Author Topic: post/plate/tie joint  (Read 844 times)
Offline shackbuilder
« on: June 21, 2016, 11:00:33 AM »
Anyone aware of a joint that brings the tie up to the top of the post with the top plate beam, without using a jowled post?  This is for a common rafter setup that will be step lapped into the plate.  I was going to have the tie come into the post 1' down from the shoulder with a wedged half-dovetail in a thru mortise, but the building is 24' wide, and i am worried about thrust stressing this joint and the post top tenons.  Roof pitch will be 12/12. Should i be worried, or is collar ties on every rafter set enough to eliminate the thrust.   Closest thing i have found is this, but as i see it, it jams me from including my 1' overhang on the rafters -  http://timberframehq.com/tie-beam-plate-tying-joint/
  Thanks for any thoughts on this.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: post/plate/tie joint
« Reply #1 on: June 21, 2016, 11:35:35 AM »
One solution is to add a sprocket onto the side of the rafter to give you the overhang;
Hope that helps.
Jim Rogers
Offline Roger Nair
« Reply #2 on: June 21, 2016, 11:55:22 AM »
To deal with the thrust issue, the simplest (to me) method is to avoid the collar related issues by having a post supported ridge, which will pickup one half of the roof load and place a substantial limit on thrust and ease stress on the tie joints.  Remember the thrust in a collar system is relentless and wood will deform and any weakness will be exposed in time.  A drive in the country will have on display many swaybacked, bulging buildings.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
« Reply #3 on: June 21, 2016, 12:23:40 PM »
Trying to keep the ridge open in a cupula area, so there will be two heavier rafter sets headered off to carry the three rafters in that area.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #4 on: June 21, 2016, 03:45:40 PM »
Three way joints are tough, and more so if you don't use a jowled post and even more so with high thrust loads. Could you use a purlin plate to pick up the rafters mid span?
Post to Plate joint
Started by bigshow on Timber Framing/Log construction
Last post June 05, 2007, 12:17:56 PM
by Jim_Rogers
Toughest post to plate joint?
Started by Satamax on Timber Framing/Log construction
Last post July 18, 2019, 03:28:23 AM
by Satamax
Tenon shoulder surface at post top to plate joint
Started by trouts2 on Timber Framing/Log construction
Last post September 18, 2018, 06:17:18 PM
by trouts2
Scarf Joint location in load bearing top plate
Started by Hackermatack on Timber Framing/Log construction
Last post January 15, 2016, 12:12:26 PM
by jimdad07
