Bucket forks
Started by Crusarius, September 05, 2017, 01:03:29 PM
btulloh
Here's the bottom.  Not much to it.  The jaw of the 4-in-1 is not a flat plate.  It's a thin triangular box with a cutting edge in front and a cutting edge in the back.  The top and bottom plates are pretty thin.  As a unit, it is strong and holds up well to abuse from typical use, which does not include mounting bucket forks.  The reason I made them this way was to put keep the force at the front and at the rear of the jaw, where the big steel lives.  There are some shim pads welded on to the top of channel steel at the back so the force is applied there instead of the thin steel of the box structure.  I did not know if would work when I was building it, so I just used a piece of 5x1.5 channel that was laying around and some 5/16 plate.  I didn't spend a lot of time making it pretty - I was just trying to see if would be functional.  Someday in my spare time I'll make another one now that I know it works.
There's a plate on the outside of each fork and two bolts through the side of the jaw that hold it in place.  The bolts don't have any real strain on them unless I catch a tree while backing and turning.  Not that that would ever happen. ;)
The whole design is dictated by the design of the 4-in-1.  My first idea was to just make it with a vertical bit at the back end of the channel and just slide the forks on and bite them with jaw to hold them in place.  Could work, but the geometry of the jaw and the cutting edge on the blade was too much to deal with at the time.  Maybe I'll go back to that on Version 2.0
Here's another counter-weight I use.  It works fine, but with the log on the back and a 10 foot pallet of lumber on the front, it's hard to get through the drive-thru at BurgerDoodle.
One thing I've found with this tractor is that I'm constantly switching between using the counter weight and using the back forks for actual work.  If my counterweight was hitched on I'd have a lot less flexibility from task to task.
HM126
Crusarius
Thank you for the detail. that really is a pretty slick setup. Definitely looks very stout.
I have a quick hitch on my tractor so changing from weight box to forks is not that much work. I do find that I almost always want my box blade on there for quick cleanup as I drive through an area so that has been my goto weight.
Crusarius
Real testing performed last night. I almost had to post a picture like Kbeitz but I managed to save it. I would have gotten a pic but I could not get off the seat without it wanting to fall over. I definitely need counterweight.
Also works for trees.
Crusarius
Forks did bow with the jeep on there but straightened right back out after setting it down.
I am very pleased with how they work.
maple flats
I used to use other pieces of farm equipment for rear ballast when lifting heavier loads in the front bucket or on my forks, then I bought an old steel weight box. I have it filled with crushed stone with a few large rocks too. The box is likely somewhere between 1500 and 2000# I'm guessing. With it on, I have no issues carrying the heaviest loads my FEL will handle. My loader bucket is quick attach so it's easy to change from bucket to forks. I had clamp on forks on my previous tractor, but that put the weight more than 2' farther out front, I like the regular forks much better and being mounted directly to the loader arms I can lift far more weight than I could back when I was using clamp on forks.
Which ever you use, just be sure to carry a heavy load low to the ground and don't make any fast turns. Many a tractor has been rolled by carrying loads too high.
I'll also vouch for the handiness of a thumb, while my tractor does not have one, I do on my little excavator. It's a mechanical for now but I think I'll add hydraulics someday. Even with a mechanical thumb, I can lift a big load of brush or limbs by clamping the bucket back against the thumb , lift it all and drive to a brush pile, then just open the bucket away from the thumb and the load drops. I just took down 3 basswood stems (a 22", a 20" and a 19" DBH) 2 wks ago, they were a cluster of 3 at the edge of the woods so they had lots of limbs to get rid of. All the bigger ones I bunched into good size piles just using the bucket and thumb, then I opened the bucket, pushed the thumb to the pile and clamped down with the bucket, lifted and drove. I was carrying anywhere from about 200-500# on a load with the bigger limbs (up to about 3.5" diameter, over that will be burned in my evaporator). The loads at the end got smaller as I had to pile stacks of smaller limbs to then clamp and carry, but it was way faster than any method I used before I had the thumb.
aigheadish
Bringing this topic back up, in case anyone hasn't thought of this, though I may have mentioned it elsewhere on FF.
I've got forks for my backhoe bucket and they are rightly impossible to see and try to slide into pallets or whatever I may be forking. To fix that I bought an inexpensive rear-view camera setup for a car, mounted the camera to a magnetic monopod and now use that, with the screen just above my steering wheel to see where my forks are going. It's not perfect but it has enabled me to be able to properly fork a lot of stuff and even be able to set stuff down very specifically. In the picture below I set this pallet of shelves into a small clearing in the shed and I wasn't too worried about destroying anything.
One thing I may eventually add is another camera or get bigger screens. I found that putting the camera down in the bucket, mostly level with the forks, makes seeing them much easier than the camera on top of the bucket. However, when there is a load on it is tough to see where the top of the load is compared to where it's being set. Another camera for the top of the bucket would probably help that.
Support your Forestry Forum! It makes you feel good.
Crusarius
That would be great. Glad you brought this back up I forgot about the camera idea. I am actually going to build a quick attach plate and convert everything over. I have a quick attach on the 3pt and love it so I want one on the front. I keep picturing being able to put quick attach plate on my snowblower and run it front or rear.
Ljohnsaw
I converted my 545D tractor to a QA and the bucket. Then I bought another plate and made a hanger for some forks. I'll probably make some other attachments at some point that I think I need 🙄. Maybe a boom. Maybe a snowblower.
So, to that end, I keep looking for plates on my favorite auction site. I got one the other day that is odd. It's got pins and such to mount a 3pt attachment. Why would you want to mount a 3pt attachment to the front of your tractor?
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Was it homemade?
Use to be a tractor at the Bangor, ME woods expo that had a 3pt on the front of the tractor too.
I myself would prefer a loader.
 But depends on what's it used for.
Some use the snowblower that is used for the rear 3ph then mounted on the front.. getting power to it is the trick. But can drive forward rather than always facing the rear and backing.
I've no 3ph attachments (yet) that I'd want on the front.
Ljohnsaw
Not homemade. It is a Vevor product. I got it for about 25¢ on the dollar. Just looking at a plate, about half price of a bare plate.
I also buy receiver car and truck hitches for 10¢ on the dollar just for the metal for future projects.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
chevytaHOE5674
Powering a snowblower up front is hard to do. Need to have a hyd pump on the rear PTO and a hyd tank feeding a hyd motor on the blower. All of that gets really costly.
I have a 3pt quick hitch welded to a SSQA plate. I use it on a loader or skid steer for picking up things like a backblade, snowblower, etc and moving them around the farm. Don't have any rear implements that I would see using up front though.
moodnacreek
Up in camp I have an older 20 hp 4x4 tractor with loader. The last owner welded 2 square hitch receivers in the bucket and they take 2 2x2 tube angle cut at the tip 'forks' about 30" They have cross pins to hold them in or remove them. These are a little crude but I have picked up so much brush often without getting off the tractor I am leaving them on. Real forks with no bucket is often much better but I am doing small trees to burn and also rocks and then dirt to fill in the holes. Bringing back an old mountain farm hay field, right in my glory.
Crusarius
Quote from: ljohnsaw on November 16, 2023, 12:36:53 AM
think box blade on the front. I want a SSQA plate setup so I can mount the bucket to the 3pt.
Crusarius
Quote from: chevytaHOE5674 on November 16, 2023, 06:25:47 PM
I have a solution for that. I am planning on building a gear box from the rear pto that will speed the PTO up and also change the direction to work on the front. be a simple 2 or 3 piece driveshaft at that point.
chevytaHOE5674
Then you have to limit loader travel and tilt to keep it in the driveshafts operations angles.
John Deere made a 110 tlb. They offered a loader mounted blower powered off the mid pto and used steel links over top of the loader cylinders to limit lift and tilt on the loader. Neat setup but it was a pita to hook it all up so kind of took away from the "quick attach" of the loader. Also kinda hang low underneath and get in the way.
Before you go trying to reinvent the wheel scour marketplace for a under tractor PTO setup. Plenty of commercially made units the drop power down from the rear and up to the front. I've seen them for sale cheaper that you could try to rig together.
Crusarius
Thats a good thought. I am not sure if I can add that to mine or not?
chevytaHOE5674
They make universal front pto shaft kits. Adjustable to fit most any tractor. Typically used for front snowblowers or street sweeper setups. They have a short pto shaft attached to a Dropbox that slids on the drawbar. Then a subframe attaches under the tractor holding the pto shaft with some pillow block bearings. Then they have a 540 stub on the front.
I see them pop up on market place from time to time without the blower or sweeper fairly reasonable.
This is a large unit but they make them for small tractors too.
True hard to do.
Or run a PTO shaft from the rear PTO to the front, is another way (like Chevy said in previous reply).
And another is the tractors that already have a front PTO or mid-mount PTO built into the design. European tractors are noted for the front PTO and front 3ph rigging.
Crusarius
my biggest thing with the snowblower setup is my old 19hp kubota had 2 speed pto 540 and 720. the blower worked so much better on the 720 setting that I would love to have that again. that is why the custom gear box to up the speed and reverse the direction is necessary.
chevytaHOE5674
Speed changes are easy to do with a chain and sprocket setup. I wouldnt recommend running a sprocket directly off the pto stub shaft though, as it places a bit of sideload that the pto wasn't really designed for.
Honestly I would mount a little air cooled briggs and stratton to the blower and power it with a v-belt setup. That way the blower would be self contained and easy to hook and unhook.
Crusarius
I really don't need another engine to deal with. Changing direction with a chain is a little more involved but still very doable. I am sure a chain would be quieter than gear drive but gears only need 2. Chain would need at least 3 sprockets.
The biggest benefit to chain is being able to have 2 outputs that spin opposite directions.
