Author Topic: Milling own timbers vs ordering timbers from a sawmill  (Read 1971 times)
Offline Joe Vachon
« on: July 02, 2017, 02:48:32 PM »
So I've been working and planning on building my own timber frame Home. I'm still in the process of clearing the land and having a foundation put in, but I just want to be prepared for the next phase after that. I wanted to know what are some of your insights as to purchasing a portable sawmill and milling my own timbers vs ordering my timbers from a sawmill. Thanks a bunch.
Offline paul case
  • Original wearer of the PCM.
Re: Milling own timbers vs ordering timbers from a sawmill
« Reply #1 on: July 02, 2017, 02:55:04 PM »
Welcome to the forum.
I bought a mill several years ago with intention to build a house. I figured the framing lumber cut from my own logs would be worth enough that the mill would be paid for in the first project. Almost from the start people were bringing me logs to saw for them and it turned into a good job. Now 3 mills later it is a good living for my sons family and mine.
I enjoy sawing. If you think you might like it and you like to work, go for it.
PC
pc
Offline longtime lurker
« Reply #2 on: July 02, 2017, 04:40:54 PM »
Kinda like Paul I bought a portable mill to cut a few boards for my own use and some beer money on the side maybe.  And it grew.
9 years later i still haven't cut that house out for myself... or i have on numerous occasions  and I've sold them each time.  And we punch 30 ton of logs a week through.
No point  buying a mill if you have insufficient raw material on hand. Other then that beware of the sawdust disease.
Offline Larch
« Reply #3 on: July 02, 2017, 08:29:19 PM »
Sawing becomes a part of your life and you know how it goes -- the shoemaker's family goes unshod.
Full time professional mills can have your timbers cut, dried planed and delivered while you're still waiting for your first timber to dry.  You want to be joining wood or figuring out how to run your mill?
I would not buy a mill unless you're sure your life would not be complete without one.  And even then I'd probably tell you to buy your beam package anyway just so you can focus your attention on your frame while you get good at sawing.
Offline bandmiller2
« Reply #4 on: July 02, 2017, 09:09:46 PM »
A lot depends on how big a rush your in. If you have a place to live near where your building and you can let timbers dry it may be worth buying a mill. If your in a hurry to complete the house buy from a mill that cuts for timber frame. If you buy a mill get a known brand so you can sell it later if milling is not your thing. Especially cutting timbers you need  decent support equipment to lift logs and timbers. Good luck mate. Frank C.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #5 on: July 03, 2017, 06:35:51 AM »
Welcome to the Forestry Forum, Joe!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline fishfighter
« Reply #6 on: July 03, 2017, 09:12:06 AM »
Here you go OP. And yes it can save you money in the long run. Also, one can custom cut lumber for the finish project that can save you a ton of money. Was the reason I bought my mill.
http://www.forestryforum.com/board/index.php/topic,82663.0.html
One thing, one needs support equipment with a manual mill. Learning to saw and making plans on how to read a log takes a little time, Besides that, there are a lot of good, smart people that post here that will answer any question without giving you a hard time. 8)
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #7 on: July 03, 2017, 11:17:58 AM »
Welcome!!!
I'd mill my own timbers, it's fun and you'll learn something too!
 8)
1992 LT40HD
Offline thechknhwk
    • Story of the Trees
« Reply #8 on: July 03, 2017, 12:45:18 PM »
You can probably do it but it might take a while.... ;D
http://www.forestryforum.com/board/index.php/topic,73938.0.html
question
Hardwood timbers vs. Softwood timbers
Started by jeremy86 on Timber Framing/Log construction
Last post September 23, 2016, 09:01:22 AM
by Heartwood
Milling and using oak posts/timbers
Started by IowaAl on Drying and Processing
Last post July 19, 2016, 11:55:45 AM
by Roy Beauchamp
Milling timbers for green use
Started by Jimbob on Sawmills and Milling
Last post October 24, 2007, 11:33:42 PM
by JD350Cmark
Milling LONG timbers
Started by ljohnsaw on Sawmills and Milling
Last post September 25, 2016, 10:11:55 PM
by Magicman
