Author Topic: WM LT300 Tapered Lumber side to side  (Read 862 times)
Offline MIsawyer
« on: March 29, 2016, 03:17:01 PM »
Im running an LT300 that has been showing taper on the boards side to side but not end to end.  Band is level to the rails.  Any ideas?
Offline Joey Grimes
  • Quality is remembered long after price
Re: WM LT300 Tapered Lumber side to side
« Reply #1 on: March 29, 2016, 03:38:07 PM »
Check your side supports for square it may be from over clamping
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Offline esteadle
    • Steadwood Forest Products
« Reply #2 on: March 29, 2016, 04:00:31 PM »
Do you mean that the thickness is changing over the length of the board?
Or is the width changing over the length of the board?
If the latter, how do you edge the boards?
Also, is this for a mill set up to be stationary, or are you moving your mill from place to place?
Timber Harvester 30HT26 (setworks, hydraulic) Stihl 880 (36" bar).
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: March 29, 2016, 04:22:54 PM »
Sounds like the boards are a different thickness, one side vs the other side, not lengthwise.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
« Reply #4 on: March 30, 2016, 03:06:45 AM »
as mentioned, check the side supports are square (or a fraction leaning in) and also the head should be not level with the bed, but the outside should be slightly raised.
when it hits the wood and 'bites in' the head sinks in and levels out a little. 1/8th of an inch i think? or 1.5mm give or take for us metric people  :D
im pretty sure the WM industrials are the same as the portables and thats the case with them.
I often knock my back supports over and have to watch making a trapezium and not a square cant..
Doesnt matter so much for taking boards off after the first one though.
Cheers
Justin
Gear I run;
Woodmizer LT40 Super, Treefarmer C4D, CAT 528 swinging grapple, 10ton wheel loader.
Woodmizer LT15 Idle side rail scraped by idle side vertical mast
Started by Hunter1000 on Sawmills and Milling
Last post March 27, 2016, 07:46:33 PM
by thecfarm
recovering side lumber
Started by Dave H. on Sawmills and Milling
Last post February 17, 2016, 09:48:18 PM
by Jeff
Side Lumber Markets
Started by Paul_H on Sawmills and Milling
Last post August 05, 2002, 09:03:23 PM
by Tom
Sawmilling & Selling Lumber on the Side - WoodMizer
Started by jameson.p.g on Sawmills and Milling
Last post March 22, 2019, 05:02:57 PM
by jameson.p.g
