Author Topic: Warrior 12” swing-blade  (Read 5666 times)
Offline NZJake
  • Board Moderator
    • 12 X 12 CUT MONO RAIL SWINGBLADE SAWMILL
« on: November 21, 2017, 02:00:38 PM »
Hi all, thought I’d share video footage of our new M12 Warrior model. Very happy with the result!
Wife says I woke up one morning half asleep uttering thin kerf and high production, I think I need a hobby other than milling?
Offline Bruno of NH
Re: Warrior 12” swing-blade
« Reply #1 on: November 21, 2017, 02:14:41 PM »
Nice looking mill
Offline dgdrls
« Reply #2 on: November 21, 2017, 06:10:32 PM »
I really like what you have made with this series of mill Jake,
Question,  does the power plant and mill head separate
from the beam for alternative style transport and storage?
D
Offline NZJake
  • Board Moderator
« Reply #3 on: November 21, 2017, 06:45:49 PM »
Yes it can slide off the beam but you would need machinery to lift it off. The Auto range of mills are heavy. Carriage weighs around 150kg alone.
Offline Crossroads
  • let’s make some sawdust
    • K Bales Enterprises llc
« Reply #4 on: November 21, 2017, 07:46:13 PM »
Nice
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« Reply #5 on: November 27, 2017, 03:53:37 AM »
Do you rate it as portable?  My 10 inch Peterson WPF is in my humble opinion barely portable.   And let me also add that it does not like the extra height of a Ford superduty 350 truck.  I have to use my aluminum trailer.
 All of the principal swing blade manufacturers offer videos with the saw head carriages being whisked around like little wheelbarrows.  I would say my 10 inch is more like a devils wheelbarrow, with a lead butt in the form of a very powerful but very heavy 35 hp engine.
Offline thecfarm
« Reply #6 on: November 27, 2017, 07:49:40 AM »
I have never see one like that on a rail.
Offline NZJake
  • Board Moderator
« Reply #7 on: November 27, 2017, 01:26:41 PM »
I’d call our M6 and M8 portable. Our M10 and M12 a better term would be mobile. Takes around 15 minutes to lower the mill onto our trailer ready to roll out. Same attachment can be used for all models.
Offline starmac
« Reply #8 on: November 27, 2017, 02:27:24 PM »
I do not expect to ever own one, but am curious. What is the maximum size board you can cut with one?
Offline NZJake
  • Board Moderator
« Reply #9 on: November 27, 2017, 10:20:30 PM »
With this model you can cut 12” planks with ease (2 cuts).
You can cut slabs up to 24” wide by double cutting.
You can cut 61” slabs using the attachment slabber.
You can cut any width slab by flipping the log once.
Offline bandmiller2
« Reply #10 on: November 28, 2017, 07:58:50 AM »
Jake, tell us about the saw blade, do saw that size require tensioning. ?? Frank C.
Offline NZJake
  • Board Moderator
« Reply #11 on: November 28, 2017, 01:25:22 PM »
Hi Frank,
Yes these blades are pre-tensioned. We are using a special tooth design to mitigate resonance build up. Also using very narrow kerf with our machined Turbokerf design. It’s a six tooth to reduce bite impact. We’ve also tweaked hook angle to also reduce pull down.
Was very impressed with full 12” cuts without bounce in some rough looking poplar.
Offline drobertson
« Reply #12 on: November 28, 2017, 06:57:11 PM »
Nice vid  , its slow enough to see the action.
Offline MbfVA
« Reply #13 on: November 28, 2017, 07:49:35 PM »
Video's playing a trick on you.  It doesn't do enough fps to capture the motion in full.   Kind of like a strobe effect.   The blade is actually turning much faster than it appears to be.
Offline MbfVA
« Reply #14 on: November 28, 2017, 07:51:31 PM »
 Did you design this blade with replaceable teeth, bolt on?  I recall some discussion of that when you were putting forth info on the new thin kerf blade.
