BLUECREEPER Poster Award #4!
I was given a new 5 bolt 2000 lb axle with 36" between the leaf mounts and 48" between the flange inside faces.Would like to use this as is but I can cut and stretch if needed.Thanks for your help.Regards,William.
That winch will wack you... You better get a worm drive winch.E=bay has them cheap. When you let go of the handle it stays put.
Started by DMcCoy on Sawmills and Milling
Started by Jay Sybrandy on Sawmills and Milling
Started by larrydown60 on Sawmills and Milling
