Author Topic: 1400 CB solenoid sticking  (Read 554 times)
Offline overclocking
« on: October 07, 2016, 10:26:39 PM »
I have a CB 1400, the Solo for the low side is sticking and causing it to burn wood faster then normal. I cleaned it,it still stuck so I replaced it. New one does the same thing after a week. I slam the door or bang on the side and I can hear it close. I don't want this to overheat or waste wood, should I put some weights on it or a small bungy cord to pull it down a little? Anyone else ever see this?
Offline Wood Shed
  • Retired antique tractor guy enjoying my Tree Farm
Re: 1400 CB solenoid sticking
« Reply #1 on: October 14, 2016, 08:29:21 AM »
I have a different model of CB and have not seen the problem you are but this year has been frustrating.  I knew the minute it was powered up something had changed (sits idle all summer).  The controller was acting erratically posting wide temp fluctuations.  So I threw $50 at it installing a new controller, did the same thing.  While working on it I noticed it went on and off if I bumped the ground wire.  Cleaned and repaired the ground connection, now I have an extra control module.  So, check your ground.  HTH
A society grows great when old men plant trees whose shade they know they shall never sit in. -Greek Proverb
Offline davewittwer
« Reply #2 on: October 19, 2016, 04:14:39 PM »
I had an issue with a sticky solenoid last year.  Cleaned with WD40 and worked great.  I also have had some issues with the wiring that controls the solenoid.  Re did some of that this fall, hopefully that will cure the problem when i fire the stove up.  Good luck, let us know what you come up with.
Offline OneWithWood
  • I am happy!
« Reply #3 on: October 22, 2016, 11:05:00 AM »
Check the alignment of the actuator linkage.
One With Wood
CB e2400 Solenoid sticking
Started by mojamboo on Firewood and Wood Heating
Last post January 27, 2015, 02:28:09 PM
by ohiowoodchuck
Sticking chainsaws
Started by Weekend_Sawyer on General Board
Last post March 31, 2014, 09:39:21 PM
by Philbert
STICKING TO THE OLE WAYS
Started by Tom_in_Mo. on General Board
Last post August 07, 2004, 03:15:56 PM
by rebocardo
saw dust sticking
Started by fivedogs on Sawmills and Milling
Last post December 27, 2011, 11:57:03 PM
by never finished
