Author Topic: Turbo 7's on a 26.5hp LT40...the result  (Read 1707 times)
Offline OlJarhead
    • Dartplayer
« on: September 18, 2017, 11:57:47 AM »
So after long last I finally had a chance to try out the Turbo 7's on my LT40HDG26.  The result?  I like these bands!
First, I just tried them on smaller logs (as suggested) and thought they cut a little faster than I was used to.  I noticed the finish was rougher than my 10's, 9's and 4's (the smoothest I think) but they definitely seemed faster.
Next I tried them on some cedar (the first logs were fir) and again I thought "these seem to like going faster".  The log was over 24" and the bands handled it well.  I only had two though and felt the last was getting dull so switched to a 10 degree to finish the log and for sure, I had to slow down!
I think for production milling the Turbo 7's will be faster though likely best on smaller logs (24" and smaller -- probably for 8 to 18" is a safe bet on lower powered mills) and also when a rougher finish is desired for beams etc...
All in all I like these bands and will have to add some more to my ever growing inventory.  Of course I'll also have to make more band boxes as I only have one now and even painted bands can be a pain to sort with one hard box!
Two thumbs up on the Turbo 7's  8)
Offline JB Griffin
Re: Turbo 7's on a 26.5hp LT40...the result
« Reply #1 on: September 18, 2017, 07:55:13 PM »
I only run 7 or 8 degree blades and im going to switch to only 7 degree.
Either the wm 7turbo or most likely the 7/40 from kasco.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: September 18, 2017, 10:12:59 PM »
What band thickness did you use?  The .045 left a significantly rougher finish than the .055 for me.
HobbyHardwoodAlabama.com
Offline OlJarhead
    • Dartplayer
« Reply #3 on: September 19, 2017, 12:02:39 AM »
045
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
« Reply #4 on: September 19, 2017, 08:12:37 AM »
I use both the turbos and 7-34 blades exclusively now.
Turbos are definitely the better of the 2.
I have resharp replace any bad 7-34s with turbos.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: September 19, 2017, 08:48:22 AM »
I need to push the 7/39 Turbos to get the smoothest lumber and even then it is not as smooth as when using the 10.  I am slightly apprehensive about replacing my rejected 10 blades with Turbos.  The 10 blades rock when sawing ERC.
The .055's that I tried broke quickly so I only use .045's.
Offline Percy
  • Resident trouble maker
« Reply #6 on: September 19, 2017, 08:52:16 AM »
If you get a chance to try a 13 degree blade, you may like it. It looks very much like a turbo 7 cept different face angle. In my opinion, it's the tall teeth and large gullet that makes these blades faster. Also seems to make them more sensitive to slight mis alignment.
Offline OlJarhead
    • Dartplayer
« Reply #7 on: September 19, 2017, 09:19:57 AM »
Thing is for me, is that I'm running a G26 and the Turbo's are supposed to be for higher HP mills.  They do seem to work well and run faster than my 10's and 4's and for production milling on doug fir, pine etc in smaller logs I think they might be a good option.
They must be great on higher HP mills!
MM -- what is the HP of your 1998 mill?
Offline Percy
« Reply #8 on: September 19, 2017, 09:46:31 AM »
My mill only has 42 hp kubota and my guess is most of the time Im using about half that. IMO your motor would be fine for these blades. Especially on smaller softwood logs as you state.
Offline OlJarhead
    • Dartplayer
« Reply #9 on: September 19, 2017, 10:32:30 AM »
Terrace huh?  I used to live in New Hazelton!  Played soccer in Terrace and Kitimat but that was a LONG long time ago!  (back in the 70's)....small world huh?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: September 19, 2017, 02:36:07 PM »
My old turbo Lombardini was spec'ed at 40 hp.  This replacement non-turbo was spec'ed at 38 hp, but if it is, then either that turbo or those two hp were powerful.  I never-ever could load the old engine down, but I can this new engine.
The jump up to the 47 HP Yanmar would have been $3400 more and I often wish that I had opted "in" instead of "out".   :-\
Offline Percy
« Reply #11 on: September 19, 2017, 07:26:01 PM »
Small world no kidding. In the later 70s I hauled logs a lot in the Hazelton area.  Does McCreary or Mikolichuk or West ring any bells? They were loggers back then🤓🤓😆
Regardless, if you could schmooze one 13 degree blade from your wm rep, you might like it on the soft wood.
Offline Seavee
  • Wood mizer
« Reply #12 on: September 19, 2017, 08:46:02 PM »
I'm running the 47hp Yanmar with the turbo 7's and they are great. Actually Marty solved some of my sawing issues when he recommended them. They saw great for me in all but Longleaf pine, for them I go back to the 10.
Wood mizer lt50 47hp yanmar Diesel  Sthil MS311, Ms661 MS200T, 029 farm boss  and a New Holland T4  75hp.
Offline JB Griffin
« Reply #13 on: September 19, 2017, 09:52:09 PM »
I absolutely will not ever again use 10deg blades. If I wanna waste time if can find better ways to.
Offline OlJarhead
    • Dartplayer
« Reply #14 on: September 20, 2017, 02:18:45 PM »
Can't say they do but we left in 79.  I am ten years your junior though so it isn't a surprise!  I was a punk hid going to school in Old Town.
Nothing like handing out at the confluence of the Skeena and Bulkley rivers!  Did they ever fix the bridge from Old Town to South Town?
Offline Percy
« Reply #15 on: September 20, 2017, 02:26:48 PM »
The Hagleget(sp) is still standing. Has a steel deck now and has been doctored up several times since you left but is still a one lane wonder.
Offline OlJarhead
    • Dartplayer
« Reply #16 on: September 20, 2017, 02:45:24 PM »
I was thinking there was originally a bridge from Old town to South Town and the one laner was on the way to new Town?  It's been a long time but I remember the bridge across the Skeena to the reservation (or South Town) was a wooden bridge that burned in the early 70's -- but I wasn't there so maybe earlier still)
Double Hard Turbo 7 verses Bi-Metal Turbo 7
Started by Beavertooth on Sawmills and Milling
Last post July 04, 2017, 09:01:19 AM
by petefrom bearswamp
Different year, same result!
Started by moosehunter on General Board
Last post February 06, 2007, 12:49:58 PM
by moosehunter
The result of my haste!
Started by francismilker on Sawmills and Milling
Last post November 12, 2012, 03:47:05 PM
by DR_Buck
Different Airline, Same Result.
Started by Mooseherder on General Board
Last post June 24, 2008, 07:11:05 PM
by fencerowphil (Phil L.)
