wide.  I know my little shaper could do that if I were only removing 1/2" to 5/8" wide cuts in pine.  So, one 5/8" pass removes the bottom, second 5/8" pass removes the top, exposing the tongue.  On the other side, one 1/2" to cut the groove.  The groove would be slightly deeper and wider than the tongue.  Its just that it would be close to 2,700 linear feet :-\
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Just Me
Quote from: ljohnsaw on March 26, 2016, 12:23:31 PM
That is not what those do. They will only allow so much to be cut PER REVOLUTION. You can still take take a full pass if you machine will allow, but what it does is does is stops the wood from diving into the cutter in the case of a catch. On the old style cutters without limiters really bad things could happen, like a piece getting sucked right in in a catch situation so fast you could not get your hands out of the way fast enough. European cutters are rated for hand or power feed for this reason.
Not sure if a Euro block will work either, but if it will you will want to keep your feed rate down to keep stress to a minimum. Slightly faster than when it starts to burn.
If you buy one get aluminum, and if offered in different diameters get the smallest diameter. You only have a half inch spindle so you want to keep the forces down as much as possible. Think leverage. The farther away from a spindle a cutter is the more force on the spindle. Roughly twice the cutter size puts four time the force on the spindle.
Machines like Hackleberry's Oliver have a lot of mass and heavy spindles. Not sure what his weighs, but my Unitronix weighs over 3000 pounds. And there is a label on mine that warns about using too much cutter without a spindle support. It says, "Use of spindle extension without spindle support can result in Death!" Seriously, thats what it says.
Make sure you have enough space under the nut for the size cutter you order. That would be the unthreaded part of the spindle. when you bolt on a cutterhead, make sure it is all the way to the bottom of the spindle, no spacers under the cutter. You will see stacks of cutters on commercial machines, but you can not do that with a light duty machine.
yukon cornelius
Do you guys think I am safe with the two 1\2"  rabets at a depth of 1\2" one pass? 2 HP machine 1\2" spindle
hackberry jake
What is the diameter of the cutters? You'll probably be fine with a slow feedrate.
yukon cornelius
2" diameter. From grizzly. Does a larger diameter effect the power of the machine? It would make sense if it does. I really never considered the diameter.
Ljohnsaw
It affects the power to some degree but more importantly, it increases the stress dramatically on the spindle.  We need to be careful with our lowly 1/2" spindles.  We can't compete with the big boys! ;)
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
ozarkgem
Quote from: yukon cornelius on March 23, 2016, 11:07:36 PM
There is a professional woodworking store just off the sq in Springfield. I can't remember the name of the place but they have all kinds of shaper bits there. Good quality. They are the Powermatic dealer also.
Larry
That would be Ballew Saw and Tool.  They do carry the full Amana line along with Freeborn, and LRH $$$$.
yukon cornelius
Thanks Jim and Larry. It would be good to check them out. I like to find new places to go look around.
Ozarkgem, off the subject bit I forgot to show you the shingle attachment while you were here. If you are back this way come by and I will get it out for you to look at.
ozarkgem
Quote from: yukon cornelius on March 27, 2016, 10:58:41 PM
That will be good. Things were a little busy that day. I want to stop a Trumans also. I will give you a call.
Just Me
Quote from: Larry on March 27, 2016, 09:36:23 PM
I have been buying from Ballew for must be 25 years, good company. Holbrens is another one I have good service from, have an order in right now.
Amana cutters are an awesome deal. I have been buying their insert cutters, and they are all perfect at a very reasonable price.
hackberry jake
Don't let spindle size be your only consideration when trying to decide how big of cutter you can spin safely. You also need to consider how rigid your spindle is. I have two shapers that take interchangeable spindles. They both have a 3/4" and a 1" spindle I can swap between. But I wouldn't consider spinning an 8" cutter on either one, even with the 1" spindle installed. I have a powermatic that has a solid 1" spindle that I might spin larger cutters on from time to time, but even the powermatic isnt very heavy built. The Oliver is the only shaper I would consistently spin cutters like this on. And if someone wanted to stack multiple cutters like this, they would likely need a shaper that's more robust than my Oliver. I believe Larry has one that would handle it.
