Dynamic Green Products Inc.
Author Topic: How many drive belts are you running?  (Read 1147 times)
Offline JRWoodchuck
« on: October 05, 2017, 04:41:36 PM »
Just curious how many drive belts you all have compared to HP.
Thanks!
Home built bandsaw mill still trying find the owners manual!
Offline Coltbodi
  • Sure, I can fix that
Re: How many drive belts are you running?
« Reply #1 on: October 05, 2017, 05:33:14 PM »
My Timberking 1600 has 2 drive belts and a 27 hp motor. The 2 belts are banded together though.
If I can't fix it, I don't want it.
Timberking 1600 with lots of mods, a 65hp mahindra with a front end loader, a welding shop, and sugarcane mill from 1890 for making syrup
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: October 05, 2017, 06:45:50 PM »
51 hp diesel, triple v-belt.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: October 05, 2017, 06:58:06 PM »
13hp Honda... 1 belt.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline 1860sylvain
« Reply #4 on: October 05, 2017, 07:32:18 PM »
10 hp électric 2 belts
Offline warren46
  • Been involved in sawing most of my life.
« Reply #5 on: October 05, 2017, 07:38:04 PM »
40 Horse Electric.  Triple V-belt.  Should be 4 or 5.
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
Offline KamHillbilly
« Reply #6 on: October 05, 2017, 07:52:50 PM »
20hp Honda , 2 belts banded
Homemade Bandmill ,Clark 664b ,Case 780b ,Jonsered 670,630
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #7 on: October 05, 2017, 08:04:55 PM »
LT40HD, with 25hp Kohler, running a double v-belt!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline moodnacreek
  • Sawin by the notches
« Reply #8 on: October 05, 2017, 08:08:49 PM »
Six c belts on a 75 hp electric circle mill.
Offline boscojmb
« Reply #9 on: October 06, 2017, 09:05:25 AM »
I have the 51 Hp Cat /Perkins running a triple "C" series belt.
I can still get the belt to slip. A four row "C" series would be better for my engine.
John B.
Log-Master LM4
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #10 on: October 06, 2017, 10:06:07 AM »
42 Kubota diesel, triple V
Offline Percy
  • Resident trouble maker
« Reply #11 on: October 06, 2017, 10:25:17 AM »
Pretty much the same as Terrific, 42 hp Kubota three row belt. My blade drive pulleys were worn out at about 8500 hours. If a guy could come up with a reliable clutching system, a cogged belt like drag racers use on their superchargers would aleiviate any slippage.
Offline JRWoodchuck
« Reply #12 on: October 06, 2017, 06:24:03 PM »
I have a 19 hp diesel with one drive belt. I have been wondering if I have been getting slippage while milling causing some rise and fall in my cuts. Still real new to this stuff so just learning. Seems like everybody with 2 has more hp than me. Just trying to rule out possibilities. Thanks for the responses.
Offline Kbeitz
    • My Hobbies
« Reply #13 on: October 06, 2017, 06:56:33 PM »
I can slip my single belt with my 13 hp Honda.
Offline JRWoodchuck
« Reply #14 on: October 06, 2017, 07:40:29 PM »
How would I know it's slipping? If Im getting slipping.
Offline FloridaMike
« Reply #15 on: October 06, 2017, 08:19:50 PM »
My mill is still under construction, but will be running two 5/8" belts with a 20.8 hp Honda.
Mike
Offline Kbeitz
    • My Hobbies
« Reply #16 on: October 06, 2017, 09:20:32 PM »
On my mill I could see the blade slowing down and the carriage also slowed down.
Then it's time for a new belt or something happened. Once my idler spring broke.
Offline Tim
  • No catch phrase anymore.
    • www.schwan-cedar.com
« Reply #17 on: October 10, 2017, 07:37:06 AM »
You'll hear the belts "bark"... and possibly belch smoke. If they smoke, you'll smell it.
Dodge, Martin and others that manufacture PT components have selection procedures in their engineering catalogues. They are step by step selection guides that are pretty well described in there.
I'm running a triple B speed up drive from 550rpm @ 48hp to ~1650rpm on my shingle mill. When I installed the drive,I had one belt turning over in the centre. I asked a millright friend about the problem. As they do not make matched sets of belts anymore, and in that Don does not like the banded ones, he gave me the fix for the problem. He told me to take the centre belt that was turning over and swap it to the outside. I've run another hundred thousand shingles since without a problem.
Eastern White Cedar Shingles
Need new drive belts
Started by SAnVA on Sawmills and Milling
Last post April 02, 2013, 09:50:32 PM
by SAnVA
WM drive belts on diesel engines
Started by barbender on Sawmills and Milling
Last post November 02, 2014, 08:36:14 AM
by petefrom bearswamp
Diesel blade lube and rubber drive belts?
Started by Jhoff on Sawmills and Milling
Last post April 20, 2018, 10:47:32 AM
by Jhoff
Wood-Mizer LT40 HDG25 Drive Belts - GONE
Started by DR_Buck on For Sale
Last post June 06, 2018, 07:22:17 PM
by Stephen1
