Tally-I/O
Author Topic: Check out this old mill 1925  (Read 674 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« on: May 22, 2016, 09:48:14 AM »
Looks like the head is stationary and the whole carriage moves.
https://commons.wikimedia.org/wiki/File:Horizontal_bandsaw_mill_(Carpentry_and_Joinery,_1925).jpg
 Blade runs at 7,000 ft. per minute
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline 1-2 Tree
Re: Check out this old mill 1925
« Reply #1 on: May 22, 2016, 10:05:56 AM »
Man I would love to have one . Bet those blades would cost ! The foundry patterns would have been huge
I like the smell of saw dust in the mornings !I have a crescent wrench and I know how to use it ! The best hammer I have ever owned !
Offline Slingshot
« Reply #2 on: May 22, 2016, 10:37:21 AM »
   Only reasonable to think that is the way the first band mills would be built
as they already had the manufacturing process in place to push the log
through the blade. And then someone realized that you would only need
half as much track if you could push the blade through the log.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #3 on: May 22, 2016, 10:40:38 AM »
very cool indeed,  I love the stationary inverted castor wheels
Dan
Offline GeneWengert-WoodDoc
« Reply #4 on: May 22, 2016, 01:26:37 PM »
I have seen a similar mill in use.  The log is on a carriage.  The reason this is done, and that the saw does not move, is that the power is transferred via leather belts to the band wheel.  This has never been able to move, as the belt gets its power from a stationary shaft.  If the saw moves and the log is stationary, then the power (the drive motor) also has to move, so we would need a gas, diesel or electric motor moving and not leather drive belts.
Before Pulling Your Mill....Check and Re-Check!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 09, 2018, 01:44:17 AM
by Ianab
Logging in Louisiana swamp. 1925
Started by Ward Barnes on Forestry and Logging
Last post December 23, 2013, 09:02:17 PM
by Big timber little dozer
Check this mill out,,,,
Started by Danny_S on Sawmills and Milling
Last post June 01, 2004, 07:41:24 AM
by FeltzE
Check out this mill...
Started by Coon on Sawmills and Milling
Last post April 20, 2011, 02:17:52 AM
by backwoods sawyer
