Author Topic: router sled  (Read 974 times)
Offline xlogger
router sled
« on: April 01, 2017, 06:22:05 AM »
Has anyone here use or have a Woodhaven planing sled? If so do you like it? I'm having several wide slabs mostly maple that cup and are sitting in my inventory not selling. I was thinking about trying to see it works selling if I flatten them. I really don't want to get into the wood working part but money is sitting there and not selling. I know you can build a sled but this one looks nice.
Offline WLC
Re: router sled
« Reply #1 on: April 01, 2017, 03:22:05 PM »
I like the looks of that one.  Much smoother operation than my home made one.  I'm going to bookmark their site for future reference.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
Re: router sled
« Reply #2 on: April 01, 2017, 03:41:23 PM »
Looks to be accurate and easy too set up. affordable price for what it will achieve. Pay for itself in no time. Got me interested.
Thanks for posting.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: router sled
« Reply #3 on: April 01, 2017, 10:24:16 PM »
Remill it.
You have one of the biggest and baddest jointers made, a sawmill.  Put the offending slab, with the hump up, back on the mill, level the twist best as you can, and skim cut it flat.  Slice the hump and twist right off.  The board will be as flat as if it just came off the mill originally.    Them flip it over and do it again.  The cut on the opposite side isn't really needed, but I like to do it to make it feed better through the planer.
I like the first cut to be just a tad under the original thickness of the board.  For example, I cut my slabs to 2 3/8" thick, so when I remill it, I set the band to 2 1/4" above the bed.  This should pretty much clean up the whole face.  Then I flip the board and remill to 2 1/8".  The board will then plane easily because its flat again.  Of course, if the cup or especially twist is real bad, the mill will slice off a lot of wood.  Sometimes it's a losing situation, so I'll crosscut the slab in half, to get a flatter board, then remill it.
I remill a quite few slabs, its one of the reasons I tell customers that they are more expensive, they get to ride the sawmill twice.
HobbyHardwoodAlabama.com
Offline xlogger
Re: router sled
« Reply #4 on: April 02, 2017, 07:00:25 AM »
Yes Robert you can do it that way, ladylake suggested that to me awhile back. I going to try that also. But I hope to have my slabber running soon and on those slabs will be too wide for my mill. Not sure how it would work putting cup slabs back on a chainsaw mill. Maybe Seaman or someone with a slabber can let us know.
Jake at Turbo Saw called me yesterday about a planer for that mill but since I only have the slabber on the mill it will cost a good bit because I would have to buy the swing blade for it, I don't have any desire for a swing blade.
Offline Savannahdan
  • Retired.
Re: router sled
« Reply #5 on: April 02, 2017, 07:53:25 AM »
123MaxBars has a video he posted under Woodworking using the Woodhaven Planer Sled.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: router sled
« Reply #6 on: April 02, 2017, 08:02:03 AM »
My sawmill is also my slab flattening device.  If the slab is too wide for the mill, I never cut it in the first place  :)
Offline xlogger
Re: router sled
« Reply #7 on: April 02, 2017, 06:53:19 PM »
I looked and he has several videos. Couldn't see that one.
Offline Savannahdan
  • Retired.
Re: router sled
« Reply #8 on: April 02, 2017, 09:42:45 PM »
His video is under "router sled".  I have the 51" model but haven't had a chance to use it.  Have other projects that got moved in its place including repairing my Husqvarna chainsaw and then completing some Alaskan mill cuts.  I do like the build of the Woodhaven sled.
Offline Briankinley2004
Re: router sled
« Reply #9 on: April 02, 2017, 10:02:33 PM »
I made one out of a harbor freight pick up headache rack I had taking up roomin shop. It's perfect working height. Put a laminate Clad door I had on top of it and is perfect height to do 3" slabs. I have to shim up 2" ones by placing uni strut under them.
Router Sled
Started by 123maxbars on General Woodworking
Last post March 15, 2017, 12:33:54 PM
by Darrel
Router sled...
Started by Hooterspfld on Sawmills and Milling
Last post May 03, 2019, 08:38:17 AM
by busenitzcww
Router Sled
Started by Bill Gaiche on General Woodworking
Last post February 04, 2017, 07:45:37 PM
by OffGrid973
Router sled
Started by xlogger on General Woodworking
Last post September 12, 2016, 04:20:58 PM
by OffGrid973
