Author Topic: stinky oak odyssey  (Read 3005 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: stinky oak odyssey
« Reply #20 on: May 12, 2017, 12:44:16 PM »
  :P  You used the term "magic" three times in Reply #17 and I wasn't even there.  ;D   :D
Now how is that for brightening your dreary day??   ???
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #21 on: May 12, 2017, 01:38:36 PM »
I really enjoyed this thread.
Thank you for sharing it with us.
Jon
Imagine, Me a Tree Farmer.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #22 on: May 12, 2017, 06:43:12 PM »
Check this one out...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline grouch
  • I'm recyclable!
« Reply #23 on: May 12, 2017, 09:37:17 PM »
Musta been thinkin' about you and how logs just sorta gather where ever you park that WM.
[Edit to add:]
Logs just sorta *magically* gather where ever you park that WM. :D
Jon
Glad to hear that. Welcome and thanks. Still getting the rest of the photos ready to post. I waffled a long time before starting this and then finally came to the conclusion that if only those who knew what they were doing posted, the discussions would be pretty thin.
'Way back, Ianab gave me advice on using a bore cut. I still haven't tried it, though.  ;D
Find something to do that interests you.
Offline grouch
  • I'm recyclable!
« Reply #24 on: May 12, 2017, 10:21:05 PM »
There was another twist in the path between 2nd log and the big mama. It turned out to be a dead end, but was still part and parcel with this tale.
I wanted tongs for my log arch. It's a little time consuming and aggravating to jack logs and wrap chains. After some sketches and fiddle-faddling around with cardboard and digging through what I had on hand...
Black pipe wasn't my first choice but the only suitable steel rod I have is some cold rolled 1-3/8 and 1-1/4. Don't want to pay for that precision just to bend it.
A little plasma on some 3/8 inch plate
Center punch
A 1 inch flat washer makes a decent template for plasma cutting a hole
Eyeball center
Works, but not as well as hoped
Should've chipped slag and made it pretty
The chain sucks
Better, but no way it's going to open enough for the big log
It will handle logs this big and a bit bigger, but not the ~23 - ~24 inch log I wanted
I think adding 3 inches to each leg will let it handle any log that will fit between the uprights on the arch.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #25 on: May 12, 2017, 10:42:00 PM »
You gotta admit that those tongs are butt ugly.  :o   :D  But they work.   8)
Offline grouch
  • I'm recyclable!
« Reply #26 on: May 12, 2017, 11:33:27 PM »
Aw, man, I thought they's sexy... er, um, ok, maybe purty... tolerable...
Alright. They're _ugly butt_ ugly. Might not improve the looks any when I graft 3 more inches of pipe right in the middle of the ones that are there. ;D
Offline grouch
  • I'm recyclable!
« Reply #27 on: May 12, 2017, 11:55:46 PM »
My original cobbled up hitch for the log arch consisted of a D-ring, clevis and drawbar:
It lurched and clunked and eventually caused the arch to move somewhat in the direction you told it to, it just sometimes took some little zigzags of its own choosing along the way. That was acceptable as long as I was dealing with logs small enough to scoot, pry or manhandle along the mill bunks. (Loading from the side still requires me to scoot logs toward the head before sawing. Clearance issues).
I needed more precision and the ability to watch the 4 inches or so clearance between tires and mill so I would not have to fight that big log into position.
My tractor needed a snout.
What the snout is welded to is a piece of 1/2 x 4 x 8 angle:
Don't know how much this helps, but I let the snout (2 inch receiver tube) continue under the angle:
Here's why the snout has to be so long:
2 inch ball in 3/8 inch angle welded to 2 inch square tube
Don't get nervous; you *won't* meet this running down the interstate:
Offline grouch
  • I'm recyclable!
« Reply #28 on: May 13, 2017, 09:49:37 AM »
Ok, that should bring us back to
I'm getting as bad as Hollyweird in scrambling space and time.
The tape measure should have been enough to tell me not to try leveling the pith. Big end was about 25 inches, small end about 15 inches, that's 5 inches of wedge to cut away before a full cut, and that's about all the good wood at the big end. It's a learning process.
Just about the mill's limit:
About 12 inches good:
I was cutting 1-5/8. These things were heavy.
Already losing some of that 16 ft
That was a stinky beast to roll. After each turn, I had to realign the track.
Offline grouch
  • I'm recyclable!
« Reply #29 on: May 13, 2017, 09:59:13 AM »
Still didn't know how far up that mess went:
Ugly and stinky:
Cut in half:
Feed trough?
Offline grouch
  • I'm recyclable!
« Reply #30 on: May 13, 2017, 10:11:02 AM »
Almost there...
What? That's not a circular sawmill? I been robbed!
Boards from the 2nd log have a destiny with dirt, tomatoes, beans, etc.
Some end grain shots (with and without flash, because I don't know what people are looking for when they study these slices). If you see any saw marks on these, tell Freud to fix their blades:
There it is -- selection to stapled. :)
Offline paul case
  • Original wearer of the PCM.
« Reply #31 on: May 13, 2017, 01:05:41 PM »
encore!!!!! popcorn_smiley bon_fire smiley_book2_page
PC
pc
Offline nativewolf
« Reply #32 on: May 13, 2017, 02:15:16 PM »
That's perfect picture end grain of a red oak!   8)
Liking Walnut
Offline grouch
  • I'm recyclable!
« Reply #33 on: May 13, 2017, 09:33:41 PM »
PC
You have to supply the respirator and fresh air pump!
Thanks. Are there multiple kinds of red oak? I remember from my pocket guide (which I lost grrr) the Quercus section was long. Only other guide I have has no photos, just line drawings of bark, leaves, seeds and flowers.
Set up the tripod for those, then couldn't tell through the viewfinder if I was getting what I wanted (forgot "live view") so set 'em up again with bottom board on top. When it turned out both sets were square and focused, decided to post both pairs.  That's as close as my 18-55mm lens will focus. Could've put on a bellows and got down to the cells.  ;D
Offline paul case
« Reply #34 on: May 13, 2017, 09:39:06 PM »
Oh yeah there are different kinds of red oak. Southern RO, blackjack oak, Black oak, Northern RO, and Water oak are the kinds of Red Oak we have here in my neck of the woods.
PC
pc
Offline grouch
  • I'm recyclable!
« Reply #35 on: May 13, 2017, 09:52:21 PM »
See, that's the thing -- common names are regional. There's a "blackjack oak" behind my house which was called a "pin oak" where I grew up. Local fellow told me when we moved here that, "It's called a blackjack oak 'cause it holds its hand all winter."
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #36 on: May 14, 2017, 11:57:56 AM »
What a fantastic journey - thx for sharing
Offline derhntr
  • Sawing lumber is addicting
« Reply #37 on: May 14, 2017, 09:17:14 PM »
I could see lots of bore hole. Big problem in dead oak.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
Offline grouch
  • I'm recyclable!
« Reply #38 on: May 14, 2017, 11:55:16 PM »
Will the villains continue eating on it after sawing?
I can't remember if I sprayed Tim-bor on all of that oak or not.
Offline grouch
  • I'm recyclable!
« Reply #39 on: May 22, 2017, 02:40:51 PM »
Stinky oak boxes doing their job:
These tomatoes look happier than the ones in the previous picture.
Onions not looking too well.
homely's odyssey
Started by 51cub on Travel Guide
Last post November 03, 2018, 01:04:08 PM
by 51cub
stinky? get out
Started by redpowerd on General Board
Last post April 10, 2004, 06:25:10 PM
by redpowerd
