Author Topic: Can anyone help me identify this. Ash?  (Read 2471 times)
Online Crusarius
  • Lost in....
    • RockModified.com
« on: September 05, 2017, 09:58:13 AM »
This is a tree that came down in my woods. Pretty sure it is local since it was in the woods of western NY. Anybody tell me what it is?
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
Re: Can anyone help me identify this. Ash?
« Reply #1 on: September 05, 2017, 01:21:22 PM »
Are the leaves part of the tree or a sapling that it happened to land next to?
Offline nativewolf
  • Forester
« Reply #2 on: September 05, 2017, 01:33:04 PM »
Oak, do you have chestnut oak locally in your part of NY?  Looks like a chestnut oak leaf maybe.
Anyhow, Ash has a compound leaf, looks like a hickory leaf or a short walnut leaf if that makes sense.  The leaf is several leaflets, google will show you better than I can explain.  Ash bark is corky/blocky, those long veins in bark and smooth sections of bark are a good indicator that it is an oak.
How big??
Liking Walnut
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #3 on: September 05, 2017, 02:23:59 PM »
Yes the leaves are part of the tree.
I know I have lots of oak. That log in the picture probably about 8" diameter but that was up the tree a good 25'. The tree actually has a crotch at the ground. the entire tree uprooted and I was wondering if I should be getting it up out of the dirt for sawing when I get my mill built. Or will it be okay to leave it where ti is? It is sitting directly on wet ground.
Offline TKehl
    • Kehlhof Ranch
« Reply #4 on: September 05, 2017, 05:20:57 PM »
Will second Oak.  To far out of my "native range" to name a variety.    The bark on some of ours do the same thing when transitioning from juvenile to adult bark, but so do some other trees.  Leaves confirm.
If it's still alive, it shouldn't rot on the ground.  Will grow "sideways" until cut.  Not sure if there are any other negatives.  I have a small cherry that blew down last year I intend to cut up.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #5 on: September 06, 2017, 07:43:32 AM »
I forgot I had a tree book at home. closer investigation may be showing more towards english oak than chestnut. But they are very similar. the chestnut seems to have oval shaped leaves where the english had leaves wider at one end which this tree has.
here is another picture closer to the top of the tree.
Offline Blue Noser
« Reply #6 on: September 19, 2017, 05:25:57 AM »
Red oak (Quercus rubra)
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: September 19, 2017, 07:42:49 AM »
Definitely a red oak.  Looks like northern red oak to me , too.
Offline Ada Shaker
  • If it moves shoot it, if not chop it down.
« Reply #8 on: October 02, 2017, 03:49:30 PM »
All I know is, leaves of three, let them be; leaves of four, give me more.
I seriously have to get you guys to id a tree i have in my backyard, no idea what it is.
If it hangs to the left, your likely to be a Husqvarna man.
If it hangs to the right, your likely to be a Stihl man.
Anything else is an uncomfortable compromise.
                             AND
Walking with one foot on either side of a barbed wire fence can become extremely uncomfortable at times.
Offline BigBurOak
« Reply #9 on: October 12, 2017, 12:56:53 PM »
I've seen them trees all over the place as far as I know that would be a Northern Red Oak. If that tree's got any good burls, crotches, or is 14"+ in diameter it's worth sawing, provided you can get it out a your woods.
Who needs a gym if you got a woodpile?
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #10 on: October 12, 2017, 01:01:24 PM »
I doubt its 14" diameter. but it is approximately 30' to the first crotch. maybe 10" diameter. I can definitely get it out. Since it has already fallen down it will get milled after the mill is built.
I still need to find me some test subjects to mill before I want to make anything good. I should go collect leaves from everything that I need to identify before they all disappear. the oak is laying on top of a bunch of trees that I don't know what they are. I know green they did not burn very well at all.
I think I need to move my junkyard and make my log pile over there.
Offline ThomasHenriksen
  • Member*
« Reply #11 on: October 12, 2017, 04:12:42 PM »
Looks like a red oak to me too.
Offline Blue Noser
« Reply #12 on: October 13, 2017, 05:32:19 AM »
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #13 on: October 13, 2017, 07:40:07 AM »
That will make my dad very happy. He loves his oak.
Offline Ron Scott
  • Forester
« Reply #14 on: October 15, 2017, 11:31:24 PM »
Yes to northern red oak.
~Ron
Offline WanderWonder
  • Forestry Student - SIU-C
« Reply #15 on: October 19, 2017, 06:38:42 PM »
Fagaceae Quercus rubra
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #16 on: June 10, 2018, 06:13:09 PM »
Well I went and looked at this tree again today. No more leaves. Guess it is time to go harvest. one of the branches is roughly 12" diameter and the other is about 15". Nice long straight trunks easily 20'+. I guess maybe this weeks task after work is pulling them out of the woods. I also have a hickory that no longer has leaves and is laying down. that will get rescued this week as well.
Getting really close to painting the mill. I have sawed a good amount of stuff just playing around. Almost done with it.
Can you identify for me please.
Started by Duke Santos on Tree, Plant and Wood I.D.
Last post January 01, 2017, 09:42:47 PM
by Ron Scott
Identify this oak
Started by poke2323 on Tree, Plant and Wood I.D.
Last post February 26, 2015, 05:55:30 PM
by mesquite buckeye
****Help Identify?****
Started by dcrice on Sawmills and Milling
Last post May 01, 2018, 12:26:16 AM
by Brad_bb
Please help to identify this log
Started by dbmoran on Tree, Plant and Wood I.D.
Last post June 23, 2019, 09:52:39 PM
by dbmoran
