Dynamic Green Products Inc.
Author Topic: What I'm sawing tonight  (Read 1978 times)
Offline Brad_bb
« on: February 15, 2017, 11:05:39 PM »
Had an ugly Walnut log that I finally started to tackle.  Had to cut off a couple big branch stubs to start with.  This log had 3 visible knot hollows and some heart rot at one end.  Not too bad, but we'll see how deep it goes.  I made my opening cut decisions and got 3 sides cut.  Then I had to spend more time than normal tonight trying to figure out how I was going cut it up.  What I need is 6 foot 4"X8" 's.  As you can see in first pic, the first half of the log is pretty good and I think I will cut it with the chainsaw at 6"3".  Then I can mill 4  4x8's.  The 5th one may not be doable due to the hollow knot as you can see in picture 2.  I may or may not be enough below it.
In the other end of the log there is some bark inclusion and hollow that was filled by a squirrel with the broken walnut shells.  The grain/figure looks pretty cool for a table or something.  Here is a closer view.
Actually most of the hollow was removed on the first couple opening cuts.  I took about 4 4/4 or 5/4 cuts after the opening.  Here is the second cut that had most of the hollow.  Actually, when it dries out, I can see using epoxy and making a cool looking piece.
That end of the log where the bark inclusion is, is probably not solid enough to make 4x8's as is.  So i'll probably take another slab cut and if it gets solid, then try to make 4x8's from what's left.  I'll use the slab cuts to make some kind of neat shelving unit or table.  I have a number of successive cuts that go from small to big.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: What I'm sawing tonight
« Reply #1 on: February 16, 2017, 06:35:21 AM »
I'm going to take a log like that and fill the void with some nice dried
chewed walnuts and some nesting grass and then fill it with epoxy.
I think it would make a great coffee table. I just got to find a way to
stop everything from floating to the top. Maybe I could hot glue it down.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Cedarman
    • Cedarusa
« Reply #2 on: February 16, 2017, 07:21:13 AM »
Never tried to do what you want to do with the walnuts and grass.
What if you put a board on top and clamped it to the slab , then turned it upside down so that your material would float to the bottom.  After hardening, saw the board off and sand the walnut and epoxy smooth.
Don't be afraid to tell me that is the dumbest idea of the lot.
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: February 16, 2017, 07:26:59 AM »
Where do you get so much epoxy without breaking the bank?
Offline Kbeitz
    • My Hobbies
« Reply #4 on: February 16, 2017, 07:43:28 AM »
E-bay ... It's only $35.00 per gallon...
Search for "Crystal Clear Bar Table Top Epoxy Resin Coating For Wood Tabletop - 1 Gallon Kit"
Offline Brad_bb
« Reply #5 on: February 16, 2017, 08:37:05 AM »
Actually that nasty board, I'll remove all those broken walnut shells etc.  There isn't any grass.  I've taken walnut halves (from the Walnut tree in my yard) that were dry and nut meat gone, filled the nuts with epoxy, then put the nut halves in the void to take up a lot of the volume, then filled the void with a slow curing epoxy to prevent cloudiness.  In the past I have also taken acorns, cut them in half, removed the meat, super glued them back together with a little hole, pre-filled them with epoxy and mixed them with the walnut shells to fill volume in the void.  Looks like the squirrel was cashing nuts.
I've also collected the shells of the June bugs.  You know, the shell it molts out of when it comes out of the ground, climbs the tree trunk and leaves the shell there?  I've filled those with epoxy from a needle dispenser.  I also took a whole june bug from last summer that was dead, let him dry out completely and posed him and two shells in a void and filled it.  Looks really cool.
I have not used any of the epoxy colorants or glow in the dark colorants, but will eventually try it.  West Systems epoxy is about $85/gallon.  Even if I used 1/3 of a gallon on one table top, that's $28.  That's not that bad.
Here's a pic I pulled off pinterest to show what I mean by colored or glow epoxies.
Sometimes the nastiest looking wood can be made to look like the coolest!
Offline paul case
  • Original wearer of the PCM.
« Reply #6 on: February 16, 2017, 08:39:03 AM »
Brad,
What is a 5/5 board? I think it may be a typo but if not enquireing minds want to know.
PC
pc
Offline Brad_bb
« Reply #7 on: February 16, 2017, 03:19:42 PM »
Brad,
PC
It's uh metric, yeah, that's the ticket....
Offline Brad_bb
« Reply #8 on: February 16, 2017, 03:24:39 PM »
Ended up getting the 4 4x8's from the front end, a 4x6 and a 2x15 slab from the front end.  On the back end I took one 2" table slab off the sketchy face and I was down to solid wood again.  I then got 6 4x8's from the rest of that back half.  There was a small hidden hollow knot shared by two of those 4x8's but is only 1/3rd the timber width, so I may be able to epoxy fill it and use them.  Gotta wait til they dry and stabilize enough before I plane them and do any epoxy work.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #9 on: February 16, 2017, 03:39:39 PM »
I've tried the filling voids with epoxy thing, several times in fact. I've watched the YouTube videos, I've put masking tape on the bottom of the table to keep the epoxy from leaking out and all I ever got was a table that needed to be house broke.
1992 LT40HD
Offline Brad_bb
« Reply #10 on: February 16, 2017, 04:28:36 PM »
Darrel,
I've just posted a new topic in General Woodworking with tips for epoxy.  Are you using West systems or something else?
Offline Darrel
« Reply #11 on: February 16, 2017, 06:10:18 PM »
Brad,
Not sure what I'm using except for the fact that it's not west systems. I haven't used it since I moved from the wet side of the Cascades to the dry side. It's in a box somewhere. Maybe when I find it I should just trash it and give West Systems a try.
1992 LT40HD
Offline timcosby
  • I'm new! or is it green
    • my blogs
« Reply #12 on: February 16, 2017, 11:49:37 PM »
wonder if a real light pour and let dry then fill the rest would hold it in place especially with the grass.
Offline Brad_bb
« Reply #13 on: February 17, 2017, 12:55:00 AM »
What's this talk about grass?  There's not grass just a kind of a walnut shell rotted meal.  I knocked it all out.  When dry it can then be filled with epoxy and hidden treasures or whatever.
Offline Kbeitz
    • My Hobbies
« Reply #14 on: February 17, 2017, 06:04:48 AM »
Brown grass nesting.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #15 on: February 17, 2017, 06:49:21 AM »
You always have interesting threads Brad.
I like working with epoxy and embedding things in the wood. In my gun room shelving units I built, I put shell casings in knots that got knocked out.
Imagine, Me a Tree Farmer.
Offline opticsguy
« Reply #16 on: February 17, 2017, 08:46:17 AM »
You say:  "Had an ugly Walnut log that I finally started to tackle."   There is no such thing as an ugly log, only beautiful wood..............   cut_tree
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline Brad_bb
« Reply #17 on: February 17, 2017, 10:45:25 PM »
By ugly, I mean gnarly!  Meaning that you're not going to be able to just saw straight solid pieces out of it.  It's gonna take a lotta figurin' and an artists eye to see what's in the log and what it should be.  I saw some table tops, an stacking organic shelving unit, and some timber frame brace stock.
I don't know if any of you do this, but I often save Walnut slabs that have cool knobs or branch knot holes that look cool.  I'm thinking that I'll use them when i build my house.  I will do some plaster walls and mount them to the walls in places like in a closet or the wall of a room, or one corner of the bathroom... and then plaster up to it so that it looks like the house was build around the tree or the tree was growing in the house.  I'll have to take some pics of my cool slab stack and start a new thread about this.
Offline longtime lurker
« Reply #18 on: February 17, 2017, 11:56:34 PM »
If you want the " like it was embedded in glass" look with no cloudiness try West 207 ultra clear hardener. The stuff is in a class of its own.
Got the teenager sawing tonight...
Started by zopi on Sawmills and Milling
Last post April 03, 2008, 05:47:15 AM
by Woodchuck53
T.V. Tonight
Last post November 11, 2003, 06:14:08 PM
by Gus
smiley
Must not be anything on TV tonight.
Started by DR_Buck on General Board
Last post October 21, 2010, 02:25:41 AM
by Coon
Not just yet, but will be around 5:00 tonight,
Started by drobertson on FOOD! FOOD! FOOD!
Last post August 13, 2013, 02:04:10 PM
by Tim Lea
