Wm spring blade tensioner conversion
Started by Crossroads, May 16, 2017, 01:26:45 AM
Crossroads
I have a 1984 lt30 that has a spring to tension the blade and I can't help but to think that has something to do with some of the dips and waves that happen on occasion. Has anyone converted the old spring tensioner over to the new hydraulic style?
Ben Cut-wright
"dips and waves" can happen for numerous reasons.  Happily, checking band tension is one of the easiest factors to eliminate.  Converting to hydraulic adjustment has its benefits but I like the spring.  First, have you replaced the spring?  Next have you measured the stretch of the band to determine its proper tension?  After getting a baseline it is simple to add or subtract tension from measured stretch.  Adjusting tension may or may not alleviate the waves and dips, but getting proper baseline tension goes a long way toward eliminating one cause.  All that said, IMO, if you cannot overcome the wave and dip by properly adjusting the spring, chances are the hydraulic won't fix it either.
pineywoods
The wm hydraulic tensioner is a real neat piece of design work. Simple and elegant. The real plus is it has a gauge that shows the actual tension, and it will vary as the blade heats up. With a spring, you are just guessing at best..Building your own would be simple enough. Arnold113 came up with a homemade design using the cylinder and pump off a cheap floor jack. My mill has the hydraulic tensioner, if it didn't, I would be building one post haste..
Ben Cut-wright
Happy Birthday, Sir!
Did you mean to state that the "hydraulic gauge shows the actual band tension"?
If stretch-measurement of a particular band is correlated with either hydraulic gauge reading or spring measurement, one may use those indicators to set tension of this particular band. Please set me right if I am incorrect.
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
Crossroads
I've not done any band stretch measurements or replaced the spring. I have made sure that everything has been squared up as stated in the manual. I thought I had it pretty well under control, but did a job last week cutting some fir that was pretty dry. I ran 4* blades and it seemed like 8-10' into the cut it would dip or dive following the grain or going around knots. I'm pressure washing the logs so,they are clean and change blades regularly. I'm running straight water on the blade, but the dripper gets plugged with sawdust quite often. Could it be that my blades are getting hot and either changing the tension or flexing and changing the set on the teeth?
pineywoods
The wm tension  gauge is actually a 0-3000 psi pressure gauge with the recommended pressures high-lighted. Yellow arc for 035 blades, orange for 042, white for 045, The hydraulic cylinder has a bore of 1 inch, makes it easy to calculate the actual blade tension if you so desire..The real advantage is you can see the pressure drop off when the blade heats up and expands. Sunshine on the head frame will cause the frame to expand enough to cause the pressure, thus the blade tension, to rise.
Crossroads
I looked in Arnold113 gallery and saw one picture of his tensioner, I need to look to see if there are any more pictures that show more of it. By the way pineywood my hydraulics are working great! The clamp and back stops being powered have sped things up a lot. The 6.5 hp gas engine runs the pump very well.
D6c
I have an '87 LT40 that I'm doing a number of mods to, and the hydraulic tensioner is one of the things I'm considering.  I did talk to WM a little about it and they seemed to think it could be done fairly easily.
Would be very interested to see how it goes if you decide to do it.
Ben Cut-wright
Quote from: Crossroads on May 17, 2017, 07:52:58 PM
Thinking it would be wise to find the cause of your complaint before buying parts that may or may not correct the problem.  Not trying to discourage you buying any component you desire.  The springs do become fatigued, a new one is cheap.  Even with a new spring or a hydraulically tensioned upgrade, the band should be measured for more exact tension.
If you suspect the band is getting hot, stop and examine it at the moment when the cut becomes unstable.  If the band is hot, if your adjustment indicates tension is less, if the band has become coated, if your "dripper" is plugged,  then you have facts you can work with.
Crossroads
Quote from: Ben Cut-wright on May 19, 2017, 12:04:21 PM
I totally agree, I guess that's why I've asked the questions so, I can learn what I don't know. I'll definitely do some measuring next time I run it. I don't have one of the fancy clamp on dial indicators like what's pictured above, but I have a digital caliper that I can clamp on like I saw in arnold113 gallery. Also, I'm going to add a pump to my watering system so, I can keep a consistent amount of fluids on the blade. The blade tensioner indicator is pretty crude so, measuring will definitely be a  lot better. I guess the next question is, how much stretch do I want? Thank you
pineywoods
Unfortunately there will be no updates to the arnold113 tensioner. Arnold passed away suddenly a couple of months ago. From his pics and personal conversations, it looks like a fairly simple deal. A cheap hydraulic floor jack and a 3000 psi pressure gauge is all that.s needed.
Kbeitz
Quote from: pineywoods on May 20, 2017, 10:54:24 AM
But how does someone know where to put the pressure gauge ?
pineywoods
Quote from: Kbeitz on May 20, 2017, 07:55:38 PM
S W A G  ;D If you mess up, can always plug the hole and try someplace else  ::)
Actually anyplace that taps into the base of the cylinder should work...
Crossroads
While searching for the picture I saw where Arnold113 had passed, that's to bad, he seemed quite creative. I'm going to measure the stretch this afternoon, how much stretch should be my target? In the first picture of a gauge above, I see the markers are at .031" is that the right amount of stretch? Thank you
Ben Cut-wright
Quote from: Crossroads on May 21, 2017, 10:03:02 AM
Looks like he lived in the River Valley, just over the hill from me.  Wish I had known.
This link should help you measure applied tension.
https://forestryforum.com/board/index.php/topic,7923.0.html
Arnold113 was a very talented man and also a very Special Friend.
Pictured here showing Pat his sawmill's homemade setworks.
Crossroads
Thanks but it was actually a Forestry Forum loss because he readily shared his expertise.
Crossroads
Okay, so I clamped a caliper to my blade then ran it up to the tension where I've been running it. Not even slightly close! It was .0005", the spring is apparently worn out, I basically had to bottom it out to get to .005" of stretch. I'm going to be doing a job tomorrow so, I'll crank it up and see if it's an improvement.
pineywoods
Quote from: Magicman on May 21, 2017, 03:51:37 PM
Arnold offered me the drawings and software for his home-made setworks..I thought I didn't have time to purse it, now I wish I had...
Crossroads
Quote from: pineywoods on May 21, 2017, 09:02:23 PM
I saw that he had your clamp on his mill, where he had 3 holes griped in the arm, was that so he could change the reach on it. Or was he searching for the best spot? The way mine ended up, I'm limited to about a 28" log, but that's not such a bad thing.
pineywoods
Yeah, them 3 holes are there because he took pics of mine and copied everything including my uh-oh's.  ::) That setworks he had developed is more than a normal setworks, it is a complete automation system, saws boards with no human intervention.
Ben Cut-wright
Quote from: Crossroads on May 21, 2017, 05:27:35 PM
There 'ya go.  Easy and quick to measure tension no matter how it is applied.  A worn out spring may not 'react' properly but it should be good enough for your test run.
