Bugs in white pine logs
Started by AnthonyW, August 26, 2016, 08:14:44 PM
AnthonyW
Is there anything that can be done to the white pine logs to discourage the pine borers? Other than sawing them faster/sooner (there are only so many days in the week). Can they be sprayed with something?
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
47sawdust
Probably not practical,but store them in a mill pond.I know what you mean as I've sawed pine that was past its prime.I don't like it but there is only so much a man can do.
Mick
Peter Drouin
Debark the logs when they come in.
A&P saw Mill LLC.
License NH softwood grader.
Chuck White
I agree, if you peel the logs, the beetles won't bother them.
Peel them and get them up off the ground and they'll last a lot longer (rot wise) too.  ;)
69bronco
3rd on peeling, they'll be backing off soon. Once it cools down a little.
hunz
I've tried insecticide with no luck, saw em quick, peel, or be prepared to say hello to "holy" lumber!
Dream as if you'll saw forever; saw as if you'll die today.
2006 Woodmizer LT40D51RA, Husqvarna 372xp, Takeuchi TL140
