Dynamic Green Products Inc.
Author Topic: Advice on a new chainsaw  (Read 2211 times)
Offline kelLOGg
« on: September 27, 2016, 08:53:08 PM »
My Husqvarna 55 rancher became very hard to pull so I took it to a dealer who said the piston was scored making it hard to pull when hot. He could not repair it. I have never put pure gas in it; he said an air leak could cause it and said running the mixture rich could help alleviate the problem for a short time. I am looking to replace it and am considering a Sthil. What are the plus and minuses of each brand? I will be getting a small one probably ~20 to 24 inch cut. I don't do felling - just trimming logs and cutting firewood.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Online Greyhound
Re: Advice on a new chainsaw
« Reply #1 on: September 27, 2016, 09:26:25 PM »
Talk about a "can of worms" you just opened up.  My very humble opinion is that there are plenty of really good choices of saws in the same price and performance range of your Husq 55 Rancher.  Yes, there are a few dollars and a few ounces and a few h.p. differences "on paper" but in the end these are really irrelevant (except maybe price for some of the non-Stihl/Husq brands).  Everybody makes a very good 50-60 h.p. clam shell saw that will last 10+ years for anyone but a professional arborist, if reasonably cared for.
So, my strong suggestion is, go with the best dealer-support in the neighborhood.  That will be real value-added over the lifetime of the saw.
O.K., if I personally had to chose an economical single saw in the 60cc class, I would definitely go with the Echo CS590.  It has a "pro" mag case vs. the clam shells in the Stihl, Husq, Jred, etc. in the same price range.  It also has a very good warrantee for the average user and I have a great local small engine shop that carries and services Echo.  But, this may not be the best for you if you don't have good local dealer support.
Offline dougand3
« Reply #2 on: September 27, 2016, 10:55:46 PM »
So, the 55 is hard to start when hot? Or rope is hard to pull when hot? Your dealer didn't want to fix it - the 55 is the easiest saw to replace the whole topend (Piston, Ring & Cylinder). Biggest air leak trouble (if it exists) is the impulse grommet = easy fix.
Offline DDW_OR
« Reply #3 on: September 28, 2016, 12:49:45 AM »
...... took it to a dealer who said the piston was scored making it hard to pull when hot. He could not repair it......... I will be getting a small one probably ~20 to 24 inch cut. I don't do felling - just trimming logs and cutting firewood.
Bob
first, take it to another dealer. DO NOT tell the second dealer about the first dealer.
sounds like you use the saw occasionally, so think light weight, powerful and reliable.
I LOVE my Echo 310, 14 inch bar = 28 inch cut. can handle a 16 bar, 18 maybe.
that is my 2 cents
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Gearbox
« Reply #4 on: September 28, 2016, 10:27:22 AM »
My 55 Rancher was hard to pull the rope . Turned out I had to take apart the rewind and clean and lube it . pulls like new and starts like it always did .
Offline kelLOGg
« Reply #5 on: September 28, 2016, 12:25:50 PM »
My hardness-to-pull comes and goes. Shop said the piston wall was galled in 2 places. ??? I'm taking it to a 2nd shop today.
Offline dougand3
« Reply #6 on: September 28, 2016, 01:45:31 PM »
Piston scoring is not going to cause "harder to pull rope handle" condition. Just the opposite - will be easier pulling with lower compression. Gearbox hit on it - you have some starter recoil dysfunction - probably gunk or goo compressing things.
Offline RIDE-RED 350r
  • No wing, no prayer
« Reply #7 on: September 29, 2016, 08:56:53 AM »
I agree, that dealer wasn't interested in repairing your saw...
Most any saw is worth fixing and in many cases is always more economical than buying new when you are talking a basic crank bearing, seal, and top end overhaul, and you have the ability to do the work yourself. If you are not able to do it yourself, then paying labor fees always brings the price up.
Swedish, you know, like the chef.
Offline kelLOGg
« Reply #8 on: September 29, 2016, 11:28:46 AM »
I took the rewind out and it pulled normally - no binding or overlapping lays of the rope. I reassembled and it cranked easily - for now. The problem comes and goes so I am not claiming it is fixed. We'll see tomorrow. The trip to the 2nd shop is on hold.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #9 on: September 29, 2016, 11:47:48 AM »
I had an old Echo that did the same thing.  I couldn't replicate the problem with the recoil off the saw and on the bench.  It was something in the recoil that was worn out and would slip around and cause the hard pulling half the time.  No amount of cleaning or lubing fixed it.  I just used it as it was and lived with it cause I didn't want to spend any more money on it.  A new recoil will likely fix your problem.
Online Greyhound
« Reply #10 on: September 29, 2016, 12:14:43 PM »
Oops.  Thought you had a 455 Rancher with the clam shell rather than the 55 Rancher which is of course a "pro" mag case.  As above, absolutely fix it yourself!  That's a great saw and easy to work on.  Sounds like you have a good start cleaning up the recoil.
Offline kelLOGg
« Reply #11 on: August 16, 2020, 07:52:18 AM »
I'm resurrecting this thread because I am still using the same saw and it still behaves the same as reported earlier but I have more info. The 2nd shop I referred to earlier removed the muffler and inspected the piston with a small light and saw no scoring. After handling it during inspection it started easily so he thought he "fixed" it. But he didn't. Here's my new info: after the saw has not been used for several hours (winter or summer) the pull handle is very hard to pull, more so in winter. It will abruptly stop usually painfully to my arm and can pull the grip out of my hand if I am not alert to it. So I have learned to give it multiple short hard pulls and after 5 or 6 such pulls it begins to pull normally and 1 or 2 more pulls it starts. It has been doing this for 4 years. I thought poor lubrication so I removed the spark plug and poured a little bit of oil in the cylinder but it was still hard to pull - no difference. When running, the saw cuts well and is all I need so I don't want to replace it - just getting tired of starting it.
Help...again.
Offline DDW_OR
« Reply #12 on: August 16, 2020, 09:41:32 AM »
is there a Decompression Valve for the Husqvarna 55
Offline kelLOGg
« Reply #13 on: August 16, 2020, 10:56:01 AM »
There is no decompression valve
Offline kelLOGg
« Reply #14 on: August 16, 2020, 11:31:58 AM »
I removed the pull coil mechanism and with only my thumb and forefinger i could simulate the cranking action of the pull cord and the engine turned over quite easily. Likewise, the pull cord when removed from the saw pulls easily but when installed it is difficult to pull. Weird! Someone suggested replacing the pull Cord mechanism And I guess I will consider that option but I sure would like to understand what the problem is first.
Offline lxskllr
  • dummy with saw
« Reply #15 on: August 16, 2020, 11:48:17 AM »
I've only had the starter cover off of a saw once, and don't remember how it all goes together, but look for rocking on a central pivot. Perhaps it's moving out of alignment, and causing the system to jam up. However, I'm not sure why that would be time dependent.
Offline kelLOGg
« Reply #16 on: August 16, 2020, 12:50:35 PM »
Here are pics of the engagement mechanisms of the pull coil and the flywheel. All looks intact to me. It baffles me why it works well when the apparently engine is warm but not when cold. Thermal expansion issue?
Offline kelLOGg
« Reply #17 on: August 16, 2020, 04:07:28 PM »
I should have taken gearbox’s advice 4 years ago. I must have tried all other possible solutions and decided to disassemble the pull mechanism and thoroughly clean with diesel and reassemble - took about Half hour. It pulls as easily as ever now. It amazes me that was the solution to the problem - a problem that would go away when the saw warmed up...go figure. Anyway I am a happy camper now thanks to gearbox
Offline homeheater
« Reply #18 on: August 16, 2020, 08:23:35 PM »
I am just dumbfounded that a dealer or repair facility could do this.  How can they even stay in business?  Lie to customer to get them to buy a new saw and make profit.   Get customer to give them the saw since it is "junk".  Repair easily and resell for profit?
Offline kelLOGg
« Reply #19 on: August 16, 2020, 08:40:30 PM »
Yes,
That dealer is off my radar screen. I think I bought the saw from them decade or 2 ago. Not sure, though. It was an easy repair to someone familiar with the problem.
Chainsaw won't cut straight. Need advice.
Started by CHARLIE on Chainsaws
Last post February 26, 2004, 03:25:42 AM
by vince
Husqvarna chainsaw advice
Started by mjeselskis on Chainsaws
Last post August 16, 2019, 11:24:16 AM
by Awesomesince72
Need advice on a new Stihl Chainsaw
Started by bkkraft on Chainsaws
Last post January 03, 2006, 09:30:56 AM
by SawTroll
Chainsaw gets lose why? Need a advice
Started by alsayyed on Chainsaws
Last post December 17, 2005, 07:31:19 PM
by highpockets
