Author Topic: Considering engine replacement  (Read 5905 times)
Offline kelLOGg
Re: Considering engine replacement
« Reply #40 on: August 08, 2017, 05:09:02 AM »
I am considering a Honda gx series 20HP. It is an easy fit - same bolt pattern as the Kohler.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline 47sawdust
« Reply #41 on: August 08, 2017, 06:35:44 AM »
Bob,
I was hoping you would come back to the Honda.My GX670 has been a good performer.Technical support has never been a problem......or needed.Also the red color goes well with your Cook's mill.
Best of luck,Mick
Mick
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #42 on: August 08, 2017, 10:18:01 AM »
Honda's and Kawies are very good engines.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline JB Griffin
« Reply #43 on: August 08, 2017, 09:13:45 PM »
As far small gassers go, honda would be my first pick.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline SineWave
« Reply #44 on: August 09, 2017, 08:24:11 AM »
All I know about Kawis is, I had a 12 or 17hp in a John Deere 175 mower and I thought it needed a starter and called the dealer (this was nearly 20 years ago) and they wanted something like $400 for a starter.
I asked, "How much for a complete new engine???"
Offline FloridaMike
« Reply #45 on: August 09, 2017, 11:00:52 PM »
I too went with a Honda (20.8 hp).  Was surprised to see the "made in China" sticker,  I guess what isn't these day.
Mike
Offline Kbeitz
    • My Hobbies
« Reply #46 on: August 10, 2017, 02:05:31 AM »
All Honda vertical-shaft lawn mower engines on both Honda lawn mowers as well as other brands (Toro, Sears, etc.) have been cast, assembled and shipped from the Honda plant in Swepsonville, North Carolina since 1982. That facility makes hundreds of thousands of engines every year, with many exported to Latin American and European distributors.
Now some of the larger, horizontal-shaft engines used in Honda generators, snowblowers, and pumps are made at Honda plants in Thailand. However, the vast, overwhelming majority of Honda engines sold in the US come right out of the Swepsonville plant.
If it says it's made in China I bet it's a clone.
Online Ianab
« Reply #47 on: August 10, 2017, 03:13:08 AM »
According to Honda's web page the GX series is made in Japan, Thailand or China. Those are the commercial rated engines.
The US plant builds the GS version which is a lighter duty engine, and would be used for lawnmowers etc.
If you bought via a legit Honda dealer it's probably a legit Chinese Honda.
If it's "grey market" then it's anyone's guess who actually made it.
Offline kelLOGg
« Reply #48 on: August 10, 2017, 07:19:17 AM »
The best price I have found for the Honda GX 20.8 HP is 1199.99 + shipping (no muffler) from an un-mentionable company so I bet it is made in China. That's a red flag for many. Maybe this is a naive question but if Honda write the specs for a product and verifies the plant can meet them (which to me is the minimum of good business practice) why does it matter where it is made? (It is not my intent to throw a grenade in the kitchen and leave  :o)
Bob
Offline iffy
« Reply #49 on: August 10, 2017, 07:52:33 AM »
The Chonda engine I have on my mill is a 22 hp, listed for $899, on sale for $699. I had a 20% off coupon so another $140 off and shipping was $6.95 to my door. If you discount my screwup with the ether, it has been a pretty good engine. The external parts look just like the external parts on the Honda I have on my welder/generator. I know the piston is different, and would assume the rod is too, but don't know about crank or other internals. My only real complaint about the engine is non-adjustable carb jets and if it sets for awhile the Jets may get varnish build-up & run lean. However, my Honda did this too.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #50 on: August 10, 2017, 11:00:24 AM »
The cure for all carburetor related illnesses is a fuel shutoff valve that is used to run the carb dry of fuel religiously every time one shuts the engine down.  Of course, this isn't required if the engine is used every single day, but for more than a week shutdown it should be run dry just to be safe.  Most small engines today don't have the shutoff valves on them anymore.  I've installed these valves on everything I own and between this and using non ethanol gas I've solved every single engine problem I've had.  All my engines now start on the first or second pull after opening the valve after a long winter sitting.  It's truly a thing of beauty.
Just sharing what's worked for us and maybe it'll help at least one other person.
Offline FloridaMike
« Reply #51 on: August 10, 2017, 06:37:44 PM »
My 2016 GX630 20.8 hp Honda has been verified through Honda Small Engine Product Registration as a valid SN that was manufactured in China.  Just the facts Ma'am!
Mike
Offline kelLOGg
« Reply #52 on: August 10, 2017, 09:02:41 PM »
Mike, that source is good to know about. Thanks.
Bob
Offline kelLOGg
« Reply #53 on: April 08, 2021, 03:02:48 PM »
Im updating this post because the compression fell dramatically last week (to 50 psi) causing rpm drop to 3000 when sawing 8 dia cedar. Deciding on a replacement for my 16 HP Kohler engine required far more evaluation then I expected. I bandied about between Honda and Kohler evaluating price, shipping cost, physical dimensions, shaft diameter and length, bolt pattern, etc. I am strongly leaning to a 20HP Honda GX633 even though the muffler will collide with part of the mill when the band is raised to about 26. I figure a muffler shop can add and bend exhaust pipe less than 2 to avoid this. What do you think?
Replacement Engine Cover
Started by Magicman on Sawmills and Milling
Last post December 14, 2012, 11:05:34 AM
by PC-Urban-Sawyer
smiley
engine replacement time?
Started by woodbeard on Sawmills and Milling
Last post June 30, 2007, 02:28:05 PM
by woodbeard
gas engine replacement for Detroit 353
Started by mjeselskis on Forestry and Logging
Last post March 06, 2015, 11:35:39 PM
by treeslayer2003
Lombardini engine replacement
Started by Ccwood on Sawmills and Milling
Last post June 17, 2019, 11:37:08 PM
by LeeB
