Author Topic: Has anyone milled "Girdled" trees?  (Read 1018 times)
Offline LaneC
  • Traveling Man
« on: May 20, 2016, 05:36:29 PM »
    I was curious to see if anyone has ever milled a "girdled" tree. From my research, a tree gets girdled and it takes it a couple of years to die. During the dying of the tree, it slowly and naturally dries. If anyone has done this, I was just wondering if it mills differently, If it is any better doing it this way (girdling) compared to felling and milling right away, or felling, left to dry for a year or so and then milling? Thanks for any replies.
Man makes plans and God smiles
Offline Larry
Re: Has anyone milled "Girdled" trees?
« Reply #1 on: May 20, 2016, 08:04:38 PM »
I did a TSI project on some woodland I owned.  One of the requirements was that I girdle all honey locust trees and spray with herbicide.  After the honey locust had been dead for a couple of years I felled all of the bigger ones and sawed the lumber.  Worked just fine but this is the only species I ever tried.  There was only slight degrade.
On a normal basis, I prefer to mill asap after a living tree is felled.  I think in general one gets the best lumber this way.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: May 20, 2016, 08:14:15 PM »
   Haven't milled any yet. Will be interested to see the results here. My grandfather used to work girdling cypress in Fla. When dead they would be felled and floated out at high water. That was why they wanted them dead and dry - to float better.
Offline gfadvm
  • Barely computer literate but anxious to learn
« Reply #3 on: May 20, 2016, 10:27:32 PM »
I haven't sawed girdled trees but I have found that standing dead elm and hackberry behave much better than green when being air dried.
Online pineywoods
« Reply #4 on: May 20, 2016, 10:33:11 PM »
Ive sawn a good bit of southern yellow pine that was effectively girdled by the pine bark beetle eating the cambium bark layer around the base of the tree, effectively girdling the tree. Cut as a standing dead tree, if you saw it soon after death, the wood is good. Magic Man has cut close to a million board feet of it.
Offline derhntr
  • Sawing lumber is addicting
« Reply #5 on: May 21, 2016, 07:24:24 AM »
Sawing dead white ash killed by EAB mills fine. Does tend to leave sap on blade. Lumber seems to be more stable than fresh green ash lumber.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: May 21, 2016, 08:38:14 AM »
Yup Pineywoods, that is what I was thinking as I read this thread.  After I finish sawing the ERC, I have 23 SYP trees to saw that were girdled by Pine Beetles.
Offline LaneC
  • Traveling Man
« Reply #7 on: May 21, 2016, 11:01:28 AM »
  Thanks for the replies Gents.
Offline garre1tt
« Reply #8 on: May 21, 2016, 12:53:08 PM »
I was just thinking about this last night as I was dropping another bug killed Grand Fir.  Maybe I should change the name of my operation to Last Chance Lumber.  Final chance for these trees to become lumber before fire wood.  Maybe a marketing slogan for sawmill manufactures.
There was a real bug infestation three summers ago.  Most would normally make it through but has record dry year last summer.  This spring most had needles turn orange when they came out of dormant.  May be a good thing.  Those that do heal give that surprise of a separated growth ring right in the best part of the log.  Hard to make good lumber from that.
Woodmizer LT 40, 1900 Linn Lumber Band mill, massey ferguson 245 tractor, Stihl 084,066,036,370,290,018
Past owner of WoodBug CSM, Alaskan CSM,1900 Linn Lumber Band mill, Lucus 6-18 Stihl 064, Stihl 084
The shortest "log" I've milled
Started by WoodenHead on Sawmills and Milling
Last post April 13, 2013, 03:38:41 PM
by hackberry jake
1- Twisted Sister or "Walnutz!" and 2- "Pre-Bent" or "Saw Mill Nightmare?
Started by MbfVA on Sawmills and Milling
Last post September 08, 2017, 12:33:17 PM
by MbfVA
Landowner in Florida: the question of "what are these trees worth"
Started by dbrooks on Forestry and Logging
Last post February 28, 2017, 10:03:46 PM
by ellmoe
Why do "old growth" trees produce better lumber?
Started by Mongo on General Board
Last post June 18, 2003, 08:57:21 AM
by Bibbyman
