Today's junkyard find.
Started by Kbeitz, January 09, 2017, 03:03:34 PM
Banjo picker
I was using a drill like you posted a picture of back in the late 70's when the Tennessee Tombigbee waterway was being built.  I was drilling a hole in a form to install a she bolt and the drill got away from me.  I just back off and let it turn until it ripped the power cord out of itself.  Then it stopped.  Boss wasn't too happy, but I was not hurt anyway.  Banjo
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
Darrel
yes it is! And yours is set up so it can hurt two people.  :D Just like MM said.
1992 LT40HD
Darrel
Quote from: Banjo picker on February 25, 2018, 01:34:13 PM
I'll bet the boss was happier then he would have been had you ridden it out!
Wow what a ride that would have been! :D :D :D
1992 LT40HD
gspren
Kbeitz, they quit putting the enclosed triggers on drills because they held and broke fingers.
Kbeitz
They just don't make then to last anymore. I have one like this that I got when I was around 16 years old. It's still going strong today.
Darrel
PIn those days, Black & Decker meant quality.
1992 LT40HD
GRANITEstateMP
Quote from: Peter Drouin on February 23, 2018, 06:22:45 PM
Good score, That will be handy, Just have to be smarter than the tool to not hurt yourself with it. :D :D :D :D
I like to call that the 10% Rule.  You got to be 10% smarter than what your working on, or with... ;D
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Kbeitz
Started the Bobcat for the first time today. Runs good. It has 3179 hours on the working clock. Is that a lot for this tractor?
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
DelawhereJoe
A place I used to work for would basically wear out a forklift before it was paid off. 24hr a day 5 or 6 days per week, 1000 20lb LP cans per hour is what they would fill. They filled for both Blue Rhino and Papco, the boss was making money like crazy. Even his trash, the old brass valves and steel cans he could and would sell.
Kwill
 Got one of these kbeitz? Any idea what it does ?
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Darrel
That is a lice nit comb for a hydraulic ram.
:D :D :D :D :D
1992 LT40HD
Ljohnsaw
I'd say it's missing it fuzzy covers - it's a Venetian blind duster...  It does have printed on it that it is a "heavy duty chain stretcher", though I'm not sure why you would want to stretch a chain ;)
John Sawicky
LAZERDAN
It is to install and disassemble flat roller chain.  Mostly farm equipment.  makes life easy when you have one.  I have a couple.       Lazerdan
Technically it's not roller chain. Flat detachable ag chain. The tool is called a detacher.  I have several sawmill stories regarding that type of chain, one includind a broken hand when i was holding the chain in the detacher and the guy swinging the hammer missed the chain by 6 inches.
Kwill
I wish I could find someone who needs it worse than I do :) it's been setting here on the shelf and gets moved from shop to shop.
There is pretty much at least one on every farm. Common name for it here is farm chain.
Kwill
Yeah a lot of that flat  chain used in my area
Darrel
You can find them on sale on eBay starting at 7 or 8 bucks and going up from there. I saw one that looks like yours kwill, the seller called it a "vintage steel & roller chain detacher". Wanted $45.00 for it.
1992 LT40HD
Kbeitz
starmac
The important half is not pictured, that would be the hammer.
All it is is a holder. The different slots are for different size chain. You could do the same thing with a vice, but its hard to carry a vice out to where most of these chains break! You slide a link in the slot, bend the adjacent link so that the slot in it lined up with the end of the link you are working on, then you use a hammer to either beat the inks apart, or together.
The previous post was removed as it breaks our policy about linking to off site photos.
Ed_K
 Works dang good when your laying under a manure spreader fixin that dang wore out chain ;D >:( :(.
Ed K
