Author Topic: Woodland Mills HM126 mod  (Read 3570 times)
Offline Napowan
« on: April 16, 2016, 06:13:41 PM »
Using 20v cordless drill to raise and lower cutting head.  Who knows.  May save me shoulder surgery one day!!!
There's never nothing to do.
Offline ozarkgem
  • age 65 yrs old
Re: Woodland Mills HM126 mod
« Reply #1 on: April 16, 2016, 06:23:45 PM »
if it works use it. I like things that are powered.
Offline goose63
« Reply #2 on: April 16, 2016, 06:33:59 PM »
And its a master force cordless drill I have fore master force tools and like them and your idea 8)
goose
thank you to all the vets
Offline Woodmonkey
  • I always need extra help.
« Reply #3 on: April 16, 2016, 07:00:41 PM »
Looks like I've found my first HM126 mod when it gets here next week.
Woodland Mills HM126, Kubota GST 4240 with grapple bucket, Ford 8N, Husqvarna 455 Rancher chainsaw.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: April 16, 2016, 08:14:12 PM »
It would not take much to hook up a electric wheel chair motor to that shaft...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline fishfighter
« Reply #5 on: April 16, 2016, 08:42:50 PM »
Give me some ideas Kbeitz. ;D Problem with that is having to mount a battery
Started my trailer build today for my 126.
Offline Kbeitz
    • My Hobbies
« Reply #6 on: April 16, 2016, 08:48:01 PM »
With the voltage of the wheelchair motors you could still use you drill batterys...
The wheelchair motors are almost the same as a drill motor.
I would buy an extra charger and take out the wire and guts.
Then you could just plug in your drill battery into the modified charger thats wired to the motor.
On the out side of the modified charger you could put a 3 way toggle switch.
Offline fishfighter
« Reply #7 on: April 17, 2016, 08:05:12 AM »
I like the way you think. ;D
In time, I am planning on adding hydraulics to my mill. I need help flipping  big logs and cants. :(
Offline Kbeitz
    • My Hobbies
« Reply #8 on: April 17, 2016, 08:44:05 AM »
An old engine lift makes for easy log rolling.
Offline fishfighter
« Reply #9 on: April 17, 2016, 07:29:37 PM »
I do have a backhoe, but it has been just so wet that I have to deal with so much mud. I started building a trailer for My 126. Stuff I had laying around. That way I can go to the log as needed.
Had an old axle that I pulled off an old trailer. Had to cut it to size to fit the new trailer. My welding skills are not the best, but I kind make two pieces of metal stick. ;D Besides that, I'm not suppose to weld. :D I did put a 12" piece of pipe thru the inside then I welded the axle up.
Woodland does have trailer plans for these mills. I do have one extension that puts the tracks at around 20'. The base of the trailer is 18'. When I add the tongue, I will make that removable. Don't need something to trip over. ;D
Offline ozarkgem
  • age 65 yrs old
« Reply #10 on: April 17, 2016, 08:38:18 PM »
what did you use for teeth on your backstops? Looks like the backstops from H#@&
Offline Kbeitz
    • My Hobbies
« Reply #11 on: April 17, 2016, 08:48:46 PM »
I have no idea what they was made for. I picked up 4 plates like that from the junkyard.
They have a welded seam of something as hard as carbide along both sides of each tooth.
It's very very hard to cut even with a cutoff grind wheel. I would never use them if I dint
have my blade guard stop on my mill. One hit with the blade on one of these would just
kill a blade.
Offline fishfighter
« Reply #12 on: April 18, 2016, 07:33:58 PM »
Got some more done on the trailer today. The way I have the axle, I'm not going to fix it in place till I get the mill on, then try it on the road. Will move it if I need to.
Got the tongue in, just need some more welding there. I will be able to remove it once I move the mill in place. There will be some pins like what goes on a trailer hitch to lock it in place.
The most I have to move my mill is about 3 miles to another place I own that is about 300 ac.
Offline JamieT
« Reply #13 on: May 05, 2016, 10:39:25 AM »
that drill mod is awesome!! will definitely be looking at doing that to mine!! thanks for sharing!!
Learned just about everything I know, from the greatest man ive ever known. My father! Everything else was self taught thru the school of HARD KNOCKS ;-)
Offline DeerMeadowFarm
« Reply #14 on: May 05, 2016, 11:12:23 AM »
Cool mod and nice work on the trailer!
Offline fishfighter
« Reply #15 on: May 05, 2016, 05:06:02 PM »
Well, she got her first run today. Success.  8) She is not only on a trailer, but now has power feed. 8)
Due to the fact that the controller will only work if everything hooked up, I added the second motor. After sawing a 6x6x13' sill with only one motor, that is all that is needed. In fact, I had to slow the speed down just a hair. ;D
I have a bunch more pictures of the build.
Offline Bruno of NH
« Reply #16 on: May 05, 2016, 05:25:23 PM »
Nice work on the power feed :)
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline fishfighter
« Reply #17 on: May 05, 2016, 05:30:53 PM »
Thanks. Planning a power toe board next. ;D That is going to be real easy to do now that I'm on a trailer. In fact, that open the door to do a lot with this little mill. ;D
Online btulloh
« Reply #18 on: May 05, 2016, 05:50:13 PM »
I'm following all this closely FF.  Good work.
HM126
Offline fishfighter
« Reply #19 on: May 05, 2016, 08:25:38 PM »
Forgot to add a picture were I mounted the batteries and the power pack for the motors. Really was the only place to mount it. :(
I will be going back and rewire it and put all wires in flex tubing.
New Woodland Mills HM126
Started by Napowan on Sawmills and Milling
Last post January 03, 2020, 03:28:54 PM
by btulloh
Started by jbjbuild on Woodland Mills
Last post January 21, 2018, 10:16:01 AM
by HOLTeam
Started by hech on Sawmills and Milling
Last post September 02, 2016, 08:30:27 PM
by Magicman
Woodland mills hm126
Started by 60lp on Woodland Mills
Last post December 22, 2013, 10:37:47 PM
by 60lp
