Author Topic: Another great CraigsList find  (Read 12647 times)
Offline TimRB
Re: Another great CraigsList find
« Reply #60 on: May 27, 2020, 12:00:51 PM »
And this "wrench" that has Flo Control embossed - cast aluminum.  For taking apart a big valve?  Or maybe irrigation pipe/valves?
LINK REMOVED PLEASE READ POSTING RULES. EBAY AND CRAIGLIST ADS NOT ALLOWED>
Edit:  Just posted because it solved the mystery--have no interest in the item.
Tim
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #61 on: May 30, 2020, 01:58:18 PM »
John, I have one that looks almost identical to yours, but it's 4,000
I've had it since '97 or so, it's out of a motorhome also, and runs at 1800 rpm
I could run it all day on 5gal gas.
Mine's on the fritz now, it has a dual distributor and it's now defective.
When I got mine, it was mounted on a small trailer with 8 inch wheels.
But, it's still very heavy!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline ljohnsaw
« Reply #62 on: June 02, 2020, 04:45:18 PM »
After some digging through the junk stockpile and pondering some different options here is what I came up with.  At first, I was going to use the trans axle from a lawn tractor but it was too narrow.
   The rails are from a pallet rack (60" piece) cut in half.  The recess on the inside edge is to accept the frame the generator is mounted in.  The receiver hitch is mounted on the top of the rails - I had to change that as the actual generator was protruding out of the frame and hit it.  So I moved it to the bottom.  The axle is supported by a pillow block bearing just under the rail mounted to that cross piece.  With the fixed axle, it was hard to turn.  So I cut the axle in the middle and put a piece of 3/4" black pipe between the rails to keep the axle straight and supported.  I filled it with grease to keep it from rusting.  The pipe rotates with the axle when going straight.  The back "bumper" is a extra piece from my sawmill build.  I cut a short length off of it and that became the battery mount.
 I had this jack already made up, just had to shorten the bar so it is compact when staged for use or in storage.  The longer draw bar is for towing.
Here the battery is mounted, the battery cables were just the perfect length.  Hard to tell from this angle but I will mount another plate to accept a gas tank on the near side of the receiver bar.  I just need to pick up another lawn tractor to get a 2 or 3 gallon tank.  I will also put some bolts/washers over the frame to hold the generator frame to the trailer rails.  The idea is to be able to remove the generator from the trailer when I keep it in my basement after the cabin is done.  I left the 3" casters on the generator frame.
John Sawicky
SkyTrak 9038, Ford 545D FEL, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 42" capacity/32" cut Bandmill up to 54' long - using it all to build a timber frame cabin.
Offline ljohnsaw
« Reply #63 on: March 26, 2021, 12:03:00 PM »
Not a freebie, but at $130, a pretty good deal.  Some thoughts and questions:
The name plate is a little mangled but I can make out "The Colson Company", a serial number (154?), 6,000 pound rating and that it was built for a specific military contract.  The date of service is messed up.  Anyone heard of the Colson company?
After removing the rotted wood, you can more clearly see the frame damage in the back side rail.  It took a hit on the right side and bent the rail in and down above the tire.  I'll see if I somehow bend it back up.
 The wood was resting on the side rails made from some T shaped stock on its side.  Then this 1/4" flat bar was bolted on top flush with the outside metal.  I *think* the square nuts are welded to the botom of the T and the counter sunk screws are rusted in.  I gave the 18 of them a good dose of BlueCreeper - this will be the acid test!
 I also gave all the lug studs and the split rim bolts a good shot.
What do you call this tread design?  These tires have a max pressure of 125 PSI!  One tire is a normal looking street tread and max pressure of 80.  I should replace it as it does have a couple cracks/splits in the sidewall.  Hate to have it fail when under load.  It'd be good to have a spare handy when I'm up the hill working.
Looks like the deck was made from white oak and was coated with asphalt tar.  A little stinky and I don't think would make good fire wood (at least in the house!).
 Not like I need another project but I plan to clean it up and paint (have a can of yellow tractor paint), repack the bearings and maybe install (if not one somewhere) a zerk on the fifth wheel plate.  I also plan to attach a receiver to the hitch so I can slide in a normal 2" hitch on a draw bar.
I would like to replace the deck with white oak (Quercus lobata) that is in range at my cabin.  I've never really looked at the oak closely to determine what I have.  Also, in my range, up there is Oracle oak (X moreha), Canyon live oak (chrysolepis) and Blue oak (douglasii).  Would any of the 3 be a good substitute for white oak in terms of durability to the weather?
John Sawicky
Offline ljohnsaw
« Reply #64 on: June 23, 2021, 04:25:53 PM »
A minor update to my RV generator.  So it was starting and running great last year.  This spring, cranked for a bit and the battery died.  So jumped it.  Ran for a while but battery still dead.  Put a volt meter on it while running - 10.6v  Can't charge very well on that!  So, quick fix:
Its a generator, right?  Needs charging while it running, right?  So slap on a battery charger!  It may have been this way since before I got it for free but need to dig into the documents to see if it even does charge.  I'm thinking not as there is no "extra" wires in the battery harness except for a couple of quick disconnects.
John Sawicky
Offline breederman
  • getting by the best way I know how
« Reply #65 on: June 23, 2021, 06:45:37 PM »
I have a generator out of a motor home and have to use a charger in it too.
Together we got this !
Offline trimguy
« Reply #66 on: June 24, 2021, 12:29:25 PM »
Maybe the motor home was responsible for charging it. Just a thought, I dont know how they are set up.
Offline Tacotodd
  • To learn and help
« Reply #67 on: June 24, 2021, 01:26:38 PM »
Id be using the generator to charge it. Otherwise, you might have to start the MH for a charge JUST to be able to run the generator.
At least thats how ID do it. But thats maybe why Im not an engineer (makes to much sense).
Trying harder everyday.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #68 on: June 24, 2021, 01:35:17 PM »
The generator cranked off of the motorhome battery which was charged by the motorhome engine's alternator.  You can probably get by with a battery charger plugged into the generator.  At least it will be charging while the genny is running.  There is not normally a 12VDC output on the genny.
Offline 21incher
« Reply #69 on: June 24, 2021, 06:27:53 PM »
I had a big Winnebago motor home and the generator started  off the house batteries. When running it charged the batteries using a 120 to 12 volt inverter in the motor home.  The engine  would  also charge them when going down the road. Be sure  to check the Hertz on that generator as some older generators can require rpm adjustments to dial in 60 hz output for sensitive equipment. I put my big generac on a trailer like that.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline ljohnsaw
« Reply #70 on: June 25, 2021, 12:17:44 AM »
No sensitive equipment - just my drill and skilsaw.
MM, I did put a volt meter on the battery when the generator was running.  That little trickle charger was only showing 12.6 v so maybe it thought the battery was fully charged.  I need to do one more test but I think this charger is too smart.  It senses what the voltage is (6v or 12v) and what the charge state is to do a fast charge or trickle.  I think if I open the circuit to see what the charger can do, it will just turn off.
John Sawicky
CraigsList find
Started by ljohnsaw on General Board
Last post December 30, 2015, 01:25:25 PM
by ljohnsaw
Jeff's great find.
Started by Wildflower on General Board
Last post July 30, 2016, 06:10:10 PM
by POSTON WIDEHEAD
Scored a great find at an estate sale.
Started by DR_Buck on General Board
Last post January 25, 2015, 05:56:15 PM
by Magicman
great dump find...stupid people..
Started by zopi on General Board
Last post May 18, 2009, 04:05:59 PM
by zopi
