Author Topic: Overhead Cable for Hydraulic Hoses  (Read 1522 times)
Offline Rougespear
  • Salmon Arm, British Columbia
« on: April 04, 2016, 11:48:18 AM »
Hi all, just looking for some ideas and points for getting the hydraulic hoses from my mill deck to the moving saw carriage.  I have settled on an overhead cable system where I can hang the hydraulic hose up near the level of the top of the carriage and it coils/un-coils as the carriage moves back and forth along the mill deck.  I am only hanging a pair of 3/8" hydraulic hoses so not a hung load.
I am unsure how far to let the cable hang, how to attach it to the cable so it slides (little rollers maybe?), whether I should loop the cable or just let it droop down, or how much slack the hose should have in it relative to the length of travel (for example: 2' more the the total length of travel)?  I have a 25' cutting deck, and I'm assuming the hose should hang about 18" down between each attachment point... so that would make about 16-17 attachments?
Any thoughts, pictures, recommendations, and pointers will be greatly appreciated!  Thanks.
Custom built Cook's-style hydraulic bandmill.
Offline Brad_S.
Re: Overhead Cable for Hydraulic Hoses
« Reply #1 on: April 04, 2016, 12:58:55 PM »
Google Timber Harvester sawmills: that is exactly how they did it. I can get you photos of mine if you need more info.
Here is a photo from my gallery which shows the cable when the carriage is all the way down the track. I think I have 5-6 attachments. I wouldn't go 16-17...they would catch each other or bunch up when at the short end.
u
Offline Rougespear
« Reply #2 on: April 04, 2016, 01:50:01 PM »
Close up and overall photos would be absolutely awesome!
Offline york
« Reply #3 on: April 04, 2016, 02:05:26 PM »
Hi,
Go on you tube and search for the TH mill in operation...
Albert
Offline DMcCoy
« Reply #4 on: April 04, 2016, 03:27:14 PM »
What you are talking about is called a hose trolley.
Farm-tek sells them for irrigation hose, maybe it would work.
http://www.farmtek.com/farm/supplies/ProductDisplay?catalogId=15052&storeId=10001&langId=-1&division=FarmTek&productId=22483
Offline 47sawdust
« Reply #5 on: April 04, 2016, 04:43:04 PM »
The Cooks HD32 series mill uses the same system as Timber Harvester.It looks like they have 4 or 5 attachments.
Mick
Offline Brad_S.
« Reply #6 on: April 04, 2016, 07:17:07 PM »
Forgive the quality, had to use phone camera and it's not the best.
Note only 5 hangers. The pushback bar mounted between the cable support pulley and the rollers/hangers is very important. Without it pushing, the rollers tilt and don't roll free which causes the whole thing to just bind up.
Offline killamplanes
  • one man band
« Reply #7 on: April 04, 2016, 09:05:58 PM »
   I have poles at each end of mill cable hookin between them old wooden rollers and some little steel rollers with string holding hydraulic line and wiring mine electric power. Hate to now how many miles those rollers got.
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
Offline Rougespear
« Reply #8 on: April 19, 2016, 11:44:49 PM »
Sorry for MY late reply... was out in the bush logging!  Thanks so much for all the input folks... sure does help.
Cheers
hydraulic hoses
Started by xlogger on General Board
Last post March 13, 2019, 02:40:53 AM
by pine
Do hydraulic hoses rupture with age?
Started by terrifictimbersllc on Sawmills and Milling
Last post January 11, 2012, 06:12:07 PM
by Corley5
Bigger Hydraulic Hoses on LT 40
Started by highleadtimber16 on Sawmills and Milling
Last post December 18, 2013, 01:01:12 PM
by Tee
Shopping for hydraulic hoses
Started by Brad_bb on General Board
Last post September 07, 2012, 03:11:33 AM
by Woodchuck53
