another table
Started by tule peak timber, September 15, 2016, 07:46:13 PM
Bill Gaiche
What a master piece. Thanks for all the photos of this project. Will be watching to see your next build. bg
Okay, we're ready to watch the next build!
Bruno of NH
scsmith42
Spectacular, as always.
Do you have any pix of the construction techniques on the mantle/safe?  I would be interested in learning more about it.
Scott
Tom's 3638D Baker band mill
tule peak timber
I sure can blog the nest hollow mantle that comes up ! I build quite a few a year. Everyone have  a safe  healthy Thanksgiving.  Rob
YellowHammer
Most impressive!!  Truly a work of art and skill!
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
21incher
That just came out amazing. I hope you got it to them in time for Thanksgiving. ;D Can't wait to see the next one. :)
Peter Drouin
Do you have the finish on all sides of the top? Is the bottom sealed?
A&P saw Mill LLC.
License NH softwood grader.
tule peak timber
Yes , all sides have the same finishing schedule. The top gets a lot more attention to make sure that it is perfect, but everything is thoroughly sealed.
boardmaker
Great thread!
Amazing work!!!
tule peak timber
Quote from: scsmith42 on November 23, 2016, 05:39:10 PM
Scott
Is anyone interested on a mantle build thread ?
69bronco
Quote from: tule peak timber on January 14, 2017, 10:32:32 AM
Scott
Absolutely!
submarinesailor
Scott
YES!!!!
Me three. The way you build with word??  :)
reedco
WOW!! I would not know where to start.  Retail wants to take 1/2 and all they have is a roof and a phone.
Not many trees
tule peak timber
The big walnut table is leaving tomorrow morning along with a walnut chest of drawers. The next batch of tables start on Tuesday. I will start a "hollow mantle " thread next week. Cheers  Rob
bucknwfl
He is a nice looking tom
Oh yea nice table too
Buck
If it was easy everybody would be doing it
tule peak timber
The chest of drawers that goes with it tomorrow.  Rob
21incher
A couple more amazing pieces of art out your door. Looking forward to the mantle thread.  8) 8)
scsmith42
On a side note, Rob do you know of any flexible material that could be used to fill surface checks on a large oak beam that already has been treated with a tung oil finish?  The beam is still green and will be drying for the next several years.  It's going to be used as a seating bench in a public area.
I'm concerned about splinters developing at the edges of the checks.  I'm not sure that epoxy would be a good answer because it may pull away over time as the beam continues to dry.  Any suggestions?
Thx.
tule peak timber
Hi SC, You are correct that epoxy is the wrong material. 3-M 5200 comes to mind first and you might look at boat deck caulking , like butal rubber. Then there are the post catalyzed urethane's .  When we produce something like your bench  we use small dental burrs and completely eat out-smooth out all cracks . Sometimes this takes more than a  few days of labor but we don't depend on any filler that may future fail. hope this helps  Rob
69bronco
Has anyone tried g-flex or similar?
tule peak timber
I have not tried G-flex. I will try  to find the data sheet from Gugeon brothers for a look at the shore-d ratings. I have used an epoxy system called Shell Epon , and they have a hardener that will make their epoxy like stiff rubber. Pretty obscure stuff.....You can also research post catalyzed silicon rubber put out by Dow corning  , I have experience with this stuff also. I can also give you the contact info of a company I use, that will customize epoxy to your specific needs. Then there are the guys in Texas.... All  specialized chemicals..... Rob
Larry
I use a lot of G-Flex and thinks its a great product.  That was my first thought when SC asked, but after thinking a bit it won't do what he wants.  Too much movement IMO and I'm not sure how good of bond can be obtained with green wood that's had tung oil on it.
One of the great things about quality products, especially West Systems is one can call and usually ask an engineer about how the product will perform.
