Dynamic Green Products Inc.
Author Topic: Timberjack Serial Number  (Read 1963 times)
Offline pinehillstacker
« on: March 25, 2016, 02:58:03 PM »
Howdy all,
I just bought a TJ 208GS, and I am trying to get service and operators manuals for it from John Deere's website.  Is there a way to decode the serial number to get the year?  The serial # is 784073.  When I bought it, the owner told me it was a 1980; I just want to double check before I fork over the cash for the manuals.
Thanks, Si.
Timberking 1400
Timberjack 208
Husqvarna 372
Offline bushmechanic
  • Someone else has it worse than you.
Re: Timberjack Serial Number
« Reply #1 on: March 25, 2016, 05:40:59 PM »
  Serial numbers are complicated on Timberjacks. The G stands for Gm engine and the S stands for standard transmission. I would guess that you machine is a D series Timberjack. Hope this helps but if not another member called neilo is knowledgeable with those old "jacks".
Offline Neilo
« Reply #2 on: March 26, 2016, 02:27:30 AM »
It is a 1976 machine. I think most of the manuals are by serial number, not just year.
As bushmechanic said, it is a D series.
« Reply #3 on: March 26, 2016, 09:48:50 AM »
Thank you much, that helps alot.
Timberking 1400
Timberjack 208
Husqvarna 372
Offline Jameso
« Reply #4 on: March 26, 2016, 07:17:44 PM »
The one I am fixing up has on it, (Timberland ~Ellicott)
Limited. This number 1063.
Model 205 H R
Serial 654541
Any idea what year? I thought 65.
It has a ford industrial gas 3.9
Offline larry1
  • TJ Forever
« Reply #5 on: April 04, 2016, 09:21:16 PM »
That was the first TJ  that I operated as a kid . They were good skidders in their day with plenty of power . When ours blew up , when swaped the engine for a 6 cyl international  and extended the frame 2 feet . She pulled even better . You are probably right about the year of yours .
Offline singh
« Reply #6 on: July 07, 2020, 04:16:27 PM »
I have a timberjack 450C serial no CB 4806 I want to know what year it is  ???
Regards
Singh
Where can I find the serial number on a Timberjack skidder?
Started by Oliver05262 on Forestry and Logging
Last post June 02, 2014, 07:52:22 PM
by tj240
Timberjack 208D serial number with plate missing
Started by MEFor3470 on Forestry and Logging
Last post November 14, 2012, 10:19:54 PM
by thecfarm
Stihl Model Number from the Serial Number
Started by johndrew98 on Ask The Forester
Last post August 12, 2019, 09:35:45 AM
by LeeB
WM serial number
Started by cpdunit1 on Sawmills and Milling
Last post April 15, 2012, 11:31:03 PM
by MartyParsons
