Author Topic: Wood Boiler Wrap Around Circ Recommendation?  (Read 623 times)
Offline LegendsCreekFarm
« on: August 31, 2016, 08:44:36 PM »
I was wondering what you all use for your wrap around pump with your wood boiler?   I am finishing up my install tomorrow and I gotta run out to get a new wrap around pump as the one I was going to use was defective.
I just need a circ to move the hot water through the boiler and heat exchanger to keep the water hot in the boiler.  I know those ECM's are getting popular, but then there is the Taco 007 that I was told is standard. I am using 1" pipe and would like something reliable and I would consider a pump that I can control speed for energy savings.
What do you use and recommend?
Offline gspren
Re: Wood Boiler Wrap Around Circ Recommendation?
« Reply #1 on: September 02, 2016, 08:01:21 PM »
  I have never heard the term "Wrap Around" in referring to a circ pump, is it something special compared to a normal circ pump?
Offline Gearbox
« Reply #2 on: September 02, 2016, 09:15:15 PM »
007 will do very little lift if your boiler or pump is lower than the high point think about a bigger pump like a 011 .
« Reply #3 on: September 03, 2016, 08:55:54 AM »
I call it a wrap around pump because that is what Central Boiler called it.  Basically it just circulates the water between the heat exchanger and oil boiler.
I went with a 007 and its working great. Its next to the oil boiler, same height and all.  I am considering moving the 007 to one of my zones in that building and moving the Grundfos Alpha to the wrap around. I like the idea of having digital controls to send more hot water if I need it.
Offline garret
« Reply #4 on: September 04, 2016, 08:43:22 AM »
The wrap-around pump as it is referred simply circulates water between the plate heat exchanger and your indoor boiler system. You don't need to oversize this. Taco 007 or smaller will work just fine. I use a super brute grundfos pump and that is overkill going back to the 007.
E-Classic 2400 comfortably heating 4,200 sq.ft. and unlimited DHW, Off-grid, Photovoltaic-powered pumps in gloomy SW PA , 34 t splitter, numerous Husky chainsaws
Offline Holmes
  • 1840 house
« Reply #5 on: September 05, 2016, 09:26:10 PM »
Best solution is to go with manufacturers recommendations.
Think like a farmer.
could my wood boiler be hooked to the oil boiler backwards
Started by stumper on Firewood and Wood Heating
Last post February 08, 2019, 08:02:24 AM
by talldog
wood stove recommendation
Started by mrbrb on Firewood and Wood Heating
Last post February 19, 2016, 07:14:12 AM
by jargo432
Need small wood stove recommendation
Started by Brad_bb on Firewood and Wood Heating
Last post January 08, 2016, 09:35:27 AM
by beenthere
Recommendation on Wood Fireplace Manufacturer
Started by Hoss on Firewood and Wood Heating
Last post November 17, 2011, 01:16:02 PM
by Hoss
