Author Topic: Nyle Kiln Insulation questions,  (Read 531 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: March 14, 2017, 10:44:55 AM »
I received my kiln yesterday (Nyle L53) I am now educating myself on insulation types and gathering building materials. I found a good buy on the insulation panels shows in the photos below. it is however not extruded but was wondering if this could be used in the chamber build?
Thanks for any advice/input.
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline Deese
Re: Nyle Kiln Insulation questions,
« Reply #1 on: March 14, 2017, 11:33:52 AM »
 :P
2004 LT40 Super 51hp diesel
Cat Claw sharpener/Single Tooth Setter
Stihl chainsaws MS880, 661, 440, 250
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Last Summer Was HOT.
Offline pine
« Reply #2 on: March 14, 2017, 02:37:09 PM »
That looks like the white styrofoam "bead type" product.  If so, I highly recomended that you stay very far away from it.
Never use the expanded polystyrene (EPS) (white stuff ) according to Nyle.
Nyle flat states do not use it.
If it is the XPS type foam, pink/blue then that is a good type.
HD had the Foamular 150 on a drastic markdown two months ago.  Don't know if it still is.
Offline 123maxbars
« Reply #3 on: March 14, 2017, 04:22:35 PM »
You are correct, just got done reading some of the book that came with the kiln. I appreciate your response!
outofthewoods
Youtube page
Out of the
Offline GeneWengert-WoodDoc
« Reply #4 on: March 15, 2017, 07:03:32 AM »
The issue with insulation is how it responds to the heat in the kiln.  With the L53, the heat is low, so the insulation will slowly deteriorate.
upgrading my Nyle kiln chamber, questions about compressor and bd ft limits/time
Started by Kelvin on Drying and Processing
Last post July 15, 2009, 07:53:11 AM
by Sawyerfortyish
Kiln Insulation?
Started by WoodChucker on Drying and Processing
Last post April 21, 2004, 10:41:32 AM
by Ga_Boy
Kiln insulation
Started by Bnewman712 on Drying and Processing
Last post May 29, 2018, 07:41:08 PM
by Bruno of NH
Kiln insulation?
Last post May 15, 2004, 10:55:03 PM
by WoodChucker
