Please welcome new sponsor:
I have an LT28 with the crank handle feed. Would power feed be nice? Yes, but I do fine with the hand crank for my needs. I saw only for myself, and not for hire. I feel that I wouldn't like the push feed that some mills come with, seems it would be harder on the back after a day of sawing. While I haven't sawed a lot of lumber on mine yet, and am no expert by any means I will say that I don't think you will go wrong with a Woodmizer.
I'm in the same situation. I have been researching mills for the last few months and have decided on the Woodland mills HM130. The upgrade from the HM126. The tracks are the same according to the drawings already posted on the euro website. They gain the extra width by using a movable blade guide and adding stainless covers to the log bunks with additional stops a little wider than the adjustable ones. The four post frame should be a bit more ridged as well. The upgrade in horsepower is also a plus. I like the movable blade guide as the logs I have are smaller in diameter.I have a deposit on the HM130, I'm told they will start shipping next week. Its a little more than I wanted to spend originally but I think the engineering and thought put into the design is worth it. If you have a welder and the skills they even have the plans for a trailer already designed and posted on the website to download. All the engineering is already done for you, nice touch!
Roundhouse:You mention pine and maple. These are two species that turn blue internally in the heat of the summer. I would caution you to study up on this issue before harvesting any trees of these species.Gerald
First cut and you will be hooked, by end of day you willing be wishing for hydraulics.The Mills you are looking at will do the job. Personally I would not want to saw for someone else with out hydraulics. To much work for limited dollars. But for a hobby sawyer with just a few logs a year to saw any of them will work.
I got the price directly from Woodland Mills. They said the launch was suppose to be this week and delivery available after May 2. They have been helpful and will send you more information if you email them. The LT28 is a lot more mill and more than twice the price. At this point in life I doubt there is a new career in my future as a sawyer, however, investing in good equipment has its rewards. I only intend to saw for my own use and selected the mill to suit my projected need. If you intend to make it a side business your needs will exceed mine.
I can say that you would not be disappointed with any of the Woodmizer mills, the quality and ease of use is top notch. Based on the other mills you are considering, you should also look at the LT15. I purchased my LT15, just the base model, then added the power-feed and trailer package as funds allowed. I can mill upwards of 200bf an hour by myself, which I think is fairly good for a manual mill. The indexing wheel/gas-strut assist (for saw head height) and available power feed are my two favorite features of the LT15 and LT28 models. As to the hand crank which you asked about earlier, it is a decent system for a manual mill. The head on the WM mills is a lot heavier than some of the other brands, and while you can push it through the log, the crank makes it much easier. Generally you crank the head through the log, then pull it back with the handle. The handle also gives you the option to push the head if you so desire (which sometimes I'd do when I was just slicing boards off a narrow cant, ie easy going). As I mentioned earlier, I have since added power feed and never looked back. Not only is it less tiring, but you can be doing other things while the saw head is making the cut, like stack boards, etc. Good luck with your decision.
Started by 2StateTrigger on General Board
Started by Teaklover on Ask The Forester
Started by Mark M on General Board
Started by AllyCat on General Board
