Author Topic: CANT HOOK or LOG PEAVEY for turning logs  (Read 6281 times)
Offline thecfarm
Re: CANT HOOK or LOG PEAVEY for turning logs
« Reply #60 on: June 17, 2020, 05:16:50 AM »
The point comes in handy to stick in the grounds if there is nothing to lean the peavey against.
That point really helps to pry the logs apart.
But as I said way back in my other post on this thread, it's a region thing.
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #61 on: June 17, 2020, 06:20:35 AM »
I don't understand about prying logs apart. Why would you have to do that? If two logs are against each other just use your cant hook and roll one away. I must be missing something.
Offline barbender
« Reply #62 on: June 17, 2020, 08:16:38 AM »
When they are piled on top of each other.
Offline moodnacreek
  • Sawin by the notches
« Reply #63 on: June 17, 2020, 08:24:47 AM »
Working a log deck by hand or logs on the ground you 'jump' them all the time with the peavy point. Logs don't roll straight and using a wedge block and turning the log against it is more work than prying or popping with the point. Go to a log rolling contest and watch.
Offline thecfarm
« Reply #64 on: June 17, 2020, 07:02:01 PM »
I also use it to pry the logs apart behind the 3 point winch to get the chains out sometimes.
moving big logs - peavey vs. cant hook
Started by rebocardo on General Board
Last post July 24, 2006, 03:46:13 PM
by rebocardo
Cant Peavey Hook
Started by 4x4American on Sawmills and Milling
Last post July 30, 2015, 08:02:01 AM
by Magicman
Cant Hook, vs Peavey
Started by Nate Surveyor on Sawmills and Milling
Last post December 03, 2007, 11:07:10 PM
by Dave Shepard
Peavey-cant hook ???
Started by Beaudeane on Sawmills and Milling
Last post January 20, 2013, 07:21:17 PM
by SwampDonkey
