Dynamic Green Products Inc.
Author Topic: ...going WIDE w WM?  (Read 1635 times)
Offline seaview
  • Woodman of Walkers Hook
...going WIDE w WM?
« on: February 28, 2017, 01:29:51 AM »
Anyone purchased a new WIDE Wood Mizer model yet?? How does it preform? and what were your not so obvious reasons for choosing the WIDE model? Do you see any drawbacks to the design and why would you not upgrade- with this not too heavy price difference?
This from WM--- The wide saw head increases the maximum width of cut from 28 on the standard models to 34 on the wide head models.
Looks like yet another very good reason to leave the LT35HD in the dust and step up to the LT40HD plate! Very tempting indeed... 'specialty milling services doing 34" wide, live edge slabs! cut on our 100% biodegradable Biodiesel powered Wood Mizer portable saw mill!' YO to ya brother! Artisans and craftspeople line up to the left... carpenters and cabinet makers on the right!
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: ...going WIDE w WM?
« Reply #1 on: February 28, 2017, 01:32:16 AM »
I bet the blade price is higher.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline seaview
« Reply #2 on: February 28, 2017, 02:38:44 AM »
OK- there's one thing that I did not consider; thank you- will check the specs on these custom bands and find out what the cost difference is. Of course in Canada, the price will be one and a half again the US price- and now maybe more if certain politicians have their way...
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: February 28, 2017, 06:20:28 AM »
I haven't needed a wider sawmill since..........yesterday.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #4 on: February 28, 2017, 07:37:41 AM »
Hello,
   Blade cost would be $ 28.00 increase than a 158" blade per box of 15 blades or $ 1.87 per blade.  1 1/4" wide .045 thick 171" length.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline bandmiller2
« Reply #5 on: February 28, 2017, 07:38:08 AM »
Sounds like a good idea, bands would only be about 12" longer. I wonder if the rest of the mill will be beefed up any as it will be handling a lot more weight. Heavier support equipment will be needed. My homebuilt will do up to an honest 30" but I try to avoid that big stuff. As important as width of cut is how high the saw head will go, never make a cut at max height leave yourself a 1/2" or so for gigback. No matter how large the mill is you will always find a log too big or too heavy. Frank C.
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #6 on: February 28, 2017, 07:52:00 AM »
The max log size rating of 36" hasn't changed.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #7 on: February 28, 2017, 08:02:26 AM »
Yup.  Never thought I'd run into something in my area bigger than 4' to slab.  Wrong!
In the long run, you make your own luck good, bad, or indifferent. Loretta Lynn
Offline JRWoodchuck
« Reply #8 on: February 28, 2017, 03:52:22 PM »
Haven't heard the term 'GIGBACK'. What does it mean?
Home built bandsaw mill still trying find the owners manual!
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #9 on: February 28, 2017, 04:02:11 PM »
Slang for bringing the head back to the front of the log, as in getting ready for the next cut.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #10 on: February 28, 2017, 04:14:45 PM »
Saw down, gigback.....
Jim Rogers
Offline DGK
« Reply #11 on: March 01, 2017, 12:34:49 AM »
You may want to query Wood-mizer about the the minimum log size that the debarker will be effective on.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
« Reply #12 on: March 01, 2017, 06:07:39 AM »
Quote
Yes WM is working on this also. Should be available very soon.
Marty
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #13 on: March 01, 2017, 07:01:38 AM »
 The biggest problem I see with these new wide models is that I don't have one lol
Boy, back in my day..
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #14 on: March 01, 2017, 10:16:28 PM »
I believe the 34" refers to the distance between blade guide rollers. I could be wrong, but on my 2006 mill the 28" is between blade guides -- the practical cutting width is 4" less. To get the extra width you have to shift the log past the normal side stop position.
I suspect Marty's pricing is in $US. Not only do the blades cost more, you will have more teeth to sharpen.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline 4x4American
    • Website Link
« Reply #15 on: March 01, 2017, 10:20:39 PM »
What a debbie downer!  Didn't even mention all the women that are gonna be flocking to the mill....
Offline Andries
  • Making buildings out of big curvy logs
« Reply #16 on: March 02, 2017, 12:29:13 PM »
Oh c'mon DUG.
I heard that the gals were already flocking to your regulation sized toothy grin . . .
 ;D
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
LT15 Wide, LT70 Wide, where's the Wide Edger?
Started by Dave Shepard on Sawmills and Milling
Last post March 25, 2018, 11:53:41 PM
by Darrel
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
Wide plank flooring...how wide can I go?
Started by lshobie on Sawmills and Milling
Last post January 13, 2016, 08:34:59 PM
by Rob in NC
Best way to dry wide EWP.
Started by Dave Shepard on Drying and Processing
Last post April 25, 2014, 09:26:36 PM
by Peter Drouin
