Author Topic: Modded muffler on Husky 455  (Read 3534 times)
Offline Woodcutter_Mo
« on: August 12, 2017, 03:51:52 PM »
 Today I got ambitious and modded the muffler on my old Husqvarna 455 Rancher, thought I'd share. After re-installing it I was surprised there there is a good bit better throttle response and it does seem to have a little more grunt pulling through a piece of oak I tested it on. Just trying to get it re-tuned now. So far I think it was worth what little effort I put into it.
 I just need to add a couple more tack welds and order a spark screen for it it it'll be good to go  :)
 Drilled the hole, bent the hole to direct the exhaust outward and cleaned out the muffler
Made a little deflector from an old piece of lawn mower exhaust pipe
Tack welded the deflector on and tried it out. That hole isn't very big so it didn't make it very much louder but it made it sound a little different. It's not any louder than my stock 372xp. I'm thinking I should have when up one more size on the hole but I figured I'd play it safe.
 I couldn't find exactly what size holes people drill in the 455 exhaust, what would be recommended? I didnt want to make it too big on the first try. I drilled it out to 27/64". Thanks
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline Canadiana
  • I was new a while ago
Re: Modded muffler on Husky 455
« Reply #1 on: August 14, 2017, 02:38:33 PM »
I like thr pro look of your mod. I hope the wlds went well. Great idea with making a deflector from old exhaust pipe. I have expanded the stock exhaust holes n deflector on my husky 570at in stages. The first 2 small expansions seemed to make the most difference and then not so much so i stopped. Not really any louder. More power in the cut. Burns a bunch more fuel. Smoked like a bugger the first couple starts after. Put about 8 tanks through it, that's about how far 5 tanks used to get me. I would do it again. Your Dual port seems more conventional
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
« Reply #2 on: August 14, 2017, 06:37:43 PM »
 Thanks for the reply Canadiana.  I bet the at is nice in that situation as it re-tunes it self for the added exhaust flow  :)
 I also opened the factory outlet on my dad's Stihl ms362 yesterday and it definitely leaned out some so I need to figure out the little red limiter caps on the ms362 carb as it is already maxed.
« Reply #3 on: August 14, 2017, 08:00:32 PM »
 Here's a couple better pics of the muffler installed, painted it black to keep the welds from rusting.
Offline Canadiana
« Reply #4 on: August 14, 2017, 11:57:20 PM »
The only thing cooler than buying a fancy aftermarket muffler is building one. AT seems to be easier to work with but time will tell. Your 455 muffler looks very similar to my 570. The 570 hasn't been sold here for awhile but i see they still sell em in indonesia. Good to know when it's time to find parts. I am interested in hearing how much more fuel it burns if at all. Let us know in time EH
Offline Canadiana
« Reply #5 on: August 14, 2017, 11:59:34 PM »
Did you have to rough up the muffler before paint? Confident it will stick?
« Reply #6 on: August 15, 2017, 05:53:39 AM »
 Ok, yea here in a month or two I will be using the saw more so I'll update later on about the fuel use ect.
 As for the paint, I did wire wheel the muffler some before painting. If I were to do it again, I would rough up the surface a little more and cure the paint off the saw (in an outdoor oven or something). I believe this will work though..
Offline teakwood
  • Switzerland
« Reply #7 on: August 15, 2017, 08:25:57 AM »
Can you post some pics of the 362 muffler? i have a 361 that i would like to muffler mod at some time and there is not much info out there about the 361
« Reply #8 on: August 15, 2017, 10:04:57 AM »
 On the 362 I just snipped the top of the deflector and folded it back so I could get a direct shot at the factory exhaust outlet, removed the spark screen and drilled it out to 1/2". I folded the deflector back down and will have to braze it. I believe most of the 362 muffler is stainless because it dulled the drill. I'll try to get a pic the next time I get a chance.
562 Modded Muffler
Started by hank_612 on Chainsaws
Last post January 02, 2018, 11:35:02 PM
by HolmenTree
Husky 51 Muffler Mod
Started by icornmfire on Chainsaws
Last post March 20, 2012, 09:08:19 PM
by icornmfire
Husky 576 xp muffler mod
Started by tripg1968 on Chainsaws
Last post May 10, 2018, 08:58:02 PM
by tripg1968
Muffler Deflectors for Husky 272/288 ???
Started by rahtreelimbs on Wanted
Last post December 20, 2005, 05:19:23 PM
by rahtreelimbs
