Author Topic: Makita 6401 kill switch  (Read 872 times)
Offline gunscrew
« on: April 07, 2016, 12:27:53 PM »
how do you replace the kill switch with least amount of tear down, do you use a blade screwdriver from out side to compress the tabs or do you have come from inside?
Offline Stihlowner
Re: Makita 6401 kill switch
« Reply #1 on: April 07, 2016, 05:29:56 PM »
Don't know about yours but many have rounded locks so they will come up out of the hole without having to unlock any tabs.
On my Homelite you can start it up with a butter knife put between the switch base and the plastic case of the saw.
I wish changing the air filter was that easy.
Offline gunscrew
« Reply #2 on: April 07, 2016, 09:45:12 PM »
thanks makes sense it comes out from outside, rather than taking the saw apart.
Offline dougand3
« Reply #3 on: April 07, 2016, 10:54:23 PM »
Never done a Makita but if you look at pic of switch - you could slide a thin 2 prong fork (or a thin, narrow putty knife) in to push 2 curved retaining tabs back as you wiggle switch out. Goggle above title and find a pic.
Offline gunscrew
« Reply #4 on: April 08, 2016, 11:29:45 AM »
 I 'm going to try the putty, butter knife thanks for the advice.
Offline gunscrew
« Reply #5 on: April 08, 2016, 03:41:59 PM »
ground a little butter knife to correct width tried pushing in and prying from the rear, no luck tried from front bingo!Thanks to those who replied.
Offline Stihlowner
« Reply #6 on: April 08, 2016, 05:37:09 PM »
That's a good thing!!!
Makita 6401
Started by gunscrew on Chainsaws
Last post December 19, 2015, 10:36:23 PM
by dougand3
Makita 6401 Question
Started by Cypressstump on Chainsaws
Last post June 02, 2012, 05:19:23 PM
by lumberjack48
Makita DCS 6401 with Big Bore Kit
Started by KC on Chainsaws
Last post July 30, 2009, 07:22:49 PM
by KC
question
Makita 6401 oiling very very well, mostly the clutch!
Started by shootingarts on Chainsaws
Last post January 20, 2014, 12:06:16 PM
by shootingarts
