OldJarheads Milling Thread...
Started by OlJarhead, April 06, 2016, 02:06:53 PM
Remle
Quote from: OlJarhead on March 15, 2023, 06:39:15 PM
Quote from: beenthere on March 15, 2023, 06:34:19 PM
The spalted maple is likely going to be green, not dry when sawing the log.
Ahhh....not doing much maple etc I thought it was more like Blue Stain on pine (sits, bugs get at it, blue stain develops etc)...
I wouldn't say spalted maple is green, green IMHO means it was just recently harvested. IMHO splatting occurs after it has been laying around for a long time and the fiber structure has started to decay due to heavy moisture content or the tree died along time ago and has been standing dead. Maybe I am wrong and others can set me straight.
"green" is usually meant to be anything over the fiber saturation point (fsp). So laying on the ground for spalting would likely mean the wood in the log is still over that fsp.
But personal opinions do vary.. no problem there.
Spalting is a discoloration in the wood caused by fungi leaving dark dotted or lined patterns that some like for "art" wood.
OlJarhead
Sounds a lot like blue stain though usually pine doesn't stain until it's down, however, if attacked successfully by pine borers it will happen.  In this case it's fungus that is on the boring beetles 'teeth' and once they get through the bark the fungus begins to weaken the trees defense making it easier for the beetle to get in.
TimW
Quote from: OlJarhead on March 01, 2023, 09:36:59 PM
Hydraulics Issue - YouTube
ok, pushing with my fingers on the microswitch gives the sound I am talking about.
A little later I move one of the levers a bunch and it starts working so you can hear the difference. This, us the problem I'm having.
Sounds to me like the pump is cavitating and starting to die.
hugs,  Brandi
OlJarhead
Thanks for all the replies.
I dropped off the motor to the shop Friday and am awaiting their word on replacing it.  Also instructed them to make sure I got the old one back so I could rebuild it (I'm wondering if it was the brushes after all but with so few hours (660) you would think it wouldn't be that worn from what others have said.
You can see me running it here in this video (and see a Super run at the same time as well as my mill back in July - I smashed them together).
(57) Sawmill Hydraulics Maintenance -- Nope, that's not the problem! - YouTube
What's interesting is that it was about 10% slower even when running 'normally' than it was in July so who knows?
OlJarhead
Apparently replacing the motor solved my hydraulics issue.  Now I need to open up the old one and look at the blushes
barbender
 Awesome👍 It must be the brushes, but that is a premature failure. I do believe on my ol girl ('97) it calls for having the brushes inspected at 800 or 1000 hours.
 If you can rebuild your old motor, it's a great item to have a spare on the shelf anyhow.
OlJarhead
Thanks and those are my thoughts (too early for the brushes but having a spare motor will be good).
It will be interesting to tear it all down and see ;) and I plan to go pick up the mill (and the pay the price for having someone else check and pull the motor and replace for me while I was at my day job)...and then I will start some testing :D
chet
Seems most times I have a DC motor problem, it turns out to be a brush just hanging up in it's holder. It's just a matter of cleaning it up, and it's good ta go again.
Notice in the link that I provided in Reply #1896, two brushes were worn and two were still like new.  I only replaced the worn ones.  In the other motor that runs the exact same length of time, there was no wear on any of the 4 brushes.
SawyerTed
Yep, I had a time diagnosing a feed motor issue.  Turned out to be brushes at about 500 hrs.
barbender
I've experienced the same thing with my Super, Magic. One motor died, the brushes were completely gone. I finally got around to pulling the other one apart, and the brushes looked like new🤷 I looked both ways and put it back together 😊
OlJarhead
I'm convinced that's the issue!  I pick up the mill today!
OlJarhead
OK!  Hopefully today will be the final day of fixing the hydraulics.  The inline valve for the side supports and log turner is cracked and I need to replace it today then I should be able to run some tests and do the spring maintenance so I can mill up a maple I quartered with he CSM last fall.
Meanwhile, this might interest you all since it's probably the same story for many of us here.  Heck, most of you probably already remember much of this story since it played out here on FF from 2010 through 2016 and beyond :D  Much of it in this very thread!  So, here it is:
Paying off a Sawmill in 13 Months?! Here's How I Did It! - YouTube
OlJarhead
Ugh -- my back didn't let me get the last repair done yet :(  Just need to replace that one inline vavle which hopefully won't take much and then I should be back to 100% and ready to go cut up some maple.
I also need to tear down the old motor which I hope to do soon.  Since I didn't take it off and it's in the new motor box, I am hoping the tech marked it when it came off....which I hear is important.
OlJarhead
OK!  If the rain holds off and I can get the valve replaced today, I'll be milling up some maple tomorrow!  Woot!  Here's hoping!  8)
Meanwhile, this one was fun!
IT'S TOO BIG FOR THE SAWMILL! MASSIVE MAPLE! - YouTube
Peter Drouin
Brushes are the first thing I look at when I have a motor problem.
A&P saw Mill LLC.
License NH softwood grader.
doc henderson
When the sprayer is out of the frame, it does kinda look like you are goin potty on the log!   :o :o :o  :D :D
OlJarhead
lol that's what my wife kept say lol
.eanwhile I have more work to do!
barbender
That thing would not meet YH's log qualifications😁
OlJarhead
lol but it meets my customers 😉
Meanwhile after replacing the two-way valve and fixing that leak, I discovered the 2nd was also cracked!!!!!
OlJarhead
https://www.youtube.com/watch?v=snt2hNcNaz4
While I'm waiting on my new vavle...here's the last of the old homestead work :)
Now I really need to get the mill fixed!  Work is piling up so the new valve can't come soon enough!  I should be back to milling next weekend if it arrives before then.
Meanwhile I also ordered a new bar for the chainsaw (ruined the last one when the saw fell and was pinched when quartering up another big maple) as I'll need to do some saw work on the big sycamore logs I need to mill up.
Goo thing the next few jobs are all local :D
OlJarhead
Well, my new valve arrives Wednesday or at least FedEx says so...then I hope to get it installed Friday before we head off to get some work done at the cabin which should include falling some timber and getting it onto the sawmill :D  Sure hope I can finally get back to milling D Logs.
OlJarhead
OK!  With luck I'll get that valve replaced (it's in the worst spot!  The inside valve, guess I'm laying on the ground for this one!
Then I'm going to be doing some milling!  Woot!  8) and I have jobs piling up and I'm not even advertising!  Ugh. I hate working...that has to stop!
Meanwhile, here is the last of the video I did last year (and finally produced)...no sawmill, all CSM work but just to quarter up a big maple to get it ready for the saw -- which of course, had problems, then winter hit full force like nothing we'd had in 20 years and of course, I didn't fix the mill (over and over again) but finally I should be back to making sawdust with the mill this week!
Granberg Edging Mill & Husqvarna 572xp vs BIG Maple! - YouTube
OlJarhead
 8) 8) 8) Drum Roll Please!!!
dancing-jack The MILL IS FIXED!!!  Finally got the last sequencing valve in and no more leaks! :D  YeeHa!  Off to the cabin and some milling this week so I'll be putting it to the test and of course filming it for y'all -- hopefully no more cussing!  ::) ;D
