1985 wood mizer Lt40
Started by Stefinney, August 04, 2017, 06:32:17 PM
Stefinney
My variable speed control has went out on 1985 Lt 40
looking for a replacement, if anyone has one left from upgrade, very interested.  Can't afford the upgrade at this time.  Thank you!
Chuck White
Welcome to the Forestry Forum, Stefinney!
Wayniac
if you are talking about the photometer under the knob you can get one at radio shack
wayniac
Stefinney
The Powerfeed has went bad.  Woodmizer has an upgrade, but it's over 800 dollars.  Was hoping someone would have one from an upgrade I could possibly by at a reasonable rate.  The older models use a rheostat, if I could find one, that would be great
Kbeitz
Lots of  rheostats on E-bay...
Love machine shop work
and Wood work shop work
And now a saw mill work
Stefinney
Yes, ordered a couple,  fingers crossed we can get this thing working!
MartyParsons
Hello,
   The Very Early LT30 and LT40 mills had a complicated power feed system. I have only ever see a few of this design. The potentiometer ( rheostat) will not work on this design.
The early design had detents on the dial to control the speed and was variable but it was detented so if the next detent was to fast and the lower speed was slow there was nothing in between. It is a mass of copper and lowered the voltage to  the motor  by creating varying resistance and current to the power feed motor.
Here is something the same that was used back in the day.
http://www.italohm.com/lang_en/products/RTP_OFEL.php
Marty
Kbeitz
There is some big Ceramic RHEOSTATS on E-bay.
2-3 OHMS, 15-8 MAX AMPS
Stefinney
Thank you so much for the help! The rheostat I ordered from eBay did the trick.  I can make this work until I can get the upgrade from Woodmizer.  Aside from the  powerfeed, my sawmill is like brand new.  Very little wear, 106 hrs.  Super excited to start cutting.🤗
