Author Topic: Calling all Motorheads!  (Read 1294 times)
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« on: April 04, 2017, 01:52:47 PM »
I'm trying to figure out what Carburetor is on the engine in Tammy's Blazer.  It has an Edelbrock intake and valve covers. I think it could be an Edelbrock carb, but I can't find any markings on it. If it had a tag, its gone now.  Reason is, there is zero choke on it. the Butterfly isn't even there.
Here are a couple pictures.
Offline coxy
Re: Calling all Motorheads!
« Reply #1 on: April 04, 2017, 02:54:48 PM »
maybe a carter
Offline Jeff
  • Fearless Leader
« Reply #2 on: April 04, 2017, 03:05:05 PM »
Put is on facebook and a drag racing friend I.D.'ed it a a Carter/Edelbrock AFB. Knowing that, I was able to find the id numbers on it. Looks like it is a 3224 600 CFM.   May be impossible to find a choke plate without finding an old junk carb.
Offline chevytaHOE5674
« Reply #3 on: April 04, 2017, 03:06:55 PM »
Edelbrock.
Best bet for parts maybe a used parts carb.
Offline snowstorm
« Reply #4 on: April 04, 2017, 04:58:32 PM »
Isn't a elderbrok a copy or an old Carter. Mopar used carter's. I had a couple 340 mopart. 1 Carter 1 with a holley. It's hard to tell from the pic. If the vacuum dash pot pull off is there. Along with the bi.metal spring for the heat riser. Or use a cable. The best way is a electric choke. There may be a up date kit. Try summit raccing.
Offline Jeff
  • Fearless Leader
« Reply #5 on: April 04, 2017, 06:14:22 PM »
The problem is the whole choke butterfly is gone. Most anything else I can find.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #6 on: April 04, 2017, 06:38:56 PM »
Early Edelbrocks were remanufactured Carters then they ran out of old carbs so they began reproducing them  :) 8)  That's the story I've heard  ;) ;D
Offline scsmith42
    • Whispering Pines Farm
« Reply #7 on: April 04, 2017, 07:01:08 PM »
Edelbrock bought manufacturing rights to the Carter AFB back in the 80's. That IS an AFB, or Edelbrock version of one.
Tom's 3638D Baker band mill
Offline Jeff
  • Fearless Leader
« Reply #8 on: April 04, 2017, 07:06:27 PM »
sO ANYBODY GOT A JUNK ONE? :D DANG CAPLoCk
Offline coxy
« Reply #9 on: April 04, 2017, 07:20:42 PM »
 umm had 2 that went to the bone yard 3 weeks ago
Offline Jeff
  • Fearless Leader
« Reply #10 on: April 04, 2017, 07:29:49 PM »
Well go get em back!
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #11 on: April 04, 2017, 07:44:26 PM »
Not much help but paying attention.
Offline Autocar
« Reply #12 on: April 04, 2017, 07:54:56 PM »
Jeff if you end up drawing a blank on the carburetor I have a friend up at Oakwood Ohio that has a woods full of ford trucks ect.
Bill
Offline Don P
    • Calculator Index
« Reply #13 on: April 04, 2017, 08:15:01 PM »
It looks the same as an Edelbrock 1406 aftermarket 600 cfm, maybe widen your junk search?
Offline snowstorm
« Reply #14 on: April 04, 2017, 08:23:56 PM »
70,so Mopar 340 360 383 440 used them. Try summit racing they sell them. Some took the choke plate thinking it would flow more air. And a lot of marine engines still use Carbs.
Offline dustyhat
« Reply #15 on: April 04, 2017, 08:42:25 PM »
Its a absolute edelbrock carb , yes go to advance auto ,they can order all the parts you need.
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Offline sprucebunny
  • Gender: Female
« Reply #16 on: April 05, 2017, 07:51:36 AM »
I think this is the same basic carb. Off a 383 Chrysler.
Looks like it might be possible to make your own choke plate :)
Offline snowstorm
« Reply #17 on: April 05, 2017, 08:23:02 AM »
Your picture looks like a double pump holley.
Offline Jeff
  • Fearless Leader
« Reply #18 on: April 05, 2017, 08:27:48 AM »
Yea, I don't think it would be even close to mine Joan.
Offline sprucebunny
  • Gender: Female
« Reply #19 on: April 05, 2017, 08:28:19 AM »
I don't know what it is. Had Edelbrock air screen thing.
Choke plate is similar and doesn't look very hard to make. Post some measurements, Jeff. If it's close, you can have the plate.
This one is
3 9/16+ long by about 1 ⅞ wide
calling
Started by coxy on General Board
Last post April 05, 2017, 09:53:05 PM
by Magicman
calling mr. bob Falk
Started by bandmiller2 on Sawmills and Milling
Last post December 10, 2007, 04:28:54 PM
by Tom
calling logger 88
Started by snowstorm on Forestry and Logging
Last post January 03, 2015, 07:36:15 PM
by outlawcowboy
Calling Dr.Roof
Last post May 06, 2004, 05:23:48 PM
by Tom
