Author Topic: Houston... We have a problem!  (Read 3373 times)
Offline timberlinetree
« on: June 10, 2016, 05:24:00 AM »
This space looking thing got fried and is obsolete. I dont think i can make one in the garage. At the moment this $12k lift is just scrap! :-\
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Houston... We have a problem!
« Reply #1 on: June 10, 2016, 09:02:34 AM »
Ouch!
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #2 on: June 10, 2016, 09:07:53 AM »
This is a nightmare in the making for many, as much as I like the technologie, it is so frightening to know that so small a peice can virtualy kill it.
  There's one of them on my mill and it scares me every time I think of it.  :-\
   Marcel
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #3 on: June 10, 2016, 10:07:00 AM »
This may be a silly question and I mean no disrespect, but did you check that little 10 amp fuse?
Offline never finished
« Reply #4 on: June 10, 2016, 09:48:05 PM »
 What I can't figure out is how stuff use to work with out such parts.
Offline ljohnsaw
« Reply #5 on: June 11, 2016, 01:59:08 AM »
That was kind of like "where's Waldo" :D  I guess I'm showing my age - I was looking for a glass fuse...  And I could not figure out how you could have read it.  I can barely read them when I have them in my hand twisting them around under a bright light!
John Sawicky
Offline Ox
« Reply #6 on: June 11, 2016, 08:43:06 AM »
I can see how fun that woulda been looking for a glass tube!  :D
So....is the little red 10 amp spade fuse OK?  I've brought things back from the dead just by changing one of these special little fuses.  If this doesn't fix it, there's gotta be a circuit board repair place somewhere.
Update:  There is.  I just did a quick google search and there's around 4 that pop up.  It's an option for you, at least.
Offline Den Socling
  • just wondering
« Reply #7 on: June 11, 2016, 12:54:13 PM »
Here is another thought. Those big old circuits made from hundreds of discreet devices can often be replaced now days with a cheap little PLC. For instance, my son took on an old sort line. The sort line was supposed to sort wood dimensions by length and put the pieces in the proper bin. It had an ancient computer and a lot of associated hardware. Garrett threw everything in the garbage and installed a cheap little PLC.
Online dgdrls
  • Learning the Art of Milling Logs
« Reply #8 on: June 11, 2016, 10:37:02 PM »
Do you know what fried it?
check the board carefully on both sides,  make certain the coating isn't failed/failing and flaking and check for exposed/broken circuit path(s).
Son and I repaired the board on his Ram truck, road salt was able to enter the box and was eroding a portion of the board,
caught it quick enough,  cleaned with pure alcohol and then sealed the exposed circuit with 100% silicone
Good luck with it,   did the little red fuse help?
D
« Reply #9 on: June 12, 2016, 07:45:33 AM »
Thanks for all the help! The fuse is ok( wish it kept this thing from smoking) and the original maker is going to try to make a new on up in Canada, meanwhile we sent it to NC. to a chip board fix it place. I'll be waiting like a chicken on eggs to see what happens next. Its tough to see the fried part in the front,the back is a different story.
This thing is really neat and I might just frame it.
Offline Ox
« Reply #10 on: June 12, 2016, 09:27:05 AM »
Yikes, now I can see it.  Looks like a few other places look "rusty" and were about ready to cook as well?  It sounds like you're getting things done, that's good.  Never good to sit on your hands and cry woe is me!  This is what made America great in the first place - movers and shakers.  Keep us posted, bud.
Offline grouch
  • I'm recyclable!
« Reply #11 on: June 13, 2016, 10:54:11 AM »
Looks like some more cooking has been going on, too. Turn the board so the "2309" silk-screened in the middle is upright, then look at the components to the right of that, one with 4 legs but otherwise looks like a power regulator and one that just looks like a black blob. Are those overheated or is it just image blur?
Find something to do that interests you.
Offline r.man
« Reply #12 on: June 13, 2016, 08:34:43 PM »
What is the board from?
Offline isawlogs
« Reply #13 on: June 15, 2016, 08:45:45 AM »
 How does one find a place to "fix" these things...   Maybe how does one word out the gooogle question. I have one here off my mill that could be sent out to be fixed and have as a spare.  :P
   Marcel
Offline Ox
« Reply #14 on: June 15, 2016, 10:28:03 AM »
I just googled "circuit board repair" and had several hits.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #15 on: June 15, 2016, 11:59:33 AM »
Replacing circuit boards on pool heaters and chlorine generators is the way to go, not worth trying to fix then cause something else is going bad on it in the next year or so. Parts aren't made to last anymore....
« Reply #16 on: June 17, 2016, 05:56:20 AM »
Thanks. Unfortunately the circuit board fix it place can't fix it. I am very thankful that this happened to us before we sold this so someone else didn't get stuck with a major problem. And I'm very thankful it didn't happen while I was up in the air. Its a 2002 Bill Max xlb 4725A.
Offline Ox
« Reply #17 on: June 17, 2016, 08:52:02 AM »
So what happens now?  Can that one place make you a new board?
Offline grouch
  • I'm recyclable!
« Reply #18 on: June 17, 2016, 11:05:41 AM »
Is the manufacturer still in business?
Is there a schematic for that circuit? Might be able to use discreet components and something like an arduino to substitute.
Offline 21incher
« Reply #19 on: June 17, 2016, 07:16:02 PM »
It has always amazed me how all electronic devices run on smoke. Once the smoke leaks out, it is all over. Can you at least get a schematic for the unit to see what it would take to create a new control scheme. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Houston we have a problem...
Started by oldsaw-addict on Chainsaws
Last post January 22, 2004, 10:48:08 AM
by Gus
Is this Cottonwood - Houston, TX
Started by Philmographer on Tree, Plant and Wood I.D.
Last post April 05, 2019, 10:53:26 PM
by KEC
Flying to Houston
Started by DbltreeBelgians on General Board
Last post February 03, 2020, 10:21:43 PM
by DbltreeBelgians
Dealers-Houston Area
Started by john_boylan on Sawmills and Milling
Last post October 12, 2006, 10:14:34 AM
by DanG
