Tally-I/O
Author Topic: governor throttle lever, pushing throttle instead of pulling  (Read 820 times)
Offline SCSawyer
  • If Your Not Sawing Your Wasting Time.
Anyone know why this is happening ?
Silas S. Roberts , Bluff Mtn. Timber
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: governor throttle lever, pushing throttle instead of pulling
« Reply #1 on: July 30, 2016, 03:13:19 PM »
I would say that it's made that way . You need to hook on different.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #2 on: July 31, 2016, 07:42:28 AM »
Spinning it the wrong way?  A couple small pulleys and a small cable might fix you right up...
Offline mburrow
« Reply #3 on: July 31, 2016, 09:23:05 AM »
here is the instructions for the Foley Universal Governor
http://www.foleyengines.com/resources/product-guides-forms-tags/hoofpierce-governor-instructional-guide
you will eventually need to know what engine you have more than likely it is a  Ford 4.9L (300CI) Inline 6 truck engine,
it could also be the The 200 or 250 cu. in. I-6 car engine. the car engines the intake manifold integral, cast with the head.
Woodmizer Kohler Command 25 Governor/Throttle Spring Configuration
Started by Pepe_Silvia on Sawmills and Milling
Last post November 15, 2019, 03:24:50 PM
by booman
WM Throttle Solenoid
Started by ncsawyer on Sawmills and Milling
Last post June 15, 2015, 09:42:35 PM
by ncsawyer
Remote throttle
Started by bandmiller2 on Sawmills and Milling
Last post November 01, 2008, 07:41:17 AM
by bandmiller2
441 throttle cable
Started by yogi on Chainsaws
Last post March 30, 2013, 02:03:34 AM
by yogi
